11-06-2013, 04:56 AM   #451
Andi Lo's Avatar
Take a look at how deep the lens hood is on the FA31mm f/1.8 and FA43 - but you're right, i'm probably over-thinking it (I haven't slept for 33 hours) . But Keep in mind zoom lenses are complex - we don't know all the variables in this particular optical design, which lens groups move for focusing, how far the lens extends and which way it extends as the focal length changes. I agree with the APS-C lenshood can be made longer than what is needed for FX - my sigma 8-16mm f/4.5-5.6 proves this. However, I have an old AF-D nikkor 20-35mm f/2.8 lens from 1996 that has a substantial lens hood on it - with this lens, the deep hood is necessary to be effective at 20mm.
Ah, that just makes a bit more sense. Perhaps at 20mm most of the optical members are deep in the lens, making a hood unecessary.
11-06-2013, 04:56 AM   #452
causey's Avatar
This is a classic Pentax lens. They have made plenty of not so fast lenses through their history with awesome builds, sharp from wide open. But the easiest way to make a lens smaller is to limit its aperture. People are a little obsessed with fast lenses these days, but not everyone needs a Sigma 18-35 f1.8 zoom.
As if everyone needed f1.8 at 18mm. The weight of the Sigma is pretty much equivalent to the combined weight of, say, the new DA 20-40, FA 50 f1.4, Samyang 85 f1.4.
11-06-2013, 05:04 AM   #453
Banned
Why shouldn't people be "obsessed" with fast lenses?
You also know that fast lenses have been around forever and also have other compositional aspects, outside even the DOF question.
Believe it or not, people are shooting in low light. This was something not possible years ago, but the body is only part of the equation.
11-06-2013, 05:05 AM   #454
Digitalis's Avatar
QuoteOriginally posted by Andi Lo Quote
It would offer a good explanation for why they made the hood so shallow, if the lens is at its minimum extension at 20mm f/2.8, then the hood should be perfectly adequate as it is - though you do get some lenses like the Canon EF 24-70mm f/2.8L that extend at the wide end of their focal range.
QuoteOriginally posted by Cannikin Quote
therefore the FF optimized hood must be made shorter.
Then the question is why did they put a hood ideally suited for a Full frame camera on a DX format lens? that would only make sense if the lens was a D-FA lens, but its a DA lens.
QuoteOriginally posted by snake Quote
Some people are obsessed with fast lenses because of the perception is that perform better than slower lenses - which can be disastrously inaccurate.E.G, The Pentax 50mm f/2.5 macro is considerably sharper @ f/2.5 than the FA 50mm is @ f/2.5. One also must take into consideration AF issues - slower lenses don't gain anything from cameras with High precision f/2.8 AF sensors, so using a faster lens is a necessity if you want reliable AF in challenging situations.
11-06-2013, 06:06 AM   #455
Iberia's Avatar
Pentax continues to build on it's collection of foolish focal lengths…cute, but who needs an expensive 30-60mm f2.8-4 zoom?
They like weird numbers so why not make the much needed strandard primes: 19mm f2.8, 23mm f2, 34mm f1.4, 60mm f1.8?
R
11-06-2013, 06:16 AM   #456
QuoteOriginally posted by Iberia Quote
Because you can get the FA 20/2.8 and FA*24/2 from Pentax,
the 35/1.4 from Samyang, and the 58/1.4 from Voigtlaender?
11-06-2013, 06:19 AM - 1 Like   #457
D1N0's Avatar
R
Foolish focal lengths do not exist. You choose not to understand the philosphy of the lens so you get angry at Pentax. I suggest you buy into m43's where you can find the primes you want.
11-06-2013, 06:20 AM   #458
It had better be an absolutely amazing lens with lightning fast AF.
11-06-2013, 06:21 AM - 1 Like   #459
Banned
QuoteOriginally posted by lytrytyr Quote
The first two are not easily available worldwide, particularly in Europe. The former is impossible and horrifically expensive. The latter is typically only available from Japan, used, and very expensive. And, as mentioned by several to many here, it doesn't perform as well as one would expect on a K5. Check the search for examples.
So no, they aren't really available and, for the most part, don't even exist outside of sourcing from around the world as used for horrific prices (same is the case for the FA35 in Europe right now, as I've also posted examples previously of its price going above that of the FA31 and 700EUR used being now a norm).
11-06-2013, 07:00 AM   #460
It's 20-40mm ........
11-06-2013, 07:00 AM   #461
Digitalis's Avatar
That lens was discontinued some time ago.. as a consequence, the prices for this lens have gone up.
11-06-2013, 07:07 AM   #462
thibs's Avatar
This is a rich one and pretty hard to swallow, considering the years of LULZ that SDM failures are giving us (and counting).
Really? Pentax screwed up so others can't have issues with their own version of the tech?
He said the most common Canon lens repair reason is due to the motor failure, he never said the that Canon had proportionally any comparable or higher returns than SDM c**p. He only said it was the first reason for repair.
11-06-2013, 07:37 AM   #463
Iberia's Avatar
R
All those lenses are big and heavy full-frame designs.
Besides, the first two are no longer available and the other two are manual-focus.
R
11-06-2013, 07:54 AM   #464
You're taking a light-hearted response to a presumably light-hearted post too seriously.
But, since you mention it:
They're both available right here:
Pentax Autofocus Fixed Focal Length Lenses - KEH.com
Indeed. Your point?
11-06-2013, 07:54 AM   #465
I like fast lenses -- I own two of the FA limiteds and the DA *55. But just because a lens has f1.4 doesn't mean that it is sharp. My copy of the FA 50 f1.4 certainly wasn't sharp till f2.8. I owned a Sigma 30mm f1.4 that was really poor in the corners to f4.
Fast lenses were created to allow photographers to take photos in low light, but my experience in most situations with modern cameras is that you are better off stopping down a little and pushing your iso a little than the reverse.
20-40mm, da, dc, f2.8-4, hd, lens, pentax news, pentax rumors, pentax-da, wr
The DA Limited Series Review [15/21/35/40/70] DonThomaso Pentax SLR Lens Discussion 7 03-04-2014 05:13 PM
KMZ remaking the MIR-20 and Helios 40-2 ironlionzion Pentax SLR Lens Discussion 16 09-27-2012 11:36 AM
For Sale - Sold: DA 21, 40 and 70, D FA 100 WR and FA 50/1.4, all EX++(Canada) farfisa Sold Items 11 04-23-2012 06:38 AM
Wanted - Acquired: DA 40 ltd and a DA 12-24 or Sigma 10-20 Jeff Bennett Sold Items 5 03-22-2011 03:32 PM
All times are GMT -7. The time now is 02:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
