05-14-2014, 07:27 PM   #16
amoringello's Avatar
Not even the company believes it, or the warranty conditions would reflect that.
And *that* is the moral of the story.
The weather/water sealing is top notch and beyond compare... when it works.
... and when it fails? Well, you're S.O.L. and on your own.
05-14-2014, 08:08 PM - 1 Like   #17
Unregistered User
Guest
Yes, Dominic, anyone who subjects their Pentax to water because of ads/reputation/becauseothersgotawaywithit are on their own.
As clear as it could be:
"This warranty does not cover any damage caused to the product, including, but not limited to: impact, moisture, liquid, sand, excessive temperature, battery leakage, chemical corrosion, mishandling, operation contrary to operating instructions, tampering, modification, or servicing by an unauthorized repair shop."
Product Repair & Service - RICOH Imaging
To Pentax's credit, they are nowhere as vague as Olympus:
"Any defect that occurs due to sand, mud, etc. entering the inside of the product casing."
etc. is the key word here.
Olympus - Warranty Regulation
Canon:
Korrosion, Schmutz, Wasser oder Sand
Canon Deutschland - Warranty information
Nikon:
lighting, water, fire, misuse or neglect.
Nikon UK
05-14-2014, 08:17 PM - 1 Like   #18
Otis Memorial Pentaxian
clackers's Avatar
Sure ... we can rightly be proud of the Pentax design and manufacturing effort, but we shouldn't overstate the case.
As your link explained, the only claim by Pentax Germany was IPX 2, which is not immersion, nor water jets, nor splashing, not even spraying, but water dripping onto the case from above ...
IP Code - Wikipedia, the free encyclopedia
05-15-2014, 12:14 AM   #19
It sounds remarkably similar to rain...
05-15-2014, 01:32 AM   #20
Timd's Avatar
Perhaps in climates where an umbrella can be used. Here our rain is usually blown from the side. An umbrella is useless and a device needs to be IPX3 to survive rain.
05-15-2014, 02:19 AM   #21
clackers's Avatar
Then I recommend you leave yours out in the rain tonight, Kunzite - have faith!
05-15-2014, 03:51 AM   #22
While the manufacturer's failsafe of voiding warranty and using technical language to avoid directly implying the ability of any product is obvious, I don't believe this negates from Pentax's ability to provide the best quality DSLR's on the current market with regard to build quality and environmental endurance.
There are plenty of videos to support Pentax's DSLR lineup. I think we have all witnessed Alex Jansen's "Pentaxian-famous" PENTAX DUST AND WEATHER SEALING IN AFGHANISTAN
[You should also check out his photography at http://www.alexjansenphotography.com]
There are also a number of other videos that demonstrate the resilience of a Pentax DSLR, with The Phoblographer and others running them underwater. Recently a Russian group found satisfaction in roughing up a K3 with water, sand and mud.
Another video I have witnessed but have been unable to find is a Japanese [Presumably] video in which a K5 is placed inside a freezer while in time lapse mode. Very impressive stuff.
05-15-2014, 06:08 AM   #23
I'm weather proof to a certain extent - yet I wouldn't leave myself out in the rain tonight...
QuoteOriginally posted by Bolt Quote
Not Japanese; Chinese perhaps? It was an Apacer rugged SD card test, and they used the best camera for this job:
05-15-2014, 07:25 AM   #24
cali92rs's Avatar
People can show all the youtube videos and give personal testimonials from here until eternity.
THe fact is, these cameras are not made by the hand of god and some have indeed failed under much more benign conditions than what is shown above. It is not a fault of Pentax, because no product is 100% perfect and failures do occur.
But the simple fact is that, under their warranty conditions, they will NOT repair your camera under their warranty if the damage was caused by something as harsh as dunking it in water, or something as benign as get a single drop of water that happens to migrate into the wrong place.
With that in mind, the prudent thing would be to protect your camera as much as possible and not to rely on it's weathersealing, because if it fails (most of the time it doesn't, but sometimes it does), then you will be stuck with the bill.
05-15-2014, 09:04 AM   #25
grhazelton's Avatar
I recall seeing a K5 totally immersed to take a picture of a swimmer. I presume that the dunking was brief, and that the lens wasn't zoomed or focused during its bath. I don't remember if the post mentioned how the camera was in a day or so.... Seems pretty risky to me.
