02-05-2014, 03:05 PM   #1306
A useful if skeptical review is now up on Optyczne (but not yet Lenstip):
Test Pentax HD DA 20-40 mm f/2.8-4.0 ED Limited DC WR - Wst
02-11-2014, 05:25 AM   #1307
This review is now available in English at LensTip.com:
Pentax HD DA 20-40 mm f/2.8-4.0 ED Limited DC WR review - Introduction - Lenstip.com
In short, it is a F8.0 lens, because the edge resolution is getting worse wider open quickly, until "The image quality in the area near the maximum relative aperture is weak".
At F8.0 it seems near to my Kit (18-55 II), except at the short end's edge area, where it is better. That's decent, given that it doesn't have an aspherical element AFAIK
On the "Coma, astigmatism and bokeh" section, the 18-55 II seems to have better defintion and compactness of the LED light in the corner. That MAY suggest, that the 20-40 has a resolution drop between the edge and the corner, which doesn't show off in the resolution chart (because they measure edge resolution rather than corner resolution there).
They praise the 20-40 for its ghosting and flares performance.
The 18-55 II seems to have better contrast rendition, in terms of deeper dark tones (as far as the different pictures can reveal?), where the 20-40 looks pretty washed-out. But the 20-40 doesn't produce ghosting bubbles, where the kit lets at least one bubble sneaking in more easily.
For me, I'm not upgrading from my 18-55 II kit to the 20-40 (unless its price would be line with the Tamron 17-50, which has a different mix of advantages/disadvantages of course).
02-11-2014, 05:34 AM   #1308
gazonk's Avatar
QuoteOriginally posted by Frater Quote
Hmm. Quite disappointing. I think I just decided to reconsider the DA21 to fill in the gap between the DA15 and the DA35. I was thinking of buying the 20-40 instead, but I think I'll be better off using my old 16-45 when I need a zoom in that range.
02-11-2014, 06:51 AM   #1309
Na Horuk's Avatar
But didn't a member post landscape photos taken with this lens and the 16-50mm? And those samples showed the 20-40mm had better edge performance
02-11-2014, 07:03 AM   #1310
If your only criterion is edge-to-edge sharpness, you would be better served by the Tamron 17-50.
The central sharpness of the DA 20-40 is high (over 40 lp/mm) at all apertures until diffraction sets in.
Although the lens' designation does not include "AL",
there is an aspherical element.
According to this argument, your kit lens would be better that the FA 31,
whose coma appears to be more severe than that exhibited by the DA 20-40.
This depends on the processing.
I have found the rendering of the DA 20-40 to be excellent,
leagues away from the muddy rendering of the kit lens.
The Limited lenses are not for everyone.
Personally, I like this lens better than my Tamron 17-50,
but your criteria may well be completely different.
Fortunately, most of us have a choice of which lenses we can mount on our cameras.
02-11-2014, 07:09 AM   #1311
Zygonyx's Avatar
Very unfortunate to see bad reviews for this lens, visibly not corresponding to users experience returns... and focussing on "edge to edge sharpness".
I seems pixel-peepers are now ruling lenses fate.
02-11-2014, 07:30 AM - 2 Likes   #1312
QuoteOriginally posted by Zygonyx Quote
I[t] seems pixel-peepers are now ruling lenses fate.
They will be condemned to lugging around a Sigma 18-35!
02-11-2014, 08:13 AM   #1313
gazonk's Avatar
I'd love to see some side by side shots of this lens and e.g. the 16-45. I don't doubt that it's much better than the 18-55, which IMHO mostly gives a very boring look.
02-11-2014, 08:30 AM   #1314
QuoteOriginally posted by lytrytyr Quote
They won't worry, since it will only be from the office to the lab. I suspect many lens testers don't get out shooting pictures in the real world much.
I have a couple of times tried to search for images from some of the testers used by magazines in my country and nothing showed up. Even this forum shows that we have different interests: I couldn't be bothered doing tests but would rather spend time going to an exhibition. I often feel the majority here would choose the other way around.
That said, I need to see some really convincing real world reports with images from this lens. At first I was really interested, but my enthusiasm have cooled
02-11-2014, 08:56 AM   #1315
QuoteOriginally posted by gazonk Quote
Hi Gazonk, that makes me curious. I only have the 40mm (my only Limited), to compare my Kit against at 40mm, but didn't recognise any "boredom gap" between them.
But if you do see a gap towards your 16-45, then that one must be an interesting lens for me to consider as an upgrading target? What visual criteria is your "boredom" criteria?
I suspect that you are hooked on bokeh, because I can confirm that the Kit's bokeh is indeed nothing special really, i.e. indeed somewhat boring
02-11-2014, 09:07 AM   #1316
gazonk's Avatar
I'm not sure if I can pinpoint it, I haven't used the 18-55 much (I gave the 18-55wr that came with my K-5 to my youngest son together with the K10d). I actually think the 18-55 often works good at the long end (my daughter has taken some nice portraits with it), but at the wide end, it often seems "murky" to me, I think the 16-45 has better clarity, color, micro contrast.
02-11-2014, 09:37 AM   #1317
QuoteOriginally posted by H. Sapiens Quote
We've started a "lens club" for it:
https://www.pentaxforums.com/forums/122-lens-clubs/247859-da-limited-zoom-club.html
One of the images posted there may really discourage you,
but I believe that it was taken with one of the earlier "beta" versions of the lens.
The serial number of the copy used for the PF review (9603201)
is out of sequence with the copies that have received better reviews,
e.g. 9600338 on Optyczne/Lenstip, or 9600243 on ePHOTOzine.
02-11-2014, 10:03 AM   #1318
Mistral75's Avatar
I am not so sure serial numbers at Pentax mean anything in terms of manufacturing date or even manufacturing batch.
02-11-2014, 10:26 AM   #1319
thibs's Avatar
QuoteOriginally posted by Mistral75 Quote
But may still be an interesting clue to a possible explanation.
02-12-2014, 04:43 AM   #1320
Digitalis's Avatar
Although the lens' designation does not include "AL", there is an aspherical element.
No, there isn't - I looked at the optical construction of it the 20-40mm and like the FA77 there are no aspherical elements used in its construction.
20-40mm, da, dc, f2.8-4, hd, lens, pentax news, pentax rumors, pentax-da, wr
The DA Limited Series Review [15/21/35/40/70] DonThomaso Pentax SLR Lens Discussion 7 03-04-2014 05:13 PM
KMZ remaking the MIR-20 and Helios 40-2 ironlionzion Pentax SLR Lens Discussion 16 09-27-2012 11:36 AM
For Sale - Sold: DA 21, 40 and 70, D FA 100 WR and FA 50/1.4, all EX++(Canada) farfisa Sold Items 11 04-23-2012 06:38 AM
Wanted - Acquired: DA 40 ltd and a DA 12-24 or Sigma 10-20 Jeff Bennett Sold Items 5 03-22-2011 03:32 PM
All times are GMT -7. The time now is 04:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
