08-13-2014, 06:04 AM - 1 Like   #661
thibs's Avatar
You won't finish this ever both of you, will you?
08-13-2014, 06:05 AM   #662
Class A's Avatar
True, ClassA, but now you are talking about the sensor.
I'm talking about the light that goes to waste on the smaller format.
The speed (f rating) is the ratio of how many mm wide a lens opens to its focal length.
Yes, an "f/4" lens remains an "f/4" lens on all formats. Just like it retains its focal length on all formats.
All I'm saying is that it is not helpful to regard an "f/4" lens on a Q to be as "fast" as an "f/4" lens on FF, with "fast" having the connotation of "being a very good light gatherer". The obtained exposure is the same, but "exposure" is not an indicator for image quality across format sizes (because total light matters, not candela/mm^2).
You probably wouldn't call an "8.5mm f/1.8" lens on a Q "wide" and I'm saying it shouldn't be called "fast" either.
There is no other consideration - same calculation for the Q as the 645Z.
Correct.
I'm not trying to redefine how the widest f-stop of a lens is calculated, I'm just trying to bring perspective to how different the meaning of the same numbers is for different formats.
08-13-2014, 06:13 AM   #663
GlassJunkie's Avatar
I guess I'll chime in now...
The F stop (ratio of objective diameter to focal length) is a static ratio, not affected by format (which is the optical target where the inverted image is cast). A 200mm F4 is a 200mm F4 regardless of whether it is put on a POS sensor, 4/3, APSc, FF, MF, or view camera. It casts the same light circle, hence the Contax-Zeiss view in the late 90s (great idea but derailed by the digital sensor train hitting it). F stop ratio is an inverted measure of "lens speed" which is still the classic term used in many optical engineering shops that look at exposure times.
The light circle is diffused the wider it is cast, and the angle of it hitting sensors or film is made more acute at the extremes. The smaller sensor "crops" but gets a higher quality light source due to less surface diffraction. Most sensors are designed with this in mind.
There is an effect on the extremes of larger sensors, but it is more to the negative than the positive. The FF argument "Larger is better" or a 24mpFF is better than a 24mp APSc, is the most ridiculous argument I have seen on this site (not this thread or the respondents). Anyone that takes that position is demonstrating their total lack of knowledge and ignorance... Simple. At 36x24mm sensor one needs 51mp to match the IQ of a 24mp APSc. Whew...
08-13-2014, 06:20 AM   #664
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by GlassJunkie Quote
The picture you look at on a screen or print and put in a frame is the same size, though, and one would be rendered from 51mp, the other from only 24 ....
08-13-2014, 06:27 AM   #665
D1N0's Avatar
Not simple. 24mp ff demands less resolving power from your lens. Each pixel will receive about a stop more light on ff 24mp. Aberrations will also be roughly half the size on FF on the same viewing size. Large pixel density is not a pro, it's a con.
DOF is preference bound so i won't talk about that.
08-13-2014, 06:32 AM   #666
Yes, and the attendant lost of resolution occurs, unless the image is magnified by some type of fractal manipulation. You are spot on...
08-13-2014, 06:35 AM - 1 Like   #667
Well, I have to say, after trying to keep up with this thread for a while, I just want Photokina to actually happen so we can at least reduce the flow of endless speculation and opinion by a notch or two...
08-13-2014, 06:36 AM   #668
clackers's Avatar
Disturbing answer, GJ.
You do realise that to get to that same size you're pushing the pixels apart twice as far in the APS-C image as the FF one, right?
08-13-2014, 06:37 AM - 1 Like   #669
Aristophanes's Avatar
Unless the optics are also designed to project a smaller image circle.
That's relative.
Again, relative.
Relative. On the Q sensor that is, indeed, fast.
The meaning is identical. If one number changes—sensor size—then it becomes relative.
QuoteOriginally posted by D1N0 Quote
Nope. It's a con for ISO relativity and a pro for cropping and editing. The quality of data points is proportionate to the quantity.
Relative.
08-13-2014, 06:42 AM   #670
Agree with your comment on aberrations, although they will be re-magnified on re-expansion of the image to make up for resolution. Algorithms can deal with the CA issue since it is not scalar more effectively than fractally making up for lost resolution.
The extra light may be desired, but IMHO not with the related overheads (refection in the box, diffraction, weight of equipment required to support the sensor class (how many birders want to lug 800-900mm in the field to shoot flying birds?
100% agree with your DOF comment. Faster lens speed (For you Pal ) or larger apertures provide different bokeh.
---------- Post added 08-13-14 at 09:48 AM ----------
I am not sure I am understanding "pushing the pixels twice as far"... Can you give me more color on it? THX
08-13-2014, 07:22 AM - 1 Like   #671
I'll get back to reading this thread once discussion about Photokina starts again..
08-13-2014, 09:09 AM   #672
QuoteOriginally posted by Pål Jensen Quote
This is not the same as equivalent speed. Equivalent speed gives equivalent exposure by definition. Equivalent DOF do not.
"Equivalency" compensate rigidly this reduction in light by boosting the ISO correspondingly. However, no photographer respond to light reduction by boosting ISO exclusively. Hence, it is no law but an option.
So, your argument is, because no law REQUIRES you to make the same image, that it provides no benefit to compare the capabilities of making the same image?
08-13-2014, 09:52 AM   #673
boriscleto's Avatar
QuoteOriginally posted by Alizarine Quote
So sometime in mid-September?
I was thinking maybe we can make this thread about cheese sandwiches.
08-13-2014, 10:07 AM   #674
So Back to Photokina
Anybody want to take a guess at which models from Nikon, Canon, Sony, and Olympus will not be on the floor? Also, what adapters if any for the Ricoh Gs?
08-13-2014, 10:24 AM   #675
D1N0's Avatar
Nikon F4, Sony A580, Olympus E-410 . What's a Ricoh Gs?
645z, anniversary, body, canon, cif, dslr, ff, focus, hood, hoya, jp, lens, lenses, line, market, mf, nikon, pentax, pentax news, pentax rumors, photokina, post, pre-orders, release, ricoh, rumors, stock, train
Photokina 2014 - FF Tesla Pentax Full Frame 797 11-14-2014 11:14 PM
Official PF Photokina Meetup Adam Travel, Events, and Groups 42 09-26-2012 11:33 AM
Photokina interview larkis Pentax Medium Format 5 09-22-2012 04:36 PM
Photokina price drop? Dynasty Pentax DSLR Discussion 10 08-21-2012 04:27 PM
Predict Pentax Photokina Announcements selar Photographic Industry and Professionals 72 08-20-2012 04:04 PM
All times are GMT -7. The time now is 08:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
