Originally posted by Digitalis
I don't think SD cards are quite up to those kind of transfer rates, XQD and SSD cards can do it. Also the image processor used in Pentax DSLR cameras will be taxed considerably with live 4K video - unless they incorporate more than one of them in the image processing pipeline, if that is the case expect battery life and sensor heating to also be issues. In most MF backs the sensor is passively cooled with heat sinks and in some cases actively cooled with a fan. The weather sealed construction of the 645D makes this rather problematic. Pentax possibly could use a small heatpipe or perhaps a peltier effect cooler to shunt heat away from the sensor and dump it into the chassis - but thermoeletric cooling will also chew up energy and in the end it is only moving the problem, not eradicating it.
Well if it can only deliver the quality that is also in the K-01 then it's just a gimick.
So delivering ProRes would be great. Even if the resolution would only be FullHD. I guess that not a single company would buy this camera for video if it doesn't do its work at hi level. So 2.5k or 4k at the max rate of like 100Mb/s or even 200Mb/s is the only way this will be a professional video tool.
Yes you need some extra battery's, but I don't think that will be a problem. Put at least a spare in the box.
