Originally posted by tabl10s
An ISO of 51k isn't needed and could've been replaced with both ISO's of 50 and 25. Why wouldn't you raise the synch speed to at least 1/200th?
I agree about the sync speed, but that is only one problem with P-TTL. Pentax really needs a new flash system, obviously we aren't getting that in K-3. Maybe they are saving that for K-1 FF?
But, obviously a lot of people don't understand image sensors and ISO. Forcing a low ISO on a sensor that does not perform well at that speed isn't going to help you get better pictures. If the lowest ISO of the 24mp sensor is 100, then that is the lowest ISO where it performs to spec. Pentax, nor any other camera maker, aren't going to enable ISO modes that result is lower quality images. Lower ISO is NOT always better in dealing with sensors. Sensors can saturate very easily at lower ISO's, unless the sensor has been specifically designed for low ISO, but then don't expect a high ISO range out of that sensor. We are not dealing with film here, sensors need to perform well at a very wide range of ISO's.
I believe we were very fortunate when Pentax selected the 16mp Sony sensor which actually performs very well outside it's designed ISO range, especially ISO 80. There is a reason why there's a function to enable these "expanded" ISO ranges in the firmware, and they are not enabled by default. For the computer geeks out there, Pentax is essentially giving you the ability to "overclock" the sensor and use it outside its design range, because they found that it works well. That may or may not be true of any other sensor, including the 24mp used in K-3.
Bottom line, I won't miss ISO 80 if the sensor performance of K-3 at ISO 100 is already able to beat the Sony 16mp sensor in my K-5.
