Originally posted by audiobomber
I thought the S was designed for shorter focal length lenses (under 300mm) and L for longer focal lengths.
Indeed the L converters (I own both of them the 1.4x-l, and the 2x-l) are documented for use on 300mm and longer glass. I've tried
the short distance viewing as the text.
The next thing I did was try out a very long distance shot ---this solved some of the focus issues, but introduced camera shake issues.
I've got my findings on my website at "http://www.vannattabros.com/photo7.html" and "http:/www.vannattabros.com/photo11.html".
this is a non-commercial site, and not copyrighted if you want to borrow some of it.
I'm not sure I convinced myself whether optical cropping or photoshop cropping is best. I think it sort of depends.
It's very clear though---when you get very long (as stacked converters (I tested among otherthings a 2x-L stacked with a 1.7x auto adapter
the shake becomes a big deal.
a few observations: Converters eat light -- lots of it. if light is marginal --- photoshop crop.
major distractions on the shot (things other than your target) will cause exposure problems on the target--- use
the converter to trim them in the camera.
Buy a K-3. --- the high ISO options --- I use up to ISO 6400 and don't feel bad as can still get a good photo
This was taken with a Pentax FA-300 f2.8 @f-11 at Iso 6400 with a Pentax
1.7x adapter. ---- If you look at the metadata it will tell you differently, but just before that I had tried my Pentax-A f/2.8 and it wouldn't
quite focus closely enough for that location so I switched to the FA300 and the adapter so I could focus more closely.
What you see in that bird photo is a 'full frame' -- i.e. uncropped.
My bottom line---there is no right answer, use what you have, and if you have choices try them. --- Small birds, really close don't work
well with the Pentax A 400 or the FA-600 because of minimum focusing distance issues. (4 meters and 6 meters respectively).
the FA 300 f/2.8 foucuseddown to 2 meters), which with the 1.7x adapter made this full frame shot possible at about 3 meters or so.
