08-07-2014, 02:22 PM   #481
SpecialK's Avatar
QuoteOriginally posted by Pål Jensen Quote
I like AF noise. It gives feedback when the camera is focusing and when it has found it.....
It's true. It took a little time to adjustment to my first HSM lens.
08-07-2014, 02:30 PM   #482
Wired's Avatar
QuoteOriginally posted by Fogel70 Quote
I really doubt that we will ever see a lens like the upcoming Fuji X 16/1.4 for a APS-C DSLR.
And if we did it would probably be massive, heavy, and expensive
08-07-2014, 02:44 PM   #483
Fuji X16 is a micro 4/3 lens, right ? On APS-C it has a field of view equivalent to a 24 mm. And there is already a 24mm f1.4 (in the Sigma world)
08-07-2014, 02:50 PM   #484
QuoteOriginally posted by goubejp Quote
No, it is an APS-C lens. The Fuji X system is APS-C.
08-07-2014, 02:55 PM   #485
RE the upcoming Fuji 16mm F/1.4:
QuoteOriginally posted by Wired Quote
Well, I bet the Fuji will be one of those things...
No. Fuji X-mount is an APS-C mount. So it's 24mm FF equivalent FoV, or 12mm m4/3.
The Samyang 12mm F/2 is another example of the advantage of shorter registration distance for fast wide lenses.
08-07-2014, 03:00 PM   #486
clackers's Avatar
The advantage of mirrorless it that the retrofocus design get less extreme with shorter register distance, so they require less glass than comparable DSLR lenses.
A question, if you don't mind, Fogel ... why does a mirrorless need a retrofocus lens?
08-07-2014, 03:48 PM   #487
But we could definitely see the equivalent for the FF! In fact there's already a 24mm F/2.0, just a hair faster than the Fuji.
The K-mount is definitely too large for the APS-C sensor, sure.
08-07-2014, 03:55 PM - 1 Like   #488
Mistral75's Avatar
Digital sensors need lenses of telecentric design, i.e.that ensure low, image-sided, raypath angles. Digital sensors do not 'like' sharp incidence angles of the rays at the edge of the image, which cause vignetting, blur (because of crosstalk) and colour shifts (usually magenta colour shift).
A retrofocus design is an example of quasi-telecentric design.
08-07-2014, 04:19 PM   #489
QuoteOriginally posted by Mistral75 Quote
And a lot of the reason mirrorless lenses aren't really all-that-much smaller or lighter than DSLR lenses.
The camera is lighter, sure.
08-07-2014, 04:37 PM   #490
Aristophanes's Avatar
The advantage of mirrorless it that the retrofocus design get less extreme with shorter register distance, so they require less glass than comparable DSLR lenses. So for mirrorless it's possible to design wider and faster wide angle lenses without them requiring extreme amount of glass. DSLR with APS-C sensor have the biggest disadvantage as it use the same register distance as FF DSLR.
That said the current DSLR corps excels at telephoto lenses.
DSLR + PDAF + telephoto = market
08-07-2014, 04:38 PM   #491
QuoteOriginally posted by ElJamoquio Quote
Samyang 14mm F/2.8, K-mount: 530g.
Samyang 12mm F/2, X-mount: 260g.
Faster, wider, and half the weight...
08-07-2014, 05:17 PM   #492
QuoteOriginally posted by Doundounba Quote
The 14mm is a full frame lens. Samyang hasn't designed a sub-530gram, 9mm F/1.8 lens for APS-C.
So, on the cameras it was designed for, the 14mm is faster + far, far wider. The difference between 9mm and 12mm is huge!
08-07-2014, 06:36 PM   #493
Pål Jensen's Avatar
Neither a 2.8 lens or a 2 lens is an 1.8 lens.
Aperture is not defined from DOF but from exposure. Ie the amount of light reaching the sensor/film.The aperture is proportional to the square root of the light admitted, and thus inversely proportional to the square root of required exposure time, such that an aperture of f/2 allows for exposure times one quarter that of f/4.
08-07-2014, 06:58 PM   #494
I can take the same pictures with a 14mm F/2.8 lens on a FF camera that I can on a 9mm F/1.8 lens on a APS-C camera. Same exposure time and everything. It's amazing, except that it's just equivalence and it just works.
Honestly if you're trying to convince me you're wasting keystrokes. I have different format cameras. Equivalence works.
I maintain that there's not much difference in weight of MILC lenses compared to DSLR.
08-07-2014, 07:03 PM   #495
clackers's Avatar
Thanks for the explanation, Mistral!
---------- Post added 08-08-14 at 12:05 PM ----------
Well, the Fuji wide angles are smaller and lighter, EJ, it was pointed out in another thread, because of the short registration distance.
The teles are presumably harder to engineer.
---------- Post added 08-08-14 at 12:07 PM ----------
I think the actual definition is the ratio of focal length to aperture diameter, Pal, rather than DoF or exposure.
645z, anniversary, body, canon, cif, dslr, ff, focus, hood, hoya, jp, lens, lenses, line, market, mf, nikon, pentax, pentax news, pentax rumors, photokina, post, pre-orders, release, ricoh, rumors, stock, train
Photokina 2014 - FF Tesla Pentax Full Frame 797 11-14-2014 11:14 PM
Official PF Photokina Meetup Adam Travel, Events, and Groups 42 09-26-2012 11:33 AM
Photokina interview larkis Pentax Medium Format 5 09-22-2012 04:36 PM
Photokina price drop? Dynasty Pentax DSLR Discussion 10 08-21-2012 04:27 PM
Predict Pentax Photokina Announcements selar Photographic Industry and Professionals 72 08-20-2012 04:04 PM
All times are GMT -7. The time now is 05:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
