Originally posted by normhead
So, even when Pentax was the slowest, it was still better in some ways than it's competition. So the long time posters, with thousands of posts have been through all this. have seen the current numbers, and have been dealing with the "pentax needs to improve it's AF for years." The Nikon/Canon speed was paid for with less accuracy. Yet no one repeats over and over, "Nikon and Canon need to improve their focusing accuracy." So what long time Pentaxians see, in a criticism like "Pentax needs to improve it's AF and SDM" is Canon and Nikon marketing hype. And when someone with 5 posts comes on a dwells on those issues, we are suspicious, one because there are folks who make their living selling Canon and Nikon gear who come on and make exactly that type of post....
I totally agree with you and it is infuriating.
1. Starting from PF's own review, when in their K-3 "test", they disregard comparison with the D7100 on the same grounds, but compete keepers in comparison with the D610, and then state "K-3's AF is still behind the best". Their review shows total incompetence and lack of basic camera understanding, firstly by comparing apples and oranges, and then secondly by totally disregarding inherent advantage of the FF camera in keepers score, due to its DoF advantage.
2. The Camera Store reviews the K-3, and in otherwise excellent review, they say "It seems D7100 locks faster on quick change between distances'. Argh! But does't it focuses accurately!?! No one asks that nor spends hours to verify! To them, as long as "the beep" appears to come faster, a hidden assumption creeps in that "the whole AF system must be better". Totally bogus.
3. DPR's first impressions of the K-3, same fallacy repeated: a subjective feeling about how fast the AF should be, and the beep doesn't come as fast as "it should". But again, no one tests it through by making some 1,000 shots, to ascertain how statistically relevant or irrelevant is a beep in terms of acquiring a well focused photograph!
On the other hand, a study done by Panasonic (!) which was used in their advertising, showed that K5 (or K5II) has a better keepers rate than D7000 (D7100).
My conclusion is that
the only problem Pentax has is not having a damn FF camera with exactly the same AF system, and it would then appear as a perfect match to both Nikon and Canon in keepers rate, maybe even better.
Most impressions that build into Canon's or Nikon's "superior AF performance" idea
are based on results when using their FF bodies with ultrafast motorised lenses, because the FF by default has lots of advantages in acquiring a well focused photograph over the APS-C format. And then when the same AF system is just put into the D7000/71000, they are presumed to be "as good as their FF siblings", which means, "better than Pentax".
It is a whole domino effects of hidden, and totally wrong assumptions.
But no one spends any quality time to go on and analyse this new SAFOX X1 AF system from Pentax, which with its 25 cross type sensors
is simply ingenious and perfectly made for an APS-C system.
