Originally posted by dosdan Yes. More MP on the same sized sensor means smaller sensels. For the same level of sensor technology, small sensels are individually noisier than large sensels. But if you were to print out the same sized output images, say A4 or 11"x8.5" sized prints, then more sensels reduce the overall noise level. So, if the fill factor is the same (how much of the sensor's surface is actually capable of generating a signal from the light, rather than "wasting" some of the sensor's area with connecting traces and other structural elements, both trends tend to cancel out. In the old days, when fill factors were low, more MP meant overall noisier images. But today, with very high fill factors due to efficient micro-lens designs, there's not much in it.
Hi Dan, I think you know a lot more than me so let me ask you this.
My thinking is more megapixels are friendlier to post processing as long as you captured your subject sharp enough. Simply put, more information is more editor friendly. As you say 100% crops are more noisy with the D7100 relative to the K-5 II but I think they are easier to manage for a good editor. I would rather not work with a 100% crop with the K-5. I would be happy with 80% or so because it seems some birds only let me get that close at 700 to 900 mm or so.
