Originally posted by MouLaG Ôfr
I think it is possible and it even exists for now : see the astrotracer function with the O-GPS1
It works with very small and repeated sensor shifts, for what I understand ;-)
You don't need the same precision for the astrotracer function. For astrotracer it might be good enough with resolution of 1-2 pixels as it will be constant moving over a long period of time. I don't think I seen any picture taken with O-GPS1 that are pixel perfect when viewing at 100%, but they are still pretty good.
For adding resolution you probably need close to 1/10 of a pixel resolution, as otherwise the error will be to large and the added data will be garbage, so you might get better result by upsampling the image in PP.
