10-06-2013, 05:14 AM   #436
Barry Pearson's Avatar
QuoteOriginally posted by MariusCTM Quote
yeap, a dslr of 1kg and 1 lens of 1.5 kg over the heads of the crowd! cool!
I've used the LCD on my K-7 (with battery grip) to take photos over the head of a crowd using my DA* 60-250mm lens. More like 1 + 1 kilograms.
(An articulated screen would have been better! But this was 4 years ago.
10-06-2013, 05:31 AM   #437
TenZ.NL's Avatar
QuoteOriginally posted by Mistral75 Quote
That and also the fact that the upper front part of D-BG4 is horizontal, flat:
whilst there is a slight recess in the corresponding part of D-BG5, matching the body's slight protrusion:
Similar, but not the same. Look at the detente pins. On the D-BG4 there are both the same size, but on the D-BG5 one is thinner, and one is thicker than those of the D-BG4. As such they are quite deliberately incompatible.
QuoteOriginally posted by Barry Pearson Quote
I have no source other than the images of the new grip.
I don't know about "deliberately", but I do fear "incompatible".
(For me, the problem isn't so much the price, it is that my main camera and my back-up camera would have different grips, which is more to carry around. This hasn't happened for my last 2 cameras).
Thanks, guys.
I tried to find some differences last night but I guess I was too tired and not sharp anymore. Allthough they look very similair, this is defenately a different grip. Too bad.
@ Barry: Price is not a problem but if the old grip would fit then I could spend €250,- on something else
Besides, when working with 2 bodies I only use a grip on the main camera, the 2nd is backup and most of the time dead weight so it`s usually without grip to keep the weight down.
10-06-2013, 06:34 AM   #438
D1N0's Avatar
New specs translated from digicame.info
QuoteOriginally posted by digicame.info:
From readers, we have to provide information about the specifications of the Pentax K-3.
  • Specifications of Pentax K-3 are as follows.
    - The sensor 24 million pixel APS-C sensor, a low-pass-less
    - Image processing engine PRIME III of the new development
    - Within the body image stabilization, adopt drive unit controller and more powerful new
    - (Effect is strong, weak, OFF selectable) low-pass selector function obtained the same effect as the optical low-pass filter by moving slightly during exposure image sensors.
    - Astro tracer support (optional)
    - AF unit SAFOX11 of new development. -3EV Supports. The use of the color information of the photometric sensor to AF
    - AF point of the AF corresponds to the luminous flux of F2.8 to three points (25 cross point), center point 27
    - Continuous shooting 8.3 frames / second
    - (SDXC, UHS-I compatible), SD media card slot dual
    - Can be saved in RAW format to use HDR
    - In the new development, finder redesigned optical system. 100% field of view, 0.95x magnification
    - Body adopts a magnesium alloy up and down and back and forth. Dustproof drip-proof. Cold performance of -10 ℃
    - Durability of the shutter 20 million times
    - Possible cooperation with smartphone FLUCARD of options
    - Body Premium Black and Silver Edition
    - Battery grip D-BG5 of K-3 only
If you think of this information as the sensor is retrofit to a low-pass-less 24MP sensor, viewfinder AF unit also image stabilization unit and the new development, Pentax K-3 is going to be a big model change very from K-5 II . In addition, low-pass filter (?) Mechanical Interesting idea to bra slightly with the SR.
Google Translate
10-06-2013, 06:37 AM   #439
The shutter is actually good for 200,000 actuations - google botched the translation as usual. Anyway, that would be a 2x increase over the K-5 series.
10-06-2013, 07:00 AM   #440
D1N0's Avatar
So if i understand correctly the low pass filter is replaced by removing moire through sensor shift.
10-06-2013, 07:07 AM   #441
With a selectable strength, yep.
10-06-2013, 07:11 AM   #442
TenZ.NL's Avatar
QuoteOriginally posted by D1N0 Quote
Lol, for the best IQ we, the users, strive to eliminate motion blur as much as possible and now the manufacturer deliberately introduces motionblur to get better IQ. You gotta love the irony in that!
10-06-2013, 07:30 AM   #443
QuoteOriginally posted by TenZ.NL Quote
That is what the AA filter does. Purposely softens the image. The predictability of the AA filter allows it to be fixed post by sharpening algorithms. Would the same algorithms work for this? I suppose as long as the effect is predictable and constant over the entirety of the sensor array.
10-06-2013, 07:34 AM   #444
Yes, K-3 takes advantage of focus peaking.
Full-time, during video?
10-06-2013, 07:53 AM   #445
Right when the FLU season is starting, I smell a conspiracy
10-06-2013, 08:16 AM   #446
QuoteOriginally posted by bhairavp Quote
..if they price their products right. The DA*300 is for 150,000 INR, which equates to ~2300USD! I can import it from B&H, pay duty and still end up paying much less!
I wonder who is getting that difference ....taxes.....or the middleman....or ?
10-06-2013, 08:30 AM   #447
I would like to see Canon or Nikon do that with in-lens image stabilisation! With every lens!
(Edit) Whoops! What about flash?
10-06-2013, 08:32 AM   #448
Two days people. Shouldn't we just wait?
Nope. I heard it was full-frame!
10-06-2013, 08:33 AM   #449
I should have packed a lunch before starting this thread.
I suspect there are more camera consumers than there are serious photographers with no desire for video. That leads me to the conclusion that if the implied stats are correct Ricoh may have a real winner (from the sales perspective) with this model.
10-06-2013, 08:38 AM   #450
QuoteOriginally posted by Colbyt Quote
Huh? My K-5 could do video quite easily. Easier than my D600 IMO.
I don't see anything that makes this camera better than Canon's cameras... tough to tell the whole experience from a spec sheet, though, and perhaps some people left Pentax because of 'difficult' video...?
camera, front, headphone, info, k-3, pentax news, pentax rumors, pictures, prices
Fixing Front and Back Focus on the K-x theunartist Pentax DSLR Discussion 18 06-28-2016 12:28 PM
Front/Back Focus issue - Is it the camera's problem or is it the lens? vtqanh Pentax DSLR Discussion 10 09-26-2012 04:58 AM
Anyone have a K-r with persistent front-focus issues and actually get it fixed? deadwolfbones Pentax K-r 7 02-17-2012 01:43 PM
Front/Back Focus vs DOF= 1/3:2/3? jmg257 Troubleshooting and Beginner Help 4 01-10-2012 01:47 PM
Any pictures of 70mm and 77mm DA side by side? eyou Pentax SLR Lens Discussion 62 03-24-2009 04:03 AM
All times are GMT -7. The time now is 10:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
