11-09-2013, 03:10 AM   #721
Iberia's Avatar
Only by empirical observation; I'm not aware of any laboratory measurements being published (except Pentax' own chart). Yes, it's clearly better.
Have you compared images taken (by you or someone else) using identical lenses with different coatings?
And if so, can you post a link?
Such claims cannot be validated unless they're substatiated with adequate testing.
The days when I believed in every manufacturer claim are long gone…
R
Last edited by Iberia; 11-09-2013 at 03:11 AM. Reason: rephrased for clarity and added quote
11-09-2013, 03:12 AM   #722
Banned
That doesn't make it "clearly better", since there are always, even in your own posts over several years, deviations between lab results and what one sees in the real world. When people have bashed Pentax based on pure numbers and spec sheets, you've told them to the effect of using the said item or bashed them for not using it and relying too much on the print. But now we're seeing you on the other side.
In the spirit of the impartial side to your postings, Alex, we need to wait for the real world to see. Nothing will be better "clearly" in every situation. There are always tradeoffs, which we will have to see. Perhaps, little difference at all.
11-09-2013, 03:14 AM   #723
Iberia's Avatar
Blind brand following is bound to cloud our reasoning somewhere along the way…
R
11-09-2013, 03:26 AM   #724
D1N0's Avatar
QuoteOriginally posted by Iberia Quote
R
same goes for blind sceptisism
11-09-2013, 03:29 AM   #725
Other lame attempts to discredit me? Don't you realize they only shows that you don't have any argument?
If something can be seen with the naked eye (as opposed to lab measurements), I will call it "clearly better". Deal with that.
I saw the difference at Photokina, and then there are sites who made side to side comparisons, in challenging conditions:
GANREF | ???????
11-09-2013, 03:48 AM - 1 Like   #726
Iberia's Avatar
GANREF | ???????
Adequate testing is fine, one doesn't have to measure everything.
R
11-09-2013, 03:53 AM   #727
Banned
GANREF | ???????
I didn't even argue with you, Alex.
11-09-2013, 04:13 AM   #728
gazonk's Avatar
QuoteOriginally posted by bxf Quote
Perhaps it's simply due to he fact that I haven't been around these forums long enough, but I don't recall such a determined dissection of the value of the other Limited lenses. I always had the impression that the value of these was accepted due to their generally conceded superior optical and construction qualities.
I think there were negative comments about the DA35 Ltd (e.g. "who needs a 35mm macro? Ridiculous!") and DA15 Ltd ("f/4? ridiculous!"), but mostly these comments wane when proof of the optical quality comes.
11-09-2013, 04:53 AM - 2 Likes   #729
Gray's Avatar
Has anyone confirmed the better HD coating performance through objective/cientifical evaluation methods?
R
I don't think the HD coating makes much practical difference in the field.
Here's a comparison of the smc and HD 15/4 limiteds. (The smc DA in fact looks better because its starbursts aren't stunted by rounded blades like the HD version).
HD version
smc version
Original images and thread link (thanks mooeep).
11-09-2013, 04:55 AM   #730
Banned
R
This is absolutely right.
But you know, you can look for the best gear available all your life, or just use the tools that are available for you.
When you buy a K-3 and this new DA 20-40mm/f2.8-4 and you can't make some descent images over the coming years, then the problem is never your gear.
11-09-2013, 04:56 AM   #731
Banned
QuoteOriginally posted by Gray Quote
HD version
smc version
I like the smc version more.
11-09-2013, 05:05 AM   #732
The 15mm is known for its incredible resistance to flare, isn't it? But change the coatings in a lens more prone to flare, and you might see a difference
The discussion about coatings started with the HD 20-40 vs. smc 16-50. Even with the HD coating, I'm not sure if the 20-40 could possibly match the 15mm's (HD or smc) flare resistance.
11-09-2013, 05:50 AM   #733
JinDesu's Avatar
Mind you the change in the starburst is because of the change in the aperture blade shapes.
11-09-2013, 05:52 AM   #734
QuoteOriginally posted by RonHendriks1966 Quote
me too, I should grab an smc version I think (have been considering this lens for months)
11-09-2013, 06:12 AM   #735
D1N0's Avatar
So now rounded aperture blades are lame all of a sudden. Maybe some people should get a star burst filter.
20-40mm, da, dc, f2.8-4, hd, lens, pentax news, pentax rumors, pentax-da, wr
The DA Limited Series Review [15/21/35/40/70] DonThomaso Pentax SLR Lens Discussion 7 03-04-2014 05:13 PM
KMZ remaking the MIR-20 and Helios 40-2 ironlionzion Pentax SLR Lens Discussion 16 09-27-2012 11:36 AM
For Sale - Sold: DA 21, 40 and 70, D FA 100 WR and FA 50/1.4, all EX++(Canada) farfisa Sold Items 11 04-23-2012 06:38 AM
Wanted - Acquired: DA 40 ltd and a DA 12-24 or Sigma 10-20 Jeff Bennett Sold Items 5 03-22-2011 03:32 PM
All times are GMT -7. The time now is 11:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
