11-11-2013, 07:38 PM   #796
mee
Actually, pretty much any lens can produce that kind of bokeh. At a close focus distance, at wide apertures, under harsh Australian sunlight, with bright specular highlights in the background - Images like that nearly always produce horrible results.The only exceptions to that rule are apochromatic lenses, which due to their superior optical correction are largely immune to producing bokeh like that.
The solution is simple - Don't take photographs in Australia.
11-11-2013, 09:30 PM   #797
Digitalis's Avatar
QuoteOriginally posted by LFLee Quote
need to pay attention to my 77mm bokeh next time
The funny thing is the FA31 was utterly incapable of replicating that kind of bokeh, when I used it with the same scene with the same lighting and subject magnification. The SMCP-K 50mm f/1.2 likewise failed at producing bad bokeh with the same scene at its widest aperture.
Go figure.
11-11-2013, 10:16 PM   #798
Go figure.
Um...that's because the FA31 was designed on God's own workbench. How dare you even act surprised that it proved to be infallible.
11-11-2013, 11:19 PM   #799
Problem is, god is still contemplating a digital FF for Pentax. Lol
On topic, I am pretty sure this lens will be highly scrutinized/tested during the lens review since it is really asking a steep value.
11-13-2013, 05:14 AM   #800
QuoteOriginally posted by rob1234 Quote
Reminds me of the old M28-50 in look.
And a surprisingly good little lens it is. Fabulous colour saturation and near as sharp as the equivalent M primes.
11-13-2013, 06:37 AM   #801
thibs's Avatar
QuoteOriginally posted by southlander Quote
IMO the Sigma 18-35 bokeh is MUCH worse than this (but has a lot of things for it, I'm strictly talking bokeh).
At least *I* find it a lot more disturbing.
11-16-2013, 01:14 PM   #802
bokeh plus other things
Sorry, did not read all 54 pages. Here is a review of the features listed on B&H. Something not mentioned so far (I think) is Quick-Shift.
Pentax K Mount
30.5-61.5mm (35mm Equivalent)
Aperture Range: f/2.8-32
ED and Super-Low Dispersion Elements
High-Grade Multi-Layer HD Coating
Weather-Resistant Seals and SP Coating
Smooth & Quiet DC Auto Focus Motor
Quick-Shift Focus System
Rounded Nine-Blade Diaphragm
First Limited Series Zoom Lens
The bokeh will be important too. Some software can tweak bokeh to lessen the effect of onion-bokeh. Will be interesting to see test reviews.
11-17-2013, 06:27 AM   #803
QuoteOriginally posted by goldenarrow Quote
goldenarrow, I find that very interesting, because my Pentax lenses are no bokeh heros, in terms of onion rings. Which software can help fixing that? Some lenses (at least the 77mm) are particularly noughty, as they produce greenish onion rings around a violet interior. Could this be fixed as well?
11-18-2013, 07:01 PM   #804
software
QuoteOriginally posted by Frater Quote
The only one I am familiar with is the somewhat subtle effect with DxO Optic Pro. If the lens is in their database, a slider shows up to blur the existing bokeh more. It is very unsophisticated but does an OK job.
I think there is also Alien Skin's "Bokeh 2", but have not seen nor heard much about it since a couple years ago.
www.alienskin.com/bokeh/examples
I don't know of anything that can get rid of green and violet rings inside the bokeh circles. That would seem to be a big step in complexity for software to handle that. Maybe someone else has an idea if that is possible??
11-19-2013, 11:37 AM   #805
Aristophanes's Avatar
The point of this lens is to create market points.
20-40 WR pairs with the revamped 55-300 and the upcoming wide angle (probably WR) for a 3-lens set-up making room for a "fast 50" or the DA*55.
You can get 20-300mm in a 2 lens kit with only a 40-55mm gap which in APS-C is not a banger FL.
And if you read the roadmap you'll see the 18-135 may soon have an accompanying 120-380ish FL zoom, probably also WR and maybe even DC and likely in the $1,300 range, or less. That's another 2 lens kit.
And you have the lower-end 18-55 and 50-200 WR models as well.
That's 3 2-lens systems, all with a WA option, and all WR (or pending).
And 4 if the 16-50 + 50-135 or 60-250 are added in.
The Pentax APS-C line-up is pretty solid with zooms save for a long one competing with the 100-400 and an upgraded WR wide zoom.
11-19-2013, 12:52 PM   #806
Heie's Avatar
QuoteOriginally posted by Aristophanes Quote
I hope not. I'm hoping for f/4 throughout the range (f/2.8-4 with f/2.8 until at least 175mm would be even better!) and a $2500-3000 MSRP because it will have the same IQ and build quality of the DA* 60-250. Not that I am going to fork over that amount of money, but Pentax needs a no BS pro-grade telezoom. The DA* 60-250 absolutely qualifies, except it is too short. If Pentax is going to attract those begging for a 7DII/D400, that is a lens that will entice them to get the K-3. Not another Sigma-esque 50-500 type f/6.3 zoom. Everything I've read is "it's a phenomenal camera! Finally the camera we've been waiting for....but no hardly any pro grade long primes/zooms. So I guess I'll just stay with my Canikon." And they're right.
Regarding lens combos, the DA* 16-50 + DA* 60-250 is just sublime.
-Heie
11-19-2013, 01:57 PM   #807
QuoteOriginally posted by Heie Quote
In my mind the F/4 makes the 60-250 a 'slight-BS' telezoom. Might not matter too much to me but the 'no-BS' zoom is a 70-200 F/2.8.
11-19-2013, 03:43 PM   #808
Considering that Sigma has already a 120-400 f5.6 zoom at 750 euros, I guess Pentax should release a lens in another league, more pro-grade oriented lens. A leak on a japanese forum has mentionned a 100-400 lens, without specification about how fast it is. May be a f4.5 lens which will autofocus with the soon to be released (hopefully) converter ?
11-19-2013, 04:28 PM   #809
monochrome's Avatar
QuoteOriginally posted by ElJamoquio Quote
IMHO that will be a lens for a larger image circle.
11-19-2013, 04:32 PM   #810
-Heie
Heie,
the Canon and Nikon 200-400mm/4 cost more than 2500-3000$, there is no way a constant f/4 lens of that focal length will cost just 2500-3000$. The newer Nikon 80-400mm/4.5-5.6 and the Sony 70-400mm/4.5-5.6 cost arount that 2500$ !!!
20-40mm, da, dc, f2.8-4, hd, lens, pentax news, pentax rumors, pentax-da, wr
The DA Limited Series Review [15/21/35/40/70] DonThomaso Pentax SLR Lens Discussion 7 03-04-2014 05:13 PM
KMZ remaking the MIR-20 and Helios 40-2 ironlionzion Pentax SLR Lens Discussion 16 09-27-2012 11:36 AM
For Sale - Sold: DA 21, 40 and 70, D FA 100 WR and FA 50/1.4, all EX++(Canada) farfisa Sold Items 11 04-23-2012 06:38 AM
Wanted - Acquired: DA 40 ltd and a DA 12-24 or Sigma 10-20 Jeff Bennett Sold Items 5 03-22-2011 03:32 PM
All times are GMT -7. The time now is 07:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