I've never worried about light rain or drizzle with either my K10 or K5 with a WR lens mounted, but I carry a plastic bag just in case there is a deluge.
05-15-2014, 10:05 AM   #26
Unregistered User
Guest
A judgement like this, based as it is on unmistakable bias in favour of a brand, is not worth much. There is no reason to believe that the weather sealings of Pentax are any better or worse than those offered by Olympus or Lumix.
05-15-2014, 11:13 AM   #27
Fogel70's Avatar
QuoteOriginally posted by mamethot Quote
Too bad Ricoh isn't using the IP code...
I doubt they could use any any higfher IP code than IPx0 on a Pentax DSLR. With a 40+ mm hole on the front of the camera, it's not much advantage of using IP coding.
---------- Post added 15-05-14 at 20:48 ----------
QuoteOriginally posted by totsmuyco Quote
Why don't they just publish this in international magazines and capitalize on this strength? Redo all lenses to be WR at the very least. I think this would be a strong selling point.
It seems to have been published in Amateur Photographer dec 14 2013 issue. Ricoh probably hired AP to make this.
It even show the review score from AP on each camera.
I guess this will make it difficult to publish in any other magazine.
05-15-2014, 01:28 PM   #28
Zygonyx's Avatar
QuoteOriginally posted by c.a.m Quote
How should we interpret "weatherproof"? I wonder what Ricoh uses as their definition. What's the difference between "weather resistant" and weatherproof? Is the K-30 really protected more robustly against the elements than the other models?
And most importantly - should I take my K-5 II with WR or DA* lens out into the pouring rain?
- Craig
Well, as others here, i did it with K-5 and DA*16-50mm on the atlantic thunderstormed coast.
No problem after abundant rinse under the tap.
But if you don't wanna take risks, i would advise WG-4...
05-15-2014, 02:24 PM   #29
QuoteOriginally posted by DominicVII Quote
Of course this is 'bias', we are talking about Pentax in a Pentax forum. If you want 'evidence' as to the objective legitimacy of my statement, it could be reflected in results portrayed by the owners and users of said devices. Pentax has a renowned, almost stereotypical synonymization relating to the endurance of their cameras, other brands while known for their quality, do not have said reputation. As is shown throughout the internet, Pentax DSLRs can handle more then their fair share of abuse. Lumix and Olympus might also be able to hold its own relative to the general competition, but I do believe Pentax is in another ball game. If not, there would be more evidence showing Olympus and Lumix cameras sustaining equal amounts of abuse.
If I were to Google Search 'Olympus Weather Sealing Fail', it would return 8,920,000 results, whereas 'Pentax Weather Sealing Fail' only 426,000 results. It does not take a genius to notice the difference.
05-15-2014, 02:45 PM   #30
Unregistered User
Guest
There are pleny of data testifying to the durability of other brands as well. Fanboys come in all colours.
Here is one for Canon:
Here is one for Olympus:
Your google survey is downright ludicrous. "Pentax water damage" will yield 2 hits on Austrian google, "Olympus water damage" 5, and "canon water damage" 16100. What does this tell us apart from the fact that there are lots of Canons out there? Very little.
While we are walking down the path of comedians: "olympus weather seals still fine" yields 501000 hits and "Pentax weather seals still fine" 424000. Guess Olympus must be better?
ap, camera, code, da*, dslr, evidence, gear, guide, ii, ip, k-30, k-5, lens, lenses, page, pentax, pentax news, pentax rumors, product, proof, rain, ricoh, uk, water, weather, weatherproof, wr, wr lens
All Weather vs. Weather Resistant jjeling Pentax SLR Lens Discussion 5 01-10-2014 12:31 PM
PENTAX Introduces New K-30 Digital SLR Camera Featuring weather resistant capabilitie Adam Homepage & Official Pentax News 18 09-25-2012 04:23 PM
Weather resistant durability palmerchan Troubleshooting and Beginner Help 8 08-17-2012 06:04 AM
Technical Data for the new Weather Resistant Pentax DFA 100mm F2.8 Macro Adam Pentax SLR Lens Discussion 11 12-12-2009 09:11 AM
New DA series Weather Resistant Lens's vk4akp Pentax News and Rumors 23 07-01-2009 05:35 AM
All times are GMT -7. The time now is 07:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
