Originally posted by Clavius
But... You can already do this without the sensor shift. Quite easily too, without being limited to the range of sensor movement. And with current Pentax cameras, you can even do that handheld. See Brenizer method.
It's also a bit about impact. The rumored technology will cause the K-3 to be labelled as a 40mp camera, no matter if that is in fact true or false.
Not really. Sensor shift would be an automated system that can easily be stitched together. But doing panoramas (and if I understand the Brenizer method correctly that's what it is, a panorama, just with certain constraints giving a special look) is a pain in the *** as soon as there are objects that are near and far... the nodal point will give you some serious problems. Now I do have a nodal point adapter, but these things are usually pretty damn expensive for a bit of metal with some screws...
Still, very interesting idea, thanks for that. I might want to find the nodal point of my 50 1.8...
