02-25-2014, 03:01 PM   #256
monochrome's Avatar
QuoteOriginally posted by bossa Quote
This new converter appears to be a re-badged Tamron. The external casing has a different ribbed texture but everything else appears identical.
Asahiman already responded to this line upthread and completely debunked it. The converter is 100% Pentax design and manufacture, not a rebadge of anything.
02-25-2014, 03:06 PM   #257
bossa's Avatar
Thanks for setting me straight...
02-25-2014, 03:37 PM - 1 Like   #258
I don't remember seeing Pentaxforum's video presentation in this thread; here it is:
If we ignore that Pentax worked on it for years, and that you can't just add weather sealing to a barrel not designed for it - you can see it's nowhere near identical to the Tamron. Of course, it looks similar - after all it's a 1.4x rear converter and there isn't much room to be creative, design-wise.
And if the specs I found are correct, it's 1mm longer (20 vs. 19mm), which means the optics are not identical.
But what do I know, I'm only a "cheerleader"
02-25-2014, 03:43 PM   #259
cali92rs's Avatar
Don't sell yourself short...you're not "only" a cheerleader.
You are a very dedicated, hardworking cheerleader
03-21-2014, 04:50 PM   #260
froeschle's Avatar
[...] how much the focus screw has to be turned to cause a given phase shift in the AF system. So, even with a screw drive AF, somebody has to translate the K value. [...]
My Soligor 1.7x AF just broke apart - no electronics inside, reduction seems to be realized by the white gear wheels. The new Pentax converter is probably more complex.
PENTAX K-5  Photo
03-22-2014, 12:34 AM   #261
I have discovered that the converter allows a fine AF adjustment different for a lens + TC combo than for the lens alone. Nice feature
03-23-2014, 11:42 PM   #262
QuoteOriginally posted by goubejp Quote
Yes, I agree on that, but wish it was possible to store more than 20 lenses now.
03-24-2014, 12:24 AM   #263
crewl1's Avatar
QuoteOriginally posted by froeschle Quote
Wow - hope you had both camera and lens supported when that happened!
03-24-2014, 02:39 PM   #264
froeschle's Avatar
QuoteOriginally posted by crewl1 Quote
I tried to pull out one of my cameras with the teleconverter and a heavy and expensive lens.
The sound revealed that this was not really a good idea.
One half of the converter stayed attached to the lens, the other one to the camera.
The corresponding bayonet only was fixed by three tiny screws in a plastic counterpart.
Fortunately, this seems to be the only damage caused - a blessing in disguise!
03-24-2014, 11:56 PM   #265
Yes, you have to be careful with heavy lenses. In fact, the mount on the camera itself is only fixed with small screws into plastic (not sure on K-3, but I have repaired a few K-7 and K-5 where the mount is more or less ripped of the camera after a fall to the ground or floor)
03-25-2014, 06:06 AM   #266
thibs's Avatar
QuoteOriginally posted by StigVidar Quote
Thought it was screwed to magnesium alloy frame ?
03-25-2014, 06:23 AM   #267
QuoteOriginally posted by thibs Quote
No, not on K-7 or K-5. It is fixed to the mirror box which is made of plastic.
The plastic in your camera: Canon EOS 7D / 10D - 70D Talk Forum: Digital Photography Review
(there is a picture of K-5 there ....)
03-25-2014, 06:24 AM   #268
thibs's Avatar
No, not on K-7 or K-5. It is fixed to mirror box which is made of plastic.
Ouch !
03-25-2014, 06:32 AM   #269
Ouch !
And K-3 is probably similar with 99.99% certainty. It is the cheapest and normal way of making cameras.
You can also see it here, https://www.pentaxforums.com/news/pentax-k30-k-5-cross-section.html , at the bottom. The small screw is cut in half and it is small and short and screwed into plastic.
03-25-2014, 06:45 AM   #270
thibs's Avatar
Yeah, I don't deny that it is expected, but not IMO on this type of cams... well, I thought.
1.4x, cameras, da, film, film cameras, forum, full-frame, hd, lenses, pentax, pentax news, pentax rumors, people, teleconverter
Vivitar 1.4x Teleconverter for Pentax k30? iittoo Pentax SLR Lens Discussion 14 12-27-2013 12:55 PM
Wanted - Acquired: Sigma APO Teleconverter 1.4x EX DG for Pentax Mount iittoo Sold Items 2 05-11-2013 06:44 PM
For Sale - Sold: Tamron-F 1.4X Pz-AF MC4 Teleconverter for Pentax stormtech Sold Items 2 01-24-2013 10:19 AM
For Sale - Sold: Tamron 1.4x Pz-AF MC4 Teleconverter for Pentax dgaies Sold Items 5 02-24-2012 01:38 PM
All times are GMT -7. The time now is 06:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
