Originally posted by K-9 Why do we feel that this camera will better the DXO scores of the D800s and D600s if the 80 megapixel Phase One IQ180 sensor does not?
Most Sony sensors have a very similiar DxO score when normalized per sensor area. So, I did the math and expect the 645Z to score at 105. Maybe 3 more or less.
This assumes the 645Z to use microlenses. Which I think is highly likely, given the Kodak already did it for the 645D.
The CCDs all have very bad DxO score when normalized per sensor area. Which makes the IQ180 score relatively low.
Originally posted by Cannikin Because 35mm is a standard.
People take offense with 35mm used as the standard when their camera isn't 35mm. I can understand that.
However, 35mm is already written into the EXIF header and used in marketing and camera menus when it comes to focal length. Therefore, there is no other obvious choice.
Except maybe scaling everything to 1m (or 10mm) sensor diagonal which would be more in line with SI, the International System of Units. But we all know how easy it is to make US Americans use SI.
Originally posted by Parallax Why do I keep harping on the topic? Quite simple, really. For the same reason others keep harping on the opposite viewpoint.
Again, I can understand that.
But there is something unlogical in that argument.
Once in photography, aperture was used to denote the size of the opening in the aperture blade, denoted like 10mm. To be used with, e.g., an 100mm focal length (F) lens.
People learned how to compare different F when it comes to determine exposure time: they divided F by aperture and used the quotient N (10 in the example above) to determine exposure.
At the time, it was a difficult transition, requiring the people to do some calculus in their head. And during the confusing transition, people started to write F/10 to make sure they meant a 1/10 F rather than a 10mm aperture ...
I still hear people screaming in the internet fora of the time: "aperture is aperture is aperture"
But eventually, when apertures became a fixed part of the lens, the notion F/10 became the only one in use (still different for astronomical scopes though).
Therefore, the argument that equivalent units for FStop, focal length and ISO requires math and aren't intuitive may hold true. But anybody using it really should refuse using an FStop number as well. As the same arguments apply! Life would be easier really if all cameras everywhere used equivalent units, at least optional in their menu system. That they don't (for FStop and ISO) is more due to aggressive marketing than anything else.
