10-07-2013, 06:51 AM   #121
johnmflores's Avatar
QuoteOriginally posted by jonny1986 Quote
about raw video output...i don't see nothing about this in spec..anybody can clarify?
Here you go. I wonder if the page is down because some of the specs are wrong. I sure hope that they don't take RAW video off!
10-07-2013, 06:51 AM   #122
QuoteOriginally posted by konraDarnok Quote
Well those limitation aren't going to be overcome by 1/250 sync speed That's a third stop, then every brand uses HSS for faster shutter speeds. So what's the problem with 1/180th?
One third stop may seem little, but that's not always the case.
That one third could give you one or two extra meters room to shoot within (people tend to pose better, with a bit of distance from the flash)
It would also give me about a second faster recycle time in many situations.
But more important: It could give you the flash/ambient mix you want.
10-07-2013, 06:52 AM   #123
cream's Avatar
QuoteOriginally posted by Alizarine Quote
everything is awesome!
'cept for the 1/180s flash sync.
I agree! I will buy it! As soon as I can order it
10-07-2013, 06:52 AM   #124
Say, what's that written in the blue line? Can't quite make it out........
10-07-2013, 06:53 AM   #125
Asahiflex's Avatar
QuoteOriginally posted by johnmflores Quote
Reading the page I thought it was about the JPEG settings.
10-07-2013, 06:55 AM   #126
Barry Pearson's Avatar
QuoteOriginally posted by txsbluesguy Quote
Does that really saw raw under the video recording quality levels?
What raw format would that be?
CinemaDNG? Or is that too much to hope for?
10-07-2013, 06:58 AM   #127
QuoteOriginally posted by Asahiflex Quote
I tend to agree. There's no mention of a RAW format for video, so I imagine there won't be one, and there's no explicit quality levels mentioned for JPG, so I imagine the quality levels listed are a "general" description not related to video.
Wim
10-07-2013, 06:58 AM   #128
cream's Avatar
https://www.pentaxforums.com/forums/pentax-news-rumors/238763-k-3-pictures-fr...ml#post2532151 here are the specs from another thread... ^^
10-07-2013, 07:00 AM   #129
QuoteOriginally posted by Ishpuini Quote
Wim
I thought so too but there is a comma between each of the quality settings and one between Good and RAW.
10-07-2013, 07:02 AM   #130
QuoteOriginally posted by Tanzer Quote
Looks like they've brought back support for PEF, in addition to DNG.
The top of the range K-series cameras have always had PEF.
Q-series don't, and I think some less than top of the range cameras don't.
10-07-2013, 07:05 AM   #131
cream's Avatar
I'm curious about this... RAW would be good, no compression. I think MotionJPG is less compression than x264/h.264 which is heavily compressed... I prefer a 5 minute video that takes 1.5 GB... than a 200MB video that is full of compression artefacts...
10-07-2013, 07:06 AM   #132
raw output in video seems an error ...in my opinion....maybe it would be noce to have an active hdmi out port to register externally.
10-07-2013, 07:06 AM   #133
awaldram's Avatar
QuoteOriginally posted by Fototim Quote
Since when in the real world has shutter speed had any effect on flash recycle time ?
Flash exposure is controlled via Aperture/ISO and is not related to shutter speed.
If you had a flash set to Xsync at 1/1000 it would still use the same power as the same flash exposed @1/60 without ambient light th exposures would also be identical.
Again nothing to do with 1/180 Vs 1/250, Flash/ambient is affected flash exposure settings not shutter .
10-07-2013, 07:07 AM   #134
QuoteOriginally posted by cream Quote
agree i cannot believe they just left us with h264...avi is much better. raw would be amazing and would really create a wow in the cinema world.
is great also we can disabled age and manual control audio. no more need for external recorder it seems.
10-07-2013, 07:08 AM   #135
to kill ambient light especially sun you need at least 8 speedflash...that's why people use profoto or battery powered strobe...because even at 1/250 sync speed you will end up at f 16 and so you need a lot of power no less than 400 watt....i mean to kill seriously...
Correct :-)
I should have used the term over power. My only excuse is that I'm not a native English speaker.
cameras, pentax k-3, pentax news, pentax rumors
Nature Pampas Highlights ozwald Post Your Photos! 2 08-27-2013 06:54 PM
how is the k-5 in regards to highlights clipping? Skog Pentax K-5 & K-5 II 4 01-27-2011 04:18 PM
P52-3-24 Light: Bokeh Highlights Rense Weekly Photo Challenges 26 01-17-2011 01:06 AM
Pentax K-5 + several lenses converted in LR 3.3 ogl Pentax K-5 & K-5 II 3 12-12-2010 12:46 AM
All times are GMT -7. The time now is 09:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
