Originally posted by Rupert seeing Falc here, I do have a question that I haven't see addressed. Is the new metering system anything radically different? I don't understand how the color sensors work in this and also how this all ties in with the "better" WB...if it does?
Ok, let me try then
Like the 91,000 dot RGB sensor in the Nikon D800 or D4, the 86,000 dot RGB sensor in the K-3 creates a secondary "live view" feed grabbed from the same image you see in the viewfinder, looking at the matte screen.
This secondary live feed is a very coarse 140 x 204 px color image. It is about the quality of many avatar icons or thumbs, i.e., it is just good enough to recognize what is photographed.
Therefore, it is possible to do a content analysis on images this size. I.e., look for sky, faces, snow, sand, lawn, water etc. Or shadow and sun. Allowing for smarter exposure and wb. Of course, there is a lot of magic involved in the firmware here and so, don't expect Nikon-level performance from day zero. Give Pentax a few firmware updates to fully exploit this piece of hardware.
Moreover, the prime task of said content analysis is to track the subject (3D tracking, no idea if the K-3 features it). Frame by frame, the firmware looks for the subject to be tracked (the point the AF.C locked on initially) and reports the image coordinate to the phase AF module which, in turn, determines if any of its AF points covers it. If yes, AF will be adjusted. If no, the AF stays idle (or uses prediction) until the subject moves back into the region covered by AF sensors. This enables the camera to track a subject even if It moves out of the AF area. In practice due to the low resolution, this works well if the tracked subject is well isolated against the background, e.g., by color.
Theoretically, the RGB metering sensor could have HD resolution and make most live view processing available to view finder mode.
Eventually, it will allow the camera to detect everyone's smile and trigger automatically. What a progress
