02-13-2014, 08:00 PM   #301
Red on the K3 is live view.
02-13-2014, 09:12 PM   #302
QuoteOriginally posted by Roberts Quote
No, there is not so much empty space in 645D behind the sensor. I don`t know about 645d II, but taking into account that 645DII has articulated screen, there is less space behind the sensor than in 645D.
Guess we're seeing the same thing and interpreting it differently. Most DSLRs have their rear LCDs crammed up against the back of the sensor.
02-13-2014, 09:23 PM   #303
QuoteOriginally posted by derekkite Quote
Thx... I don't have a K3 so I wasn't sure how the modes work. I think I had in mind the red button from the K-01, which I heard was one-touch record or something.
It could very well be the 645D-ii would only be LV, if they recycle the K3 firmware (like the K7 > 645D).
It would still be nice for display on a large monitor in a studio situation though.
02-13-2014, 09:25 PM   #304
MadMathMind's Avatar
Engineers over in metric countries must deal with the ambiguity all the time of what is mass for calculations vs weight/force when everything is called kilograms for both.
Only if the planet on which the object resides is unclear.
Otherwise, it is clear because kilograms are always mass. There's no ambiguity when you CALL kilograms "weight" because all the objects are assumed to reside on Earth, where the two quanities are simply related by a factor of 9.8. Every engineer who made it through his program would know kilograms are actually a unit of mass--they'd never pass a few core courses without knowing the difference between weight and mass!
I'd say the ambiguity is in the old USA. Most people don't even know the unit of mass (it's slugs, btw), since it is never used. When given some block on a spring problems (which need mass, not weight), many of my DE students--all future engineers--didn't realize they needed to divide pounds by 32 to get mass to make the problem work. They always equated pounds and kilograms as the same. If all they knew were kg, this wouldn't happen.
02-13-2014, 09:47 PM   #305
QuoteOriginally posted by MadMathMind Quote
...except when they aren't.
02-13-2014, 10:05 PM   #306
Banned
There is no video switch button!
02-13-2014, 10:48 PM   #307
Digitalis's Avatar
After sitting here and comparing that image to my own 645D I noticed another thing: the AF point selector dial has been blanked as well. It is likely we will see a K3 style AF system used in the 645D as well, which will give the 645D MK II a boost in low light capability.
02-13-2014, 11:01 PM   #308
Yep. And the significance of the following escapes many: Weight = mass x gravity.
So find the mass of 1 kilogram-force of weight using that formula if weight and mass are equal.
Mass = 1 kilogram-force / 9.81 = 0.102
Oops it doesn't add up on more than one level. Need to convert kilograms (the weight) to something else or have some constant that makes the numbers numerically the same and get the units fixed.
In America we also have pounds-mass and pounds-force instead of the slug and the constant gee-sub-cee (gc) is the fudge factor that makes the units work out. In my field of engineering, the slug as mass is rarely used in computations.
02-14-2014, 07:12 AM   #309
QuoteOriginally posted by RonHendriks1966 Quote
It has a standard issue "start recording" button.
02-14-2014, 07:40 AM   #310
D1N0's Avatar
QuoteOriginally posted by mikemike Quote
I think he means there is no lever to switch between video and still, like on the K-3 where the video button doubles as liveview button in stills mode. So het red dot button is only for video. And liveview must be switched on differently I guess. Orrrrr the little bit of tape hides a LV sign and the AF selection controller has a video setting (since you would use Contrast detect AF in Video mode.
02-14-2014, 07:55 AM   #311
It will be on that unlabeled dial behind the word 645D. It will have a still mode, 16:9 mode, and a 2.4:1 ratio. Framerate and resolution will still be menu driven though.
This is the wild speculation rumor section right.
02-14-2014, 12:19 PM   #312
Banned
It looks like the delete/trash button.
02-14-2014, 01:03 PM   #313
Then the red dot and the microphone holes are there just to mislead us?
02-14-2014, 01:23 PM   #314
Zygonyx's Avatar
ApparentIy nobody read or do believe in my first post here ....
it is clear for me that the "AF point" selector's indication have been erased because it will be the Video / Live view lever... and Ricoh decided to make up buzz about it....
02-14-2014, 01:31 PM   #315
between the red dot and play buttons is a rectangular area that has been badly photoshopped. this is where the video rec icon will be.
red button is record.
as for video itself...
my guess is this camera will have the same internal processor as k3 with more buffer and will offer 1080p to sd card and pro res or RAW 4k to ssd or live hdmi out.
50mp sony cmos, 645d, ability, advantage, bit, blackmagic, camera, canon, cards, cmos, crop factor, fujitsu, heat, image, k3, lens, macro, market, max, medium, medium-format, mf, minutes, model, mp, name, pentax, pentax 645d2014, pentax news, pentax rumors, phase, products, sensor, size, slr, sony, status, texas, video
Phase One announces IQ250 50MP CMOS medium format back with Sony sensor jogiba Non-Pentax Cameras: Canon, Nikon, etc. 8 03-04-2014 12:30 PM
Hasselblad H5D-50c: 50Mpix CMOS sensor from Sony -soon in Pentax 645D II? Mistral75 Non-Pentax Cameras: Canon, Nikon, etc. 8 01-22-2014 05:42 AM
Sony SLT-A58 [20.1 Exmor HD CMOS] (??Maybe K3 Sensor??) joe.penn Non-Pentax Cameras: Canon, Nikon, etc. 11 03-07-2013 01:04 PM
Do the new Sony CMOS sensors attract dirt? GeneV Pentax DSLR Discussion 10 08-31-2012 09:26 AM
New Sony APS-C size CMOS Image Sensor with 12.47 Effective Resolution for use in DSLR Matjazz Pentax DSLR Discussion 4 08-20-2007 02:42 PM
All times are GMT -7. The time now is 05:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
