Originally posted by Kunzite
A clue towards a new shutter is the increased reliability (which I mentioned before). Or, maybe they found out the old MTBF was underestimated by a factor of 2
FSP could actually need shutter modifications, if the rearming is not fast enough.
AFAIK the SR lowers the effective sync speed a bit, so the shutter should actually be capable of 1/250 (in a non-stabilized body). Maybe they would be able to improve on this limitation, but using a faster shutter (as in: faster traveling curtains, resulting in a faster sync speed) is probably too expensive, for a $1300 body.
I don't know. I mean, I give up on presuming anything about "why Pentaxes won't work as others".
Sony also uses SR, and Olympus. Alpha 77 syncs at 1/250, and Oly EM1 at 1/320.
Their lower grade cameras, though, sync at lower speed. Old Alpha 65 synced at 1/160.
I remember reading somewhere many months ago, that Olympus deliberately omitted using a better shutter mechanism for the OMD5 to sync it to 1/320. They used a lower grade, saying that cost would not be justified, and that they are leaving it for the flagship (presumably EM1?). However, 1/320 is now available in their E-P5 too. It costs less than $1300.
And K-3 s is supposed to be some sort of
flagship for Pentax, but the cost isn't justified at all? All that doesn't make any sense when comparing to others. And makes one wonder in what direction those Pentax cameras and the entire system are going to.
