Originally posted by dcshooter
The SDM motor I'd say is a special case ( and a bit of a red herring, since the previous posts were taliking about the Limited lenses with screw drive, not the * zooms). I am talking more about general quality of construction and materials being used.
Pardon? A "red herring"?
The SDM issue is not a "red herring", it fundamentally relates to what makes a lens "professional grade" as the latter particularly entails reliability. The SDM issue is a big problem, it must have cost Pentax numerous sales and a lot of reputation.
I do not see a substantial discussion focused only on "Limited lenses" and the post from Winder you responded to just made a very general statement about "professional grade, high speed lenses"; it was by no means reducing the context to Limited lenses.
I suspected that you did not really have convincing arguments regarding Sigma producing second-grade lenses and your response did not convince me otherwise.
- Sigma uses plastics for a lot of comonents where OEMs (Pemntax/Nikon/Canon/Olympus) use metals. This includes critical components like focusing gears.
Don't we all emotionally respond to metal whereas rationally we should acknowledge that often modern synthetic material is the better choice?
Synthetic material can be more temperature stable, respond better to knocks, can be manufactured to meet lower tolerance requirements, etc.
I guess we should all avoid Pentax DSLRs because the material directly behind the metal bayonet that is crucial for robust mounting with optical precision is an example of using "plastics".
- Sigma will often tape components together where others will use set screws. Structurally, this need not be a problem, but in hot temperatures, the adhesive can soften and things loosen up
I know that they have done that in the past with their cheap budget lenses.
Can you provide an example of an inadequate use of tape in an EX series lens, for instance?
- overall mechanical tolerances and fit appear to be generally poorer
I don't think your impression ("appear") counts much.
Many Pentax lenses have mechanical issues. The 16-50/2.8 was plagued with decentering; DPR could not find one in three DA* 55/1.4 without an optical issue, a PF users went through five copies and still couldn't find a satisfactory one. Even the FA 31/1.8 is notorious for having a loose front group (hood wobbles) or a loose middle group (wobbles when you shake the lens) or both. An FA 31/1.8 without issues is a fantastic lens, but there are many copies around which do not achieve the intended performance because of manufacturing tolerances.
I'm not trash talking Pentax lenses (although I wish for the price you are paying for an FA limited the QC would be better) but it is simply not true that Pentax build is beyond reproach while Sigma uses cheap parts.
- Sigma is notorious for not licensing communications protocols, but rather reverse-engineering them.
This has no relevance to the topic at hand.
I guess the use of "red herring" would actually be appropriate now.
It seems like you have a bias against Sigma to which you are of course entitled.
The problem is, when newer bodies (particular Sonys and Canons) have come out, they have been unable to communicate with legacy glass. Sigma has on occasion re-chipped lenses, but they have not done so for every model, and they generally will only supply the service for a shor ttime.
I have had an out-of-production lens serviced by Sigma with no issues. On this forum, I have heard many praises for Sigma service with chips being exchanged for free and with quick turnarounds. I cannot remember one story where a user was turned down because their lens was only "serviced for a short time".
- The exterior paints and finishes used on Sigma lenses are low quality and are notorious for chipping, flaking, and degrading.
I do not know which Sigma lens models you are talking about.
My EX series lenses do not exhibit any of these problems.
To get back to the term "professional grade": Many pros use Sigma lenses. Lindsay Adler is a prominent example. She uses Sigma lenses exclusively on a Canon camera. I'm sure she is paid by Sigma, but I do not believe that she would have accepted the deal if the lenses were not fit for professional use.
