07-31-2014, 05:40 AM   #61
cxdoo's Avatar
Does it say anywhere that the bump on the front right is actually a knob? Maybe it's a connector for a grip or something?
07-31-2014, 05:45 AM   #62
QuoteOriginally posted by JPT Quote
The circular thing on the front is not a logical shape for a grip, too big for an IR sensor and has no kind of grip to be turned like a dial.
Crazy suggestion - Could it be a small touch pad control?
My bet is: it's a second shutter button. Check out the finish on the top-panel shutter button; it has the exact same black inlay as the button that appears on the front. Maybe an effort to address some of the criticisms about the Q's ergonomics?
07-31-2014, 05:52 AM   #63
i83N's Avatar
It's a wifi antena
07-31-2014, 06:10 AM   #64
VisualDarkness's Avatar
I think it's just a second control wheel, nothing less and nothing more.
07-31-2014, 06:10 AM   #65
Na Horuk's Avatar
ooh wait, is Pentax going to have two lines of Q cameras now? Maybe this isn't a Q7 replacement, but an addition. Just like the Q lenses come in two types, the "high performance" and the "toy", maybe now there will also be two bodies. One a cheaper, plastic body; and the other a metal, more expensive body (S line). But I do wonder what features will separate the two. Cosmetics is not enough
07-31-2014, 06:20 AM - 1 Like   #66
bluefoam's Avatar
Heres my guess...
The weird knob on the front has a relatively contemporary finish (as opposed to the retro finish on the rest of the camera), so I believe it is for a new technology... I think 1) it contains the wifi antenna, 2) is a quick press button to link/share photos with your phone
07-31-2014, 06:33 AM - 1 Like   #67
konraDarnok's Avatar
No SR emblem. Is that how they fit a 1" sensor in?
07-31-2014, 06:37 AM - 1 Like   #68
Maybe that second button on the front is a cover for a tiny screen used to compose selfies? Nah, I doubt it. How about an attachment port for some type of Rube Goldberg articulating EVF? Probably not. I'll go with a new grip attachment point.
07-31-2014, 06:38 AM   #69
teignmouthpentaxguy's Avatar
the top down shot gives a better view of the new 'knob' - More Pentax Q-S1 photos show up ahead of its launch | Camyx (maybe the S1 name stands for a square sensor! I'm joking btw)
07-31-2014, 06:39 AM   #70
D1N0's Avatar
I still think it's a clip on attachment. Maybe the will come with a belt clip. The alternative is a water release button to spray your unsuspecting subjects.
07-31-2014, 06:40 AM   #71
monochrome's Avatar
QuoteOriginally posted by konraDarnok Quote
I'm not sure SR does anything meaningful on any of my Q's. Maybe not having the mechanism opens internal space and eliminates a costly assembly.
07-31-2014, 06:55 AM   #72
I'm sure it's cheaper to leave out the SR, but it's been effective in my experience. I'd be kinda disappointed to see it left out.
07-31-2014, 07:03 AM   #73
I bet the 'black' area on the new knob is the IR remote receiver. It is in the same spot as on previous models.
Question is if it has any additional functions?
Looks quite different from the opposite quick dial in the top view, but if it had a turning function it should look more similar.
hkan
07-31-2014, 07:27 AM - 1 Like   #74
Mistral75's Avatar
In Q-S1, the S is for Selfies.
The "circular thing in the front" is a cap that protects a mirror that assists in framing selfies (no swivel back LCD for the sake of thinness).
07-31-2014, 08:16 AM   #75
Interesting, the second knob doesn't look like a second dial any more from the top view since there's no texture to it for easier turning. The dark part is probably because IR is inside. I'm starting to think S means Simple, without SR.
5-15mm, auto, build quality, cameras, distance, dslr, fps, lenses, line, pentax, pentax news, pentax rumors, q2, quality, ricoh, screen, sensor, sensor size, spec, sr, tv
Rumour: New Q with larger sensor JPT Pentax News and Rumors 217 06-18-2013 12:52 AM
Re-cycling another Pentax FF rumour/FF rumor from A German photography magazine rawr Pentax Full Frame 73 09-19-2012 01:12 PM
Pentax full frame rumour schufosi777 Pentax Full Frame 1039 09-04-2012 01:03 AM
Will this be the Q2 sensor? Unsinkable II Pentax Q 3 08-21-2012 01:24 AM
Q Mini Review - Hoping for a Q2 deanm3 Pentax Q 38 09-21-2011 09:30 PM
All times are GMT -7. The time now is 04:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
