02-10-2014, 04:10 AM   #136
And every SLR is a Asahiflex/Pentax rebadge,all copycats :-)
02-10-2014, 04:57 AM   #137
QuoteOriginally posted by ElJamoquio Quote
Different elements = NOT a rebadge.
Different coatings, in my opinion, often makes for a rebadge. With modern coatings the difference between 99% and 99.2% is primarily marketing.
Different outer shell = Rebadge IMO.
The optical design is 99% of the lens. You can put a quick shift on it - and I love quick shift - and call it a Cimarron but it's still a rebadge.
Pentax, when they were in the midst of their financial woes, licensed the optical formulas to several lenses to Tokina (16-50, 50-135, 35 macro, 10-17 FE). Tokina licensed one lens back -- the DA 12-24. I wouldn't really call this a re-badge situation since there were tweaks done by both companies to the end product and the lenses were produced in their own factories.
02-10-2014, 05:42 AM - 1 Like   #138
aurele's Avatar
sorry, but what was the original point about the "rebadging issue" ?
02-10-2014, 05:55 AM   #139
That the new * Telezoom "must be a rebadged Tamron":
QuoteOriginally posted by Kenn100D Quote
70-200mm tele must be a rebadge Tamron. But i hope it aint so.��
02-10-2014, 08:00 AM   #140
QuoteOriginally posted by aurele Quote
I don't know but it seems to have taken on a life of its own to the point where it is an obsession.
02-10-2014, 08:51 AM   #141
Different coatings, in my opinion, often makes for a rebadge. With modern coatings the difference between 99% and 99.2% is primarily marketing. Different outer shell = Rebadge IMO
QuoteOriginally posted by mikemike Quote
I agree, but it is quite plausible that one brand might use better grades of glass for their elements or use better types of elements like with aspherical elements using ground glass instead of molded or hybrid. It is probably impossible to tell for certain though without it being expressly noted or taking the lenses apart and inspecting the elements by someone who is an expert in optical glass.
The real question is whether the lenses perform the same in terms of real world output. Coatings and quality of glass can affect microcnotrast and color rendition, both of which can have a bigger impact on image quality than, say, sensor size, because the effects of microcontrast and color rendition can be detected at small prints sizes, whereas it might require large print sizes before you'll notice the added resolution due to larger sensor size.
According to lenstip.com, theTokina 12-24 has a "green hole," which means it prevents a larger percentage of the green part of the color spectrum from reaching the sensor than most lenses in its price category. That potentially lowers the quality of the color rendition, which can have an impact on the final image, particularly prints.The DA 12-24, on the other hand, suffers no such "green hole" problems. It has some of the best color rendering of green (and blue) that I've ever seen in a zoom lens.
02-11-2014, 01:34 AM   #142
According to an independet lens review by the Swedish magazine FOTO, both the SMC Pentax-DA* 200mm F2.8 ED [IF] SDM and the SMC Pentax-DA* 300mm F4 ED [IF] SDM are FF lenses, as their picture circle well cover the FF picture circle.
Translated quote: We discovered that the curves for both MTF and vignetting had typical FF-performance when measuring these. Thus it is able to use it on a FF camera.
02-11-2014, 01:58 AM   #143
ogl
Banned
QuoteOriginally posted by arne.oestlund Quote
We know it for many years.
02-11-2014, 02:02 AM   #144
gazonk's Avatar
If the DA300+TC also covers FF well, Pentax already has a decent tele lineup for FF. Too bad the DA560 (according to the PF review) isn't very good on FF, though.
02-11-2014, 06:33 AM - 2 Likes   #145
StarDust's Avatar
QuoteOriginally posted by ogl Quote
Don't pick on the new guy
02-11-2014, 09:03 AM   #146
QuoteOriginally posted by mee Quote
Is there any word on Tokina releasing anything for Pentax in the not-too-distant future? I see what looks to be around a 12-28mm on the roadmap.. but I also see Tokina has a new 12-28mm F/4 out now.. wonder if they will share that with us. Btw the Tokina is still an APS-C lens..
I think that the DA wide zoom on the roadmap is an OEM of Tokina's AT-X 12-28mm PRO DX. It could replace the DA 12-24mm which was out in 2005.
A 16-85ish lens is a conundrum. It would be a successor of the DA 17-70mm, which was out in 2008. I would like to see a replacement of the DA 16-50mm, though, which is older than the DA 17-70mm. Anyway, a 16-85ish should be Pentax's original along with the DA tele-zoom on the roadmap.
02-11-2014, 10:02 AM   #147
Serpiente's Avatar
Same optical formula, different materials. If you use better glass, coatings, seals, af-motor, exterior you get a better product
02-11-2014, 10:29 AM   #148
thibs's Avatar
QuoteOriginally posted by Daikokuya Quote
I don't think so but could be wrong of course. Otherwise Pentax would have gone very quickly with the other Tok, the 11-16/2.8.
02-11-2014, 11:53 AM   #149
mrmentera's Avatar
Hej Arne,
Du kan titta på den här tråden där falconeye uppdaterar listan på första inlägget efterhand som linserna testats på FF.
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/31629-da-le...ts-thread.html
02-11-2014, 03:15 PM   #150
Perhaps Ricoh thought that making/using an 70-200mm on apsc isn't bad at all, and there is a really profitable market from that lens range as more Pentax are egging on telephoto range.
If this will be out in the market, then we Pentax users would be really covered with good telephoto lenses together with the rumored telezoom (~100-400?) and the existing 50-135.
advantage, camera, circle, dof, f2.8, ff, k-mount, k-mount lens roadmap, lens, lenses, patent, pentax, pentax news, pentax rumors, pentax-da*, picture, posts, promise, roadmap, rumor, sdm, smc, surprise, tamron lenses, time, tokina, weather, yay
Pentax K-mount Lens Roadmap Archive (from 2005 on) Asahiflex Pentax SLR Lens Discussion 39 08-29-2023 09:24 AM
Updated Lens Roadmap Phil A Pentax Q 2 06-25-2013 01:53 PM
Pentax Q Lens roadmap updated... wanderography Pentax News and Rumors 23 10-03-2012 03:35 AM
Updated roadmap for 645 mount ogl Pentax Medium Format 9 09-26-2012 12:00 PM
New lenses roadmap, updated 22/09/2008 (pdf) cateto Pentax News and Rumors 55 09-28-2008 06:35 AM
All times are GMT -7. The time now is 07:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
