01-31-2014, 08:15 PM   #211
I'm curious if the K-60 will have better video. E.g., Nikon's lower end D5300/D3300 both have 1080/60p but the D7100 only has 1080/30p...
01-31-2014, 10:22 PM - 1 Like   #212
Cynog Ap Brychan's Avatar
QuoteOriginally posted by OJGoreng Quote
if I cut the field of view of my original image below in half, I end up with a frame containing significantly more duck.
It's always good to have more duck
02-01-2014, 02:08 AM - 1 Like   #213
eurostar's Avatar
QuoteOriginally posted by woodywesty Quote
When I joined the Forum last year I was very excited about the benefits that "crop factor" had on "focal length". It appeared that a 300mm lens in front of a K5ll would automatically provide the magnification of a 450mm lens. However, from what I think I've learned, the actual magnification isn't changed at all only the "field of view", that what you see is the same decreased angle of view (FOV) that you would see with a 450mm lens but the object is not magnified as if you were using a 450mm lens. It still has the magnification of a 300mm lens.
The focal lenght doesn't change, obviously: it's theoretically 300 millimeters from the nodal point to the sensor plane and that can't change if you put the lens on a MX, on K-5 or a Q.
But the magnification is just how much space in the frame takes the subject without changing the distance from subject to camera, so a 300mm on a 24MP APS-C gives you the same magnification of a 450mm on a 24MP fullframe. The subject IS equally magnified in the two cameras.
02-01-2014, 03:48 AM   #214
climbertrev's Avatar
QuoteOriginally posted by Giklab Quote
Wait, so we suddenly get a 1.4x TC and a lens that looks like a ~100-350mm?
60-250 * 1.4 = 85-350mm.
Hmmmmmmmmmmmmmmmm...
Are you suggesting that this hypothetical lens might be based on the 60-250 and act like the Canon EF 200-400mm f4 L IS USM with internal 1.4x extender lens (without obviously the IS)
Hmmmmmmmmmmmmmmmm... indeed
The latter costs more money than many new cars, let alone secondhand ones
02-01-2014, 05:48 AM   #215
QuoteOriginally posted by jpzk Quote
So, this cropped image of "more duck" should therefore show more details if taken with a 24MP sensor, such as the K3 ?
JP
After a lot of reading posts on this site and DPR the "more duck" for your buck is what I believe is the case....
02-01-2014, 05:50 AM   #216
JP
It is my experience that it would have more detail, assuming good technique and a sharp photo at a pixel level. The hard thing is that the more pixel dense sensors become, the harder it is to get sharp photos at that level.
02-01-2014, 06:10 AM   #217
WPRESTO's Avatar
QuoteOriginally posted by boriscleto Quote
It's basically the APS-C equivalent of the FA* 250-600 (202-560).
It will have to be a large and expensive lens, unless the aperture is more like 4.5-6.7. Even then I'm sure it will be expensive.
I can deal with moderately expensive IF, IF, IF the IQ is really good, on par with the 250-600. But, if it is just a bargain lens - forget it.
02-01-2014, 06:10 AM   #218
QuoteOriginally posted by eurostar Quote
But the magnification is just how space in the frame takes the subject without changing the distance from subject to camera, so a 300mm on a 24MP APS-C gives you the same magnification of a 450mm on a 24MP fullframe. The subject IS equally magnified in the two cameras.
And this is what I want to believe is the actual hard optical physics/sensor relationship reality. Being a "visual" kind of person I could sure use graphic depictions though. Actually what I could use is a good course on the subject!
02-01-2014, 09:17 AM   #219
QuoteOriginally posted by Cynog Ap Brychan Quote
So if you want to get 1 horse sized duck use a telephoto lens and if you want to get 100 duck sized horses use a wide angle?
02-01-2014, 09:23 AM   #220
D1N0's Avatar
It's easy. Cropping uses less of the image circle of the lens. The sensors are cropped. Equivalent focal length is the focal length you would need on a Full Frame to get the same image as the lens produces on the cropped sensor. It's like cutting out a stamp sized piece of a 4x6 print. Focal length has not changed because you took a scissor to the photo, but the image has zoomed in to what you cut out.
02-01-2014, 09:26 AM   #221
wildboar's Avatar
QuoteOriginally posted by DominicVII Quote
What I find somewhat irritating is that you do not have the option of auto-bracketing with self-timer on kr, k30, and k50. I really hope they will adding this feature to the k60 and other future releases.
I totally agree! This is my second biggest request for the K60. My biggest request would be for the info screen settings to go back to the 'toggle' mode of the K5 and prior. The new method requires too many different key presses to show/hide the histogram.
02-01-2014, 09:44 AM   #222
lguckert79's Avatar
I hope the 18-70 has as good IQ like the 18-135
02-01-2014, 09:50 AM   #223
QuoteOriginally posted by wildboar Quote
I don't see this coming. Seems like Pentax has always reserved this feature for upper end cameras, just like they don't allow K30/50 to shoot more than three shots in multi-exposure mode.
02-01-2014, 09:58 AM   #224
QuoteOriginally posted by mikemike Quote
That's Good!!
02-01-2014, 10:05 AM   #225
QuoteOriginally posted by D1N0 Quote
I sure hate to ask this.... but I will! Lets say I put my 300mm Super Takumar full frame lens on my K3 and take a picture of the duck from 30 feet and then while I and the duck hold our positions I put the DA300mm lens on the K3 and take the same shot.. Will the two pictures be the same....?
af, cp, dc, distortion, f/4-5.6, hd, image, lens, lenses, magnification, optics, pentax, pentax news, pentax rumors, products in cp, ricoh, ricoh pentax products, rumors, wr
CP+ 2014 Pentax Interview: Question Suggestions Adam Photographic Industry and Professionals 137 02-24-2014 12:59 AM
CES 2014 and CP+ 2014 Uluru Pentax News and Rumors 134 01-25-2014 09:11 AM
PENTAX RICOH IMAGING to Exhibit Two Reference Products at CP+ 2013 Company to showcas Adam Homepage & Official Pentax News 0 01-29-2013 03:00 PM
Tomorrow, September, 5 - NINE announcements of new products Pentax and Ricoh ogl Pentax News and Rumors 173 09-06-2012 10:13 AM
All times are GMT -7. The time now is 05:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
