Originally posted by *isteve The same amount of light enters all of the cameras at the same fstop, the question of it is how much of it do you capture and how much do you divert to the AF sensor? The problem with the 4/3 cameras is the smaller mirror.
The E3 probably uses a very high quality pentaprism and slightly overize mirror with a magnifying eyepeice that reduces the view angle to match the sensor size. This oversize mirror would compensate for the light loss due to magnification and would compete on even terms with good APSC finders.
There is no substitute for the bigger mirror if you want a brighter larger finder.
Interesting, if this is the case, then wouldnt it be possible to make a Pentax APS-C camera but with a FF mirror since the lens mount is FF, and get brighter viewfinder? or are they arleady doing that. And if the mirror is FF, the lenses cover more than APS-C then should it be a big probelm to get 100% of the APS-C FOV in the VF. if its like taking a FF VF and then just cropping it down to 1.5x then why make it smaller so u dont get 100%.
Heh am sure its not so easy. Actually I wasnt sure 100% was possible with APS-C but then came the D300 and now I want to too
Id love FF, actually the ISO performance of k20d seems fine to me, I stick to lower ISO. I want the more shallow DOF, especially with f2.8 zooms, and the big VF.
