02-09-2014, 02:58 PM   #121
"Badge engineering or rebadging is the application of a different brand or trademark to an existing product (e.g., an automobile) and subsequently marketing the variant as a distinct product. Due to the high cost of designing and engineering a new model or establishing a brand (which may take many years to gain acceptance), it is less expensive to rebadge a product once or multiple times than to create different models. The term is a misnomer in that little actual engineering takes place."
Badge engineering - Wikipedia, the free encyclopedia
What other definition do you think we should use? One that calls a Pentax-made lens with Pentax-designed optics a "Tokina rebadge"?
By the way, here's the patent for the 16-50:
Espacenet - Original document
And this one, for the 50-135:
Asignee: Pentax Corporation.
Your source is awesome. Thanks a million.
I wrote some of that source. Check the edit history.
Now, tell me, by which standards are those Tokina rebadges?
'one way or another'.
02-09-2014, 02:59 PM   #122
An important factor though is whether or not the lenses are made on the same line with the same parts, elements, coatings, etc... If they just share the same optical formula but were made with different glass and different coating there is a lot of room for variation in final results.
02-09-2014, 03:13 PM   #123
Different elements = NOT a rebadge.
Different coatings, in my opinion, often makes for a rebadge. With modern coatings the difference between 99% and 99.2% is primarily marketing.
Different outer shell = Rebadge IMO.
The optical design is 99% of the lens. You can put a quick shift on it - and I love quick shift - and call it a Cimarron but it's still a rebadge.
02-09-2014, 03:18 PM   #124
I agree, but it is quite plausible that one brand might use better grades of glass for their elements or use better types of elements like with aspherical elements using ground glass instead of molded or hybrid. It is probably impossible to tell for certain though without it being expressly noted or taking the lenses apart and inspecting the elements by someone who is an expert in optical glass.
02-09-2014, 03:28 PM   #125
QuoteOriginally posted by ElJamoquio Quote
Interesting. Then, why not using it?
I provided proof that those are Pentax designs, and we know as a fact they're made in by Pentax, in Vietnam, and their internal and external components are nothing like the Tokinas. Yet you're still saying this?
I give up, it's pointless.
02-09-2014, 03:32 PM   #126
Tokina lenses aren't weather sealed either, and yet the DFA 100 is weather sealed.
---------- Post added 02-08-14 at 09:16 PM ----------
Indeed. That complaint is a pet peeve of mine...
Tamron 2,8 70-200 and 2,8 24-70 are using the same WR/AW quality range like Pentax * lenses.
Maybe it is a gift from Mr Jun Hirakawa,ex Pentax optic specialist and fired under Hoya!!!
Now he is a Tamron member ;-)
Pentax 16-50 and 50-135 are 100% made by Pentax in the Vietnam Factory,Tokina production is an own thing.
The patents are made under Pentax,before Hoya.
Some of the wideangles are Tokina Patents and are produced in the own Factorys.
The Pentax 12-24 is a Tokina Patent,but built in own Factorys.
The development is a 50/50 thng between Pentax and Hoya.
This relationship is not more exist.
Best regards
02-09-2014, 03:34 PM   #127
I am. Thanks for the entertainment.
one way: pentax rebadges lens: 12-24, 18-250/270, etc
another way: tokina rebadges 16-50, etc.
02-09-2014, 03:38 PM   #128
But more interesting is this Patent ;-)
ROTARY ACTUATOR
02-09-2014, 04:27 PM   #129
Try being polite next time.
Using the same standards, the Tokina 16-50 is not a rebadged Pentax either; while the Tamron is a perfect example of a rebadge. But, as I said, it's pointless.
---------- Post added 10-02-14 at 01:30 AM ----------
QuoteOriginally posted by asahi man Quote
ROTARY ACTUATOR
I wonder if we'll see that in some lenses. Pretty old patent, but could allow them to get speed-wise on par with the fastest ring-type USM?
02-09-2014, 04:35 PM   #130
The Tamron is 100% produced in the Tamron factory,one of them.
The Patent above is a new motordrive,little bit like the Canon Ring USM.
But not the same type.
I think we will see a drive like this in the new Pro* Line,maybe end of 2014.
02-09-2014, 04:41 PM   #131
Indeed, it's different technology - non-piezo, but a magnetic drive. Anyway it would eliminate the gears and other such stuff.
02-09-2014, 05:15 PM   #132
Blue's Avatar
If you say so, but even presuming that, how does the differences in terminology affect the principles at play here?
Lenses with moving surfaces are sealed. Lenses without moving surfaces are sealed. The external shell around the glass can be sealed, but does not have to be, and the optics are unchanged.
I have not yet seen a 'rebadge' where the external surfaces were completely unchanged.
The D FA 100/2.8 WR wasn't a rebadge from Tokina nor was its predecessor, the D FA 100/2.8. Before the Hoya days, Pentax had various collaborations with Tokina, but during the Hoya years, Hoya dropped the k-mount. If you look, you will see that Tokina has a lens based on the DA 35/2.8 LTD Macro.
02-09-2014, 05:35 PM   #133
mee
Is there any word on Tokina releasing anything for Pentax in the not-too-distant future? I see what looks to be around a 12-28mm on the roadmap.. but I also see Tokina has a new 12-28mm F/4 out now.. wonder if they will share that with us. Btw the Tokina is still an APS-C lens..
02-09-2014, 06:20 PM   #134
I do hope to see it in the red (and yellow) stuff in the bottom of the roadmap
02-09-2014, 10:12 PM   #135
thibs's Avatar
Well, by that count the SMC-M 50/1.4, the A50/1.4, the F50/1.4 and FA50/1.4 are all rebadged aren't they ?
advantage, camera, circle, dof, f2.8, ff, k-mount, k-mount lens roadmap, lens, lenses, patent, pentax, pentax news, pentax rumors, pentax-da*, picture, posts, promise, roadmap, rumor, sdm, smc, surprise, tamron lenses, time, tokina, weather, yay
Pentax K-mount Lens Roadmap Archive (from 2005 on) Asahiflex Pentax SLR Lens Discussion 30 02-25-2021 06:46 AM
Updated Lens Roadmap Phil A Pentax Q 2 06-25-2013 01:53 PM
Pentax Q Lens roadmap updated... wanderography Pentax News and Rumors 23 10-03-2012 03:35 AM
Updated roadmap for 645 mount ogl Pentax Medium Format 9 09-26-2012 12:00 PM
New lenses roadmap, updated 22/09/2008 (pdf) cateto Pentax News and Rumors 55 09-28-2008 06:35 AM
All times are GMT -7. The time now is 03:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
