07-30-2014, 12:25 AM - 1 Like   #16
QuoteOriginally posted by vagrant10 Quote
so what do you think that second wheel in the front is?
Its for filling up with orange juice on a hot day out.
How thoughtful!
07-30-2014, 01:31 AM   #17
QuoteOriginally posted by MD Optofonik Quote
Hmmm. Sexy. Still no fast wide prime. Still no viewfinder (I know, we can all mostly live without it).<br />
<a href="https://translate.google.com/translate?sl=auto&amp;tl=en&amp;js=y&amp;prev=_t&amp;hl=en&amp;ie=UTF-8&amp;u=http%3A%2F%2Fdigicame-info.com%2F2014%2F07%2Fpentax-q2.html&amp;edit-text=&amp;act=url" target="_blank"><br />
This should be interesting.</a>
<br />
<br />
A viewfinder just makes it a bigger camera so might as well be a different model range. <br />
The q is a q because of its size. <br />
J
07-30-2014, 02:36 AM   #18
Looks nice to me, but if this one's gonna be mag-alloy too, then will it also launch at the original Q's launch price?
07-30-2014, 02:58 AM   #19
raider's Avatar
Looks good. I hope the price is ressonable
07-30-2014, 03:18 AM   #20
VisualDarkness's Avatar
Hopefully they go back to the metal that makes the Q so prestigious (see what I did there?) feeling. I have a feeling that this pseudo-Leica with angular top shapes with gun-metal looks will be seen in a lot of the coming Pentax models.
07-30-2014, 03:27 AM   #21
i83N's Avatar
Practical question; how to calculate image circle?
07-30-2014, 03:57 AM   #22
Mistral75's Avatar
QuoteOriginally posted by i83N Quote
Of a lens? You calculate it like its other optical properties when you design the lens (you rather use it as an input parameter) and you measure it on an actual copy: lens focused on infinite, illuminated by a far source, you measure the diameter of the luminous circle on a support placed at register distance.
07-30-2014, 04:05 AM   #23
i83N's Avatar
QuoteOriginally posted by Mistral75 Quote
I mean not at design moment, but at the end user.
07-30-2014, 04:07 AM   #24
Mistral75's Avatar
I have answered both.
07-30-2014, 07:10 AM - 1 Like   #25
Banned
Well to be expected....looks good.
07-30-2014, 07:18 AM   #26
D1N0's Avatar
No more grip but a clip?
07-30-2014, 07:46 AM   #27
Caat's Avatar
The other 'thing' on the front looks a lot like a large button - which might be able to be operated using the middle finger. Although I can't really think why it would be necessary.
Without seeing the back it's not really possible to say if there might or might not be provision for an optional viewfinder.
07-30-2014, 08:11 AM   #28
Glad to see the Q replacement leaked this early. I was getting worried that the Q replacement was being saved for Photokina as the big Pentax announcement.
07-30-2014, 09:48 AM   #29
Biro's Avatar
I don't believe the inclusion of an EVF would necessarily make the Q larger. Look at what Panasonic has done with the LF1, which has the same-sized sensor as the Q7. Frankly, even if it was a low-res EVF (like the LF1 has), it would still make a huge difference when working in bright sunlight. I wouldn't be worried about manual focus in this kind of situation. Of course, if it was even a mid-res resolution EVF (say, 1 million dots?) that would be great.
07-30-2014, 09:55 AM - 1 Like   #30
crewl1's Avatar
QuoteOriginally posted by Alizarine Quote
I suspect this will be plastic, based on the silver lugs in the pictures and because I don't think they will make the mistake again as they now know they can't get $800 for one.
5-15mm, auto, build quality, cameras, distance, dslr, fps, lenses, line, pentax, pentax news, pentax rumors, q2, quality, ricoh, screen, sensor, sensor size, spec, sr, tv
Rumour: New Q with larger sensor JPT Pentax News and Rumors 217 06-18-2013 12:52 AM
Re-cycling another Pentax FF rumour/FF rumor from A German photography magazine rawr Pentax Full Frame 73 09-19-2012 01:12 PM
Pentax full frame rumour schufosi777 Pentax Full Frame 1039 09-04-2012 01:03 AM
Will this be the Q2 sensor? Unsinkable II Pentax Q 3 08-21-2012 01:24 AM
Q Mini Review - Hoping for a Q2 deanm3 Pentax Q 38 09-21-2011 09:30 PM
All times are GMT -7. The time now is 04:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
