Originally posted by sandysnyders
To Voice of Reason. Yes I am using the Macro lense onmy Pentax K5 digital slr. I do have a tripod and can attempt that using Corel but am very interested if I can do it in camera - how wouldI do that? Is there a setting for that? thank you for your help. Is the technique called "bracketing"? thank you for knowing what I am talking about.
sandy
Okay, Macro isn't something you do in camera or in post processing, it has to do with the lens itself. Basically you want a lens that says "Macro" on it for the best effect, but you can achieve a pseudo macro effect by focusing in on something with the aperture set open more, and then getting closer to it (in the case if you're using the kit 18-55 within a foot) and focusing on the subject, in this case a flower. Macro is pretty much all the lens and how you focus.
For HDR, which is a completely different thing, you can go into the menu on your K5 and let ti do in camera HDR. You can only do it when shooting jpg only, so I generally don't do it that way. Still, if you do it in camera go into the menu, set it to jpeg only with the highest quality, and then go into another part of the menu and turn on HDR and set it how you want it. This is all in the manual, but also easily found just by messing with the menu. Then set the camera on a tripod and do a 2 second delay after you've got your shot framed, and the camera will take 3 or more pictures depending on how you set it.
You can also do it with RAW format stuff by turning on exposure bracketing, and set how many you want, then do it again on a 2 second delay and on a tripod, but it takes more work in photochop to do it, though I think you generally get better results.
