08-20-2014, 11:25 AM   #316
ghl
QuoteOriginally posted by RonHendriks1966 Quote
But you can combine it with bracketing
This is true, it just seemed a strange omission when I first encountered it.
08-20-2014, 11:27 AM   #317
konraDarnok's Avatar
Specs of PENTAX K-S1
- 20MP APS-C CMOS sensor
- LCD monitor 3 inches 921 000 dots. Aspect ratio is 3: 2. Touch panel is not mounted.
- ISO100-51200
- Video 1920 x 1080,30fps, stereo
- Built-in camera shake correction
- The battery D-LI109
- 120mm x 92.5mm x 69.5mm size
So it's the Pentax Sony A3000?
08-20-2014, 11:28 AM   #318
jcdoss's Avatar
Mistral, are those creations of yours? The gray one is awful, but the white one is pretty slick. I always thought Pentax had a good idea with their plethora of color schemes you get your camera in. The dark burgundy K30s were quite attractive, as were the dark metallic green ones.
08-20-2014, 11:34 AM   #319
The specs and the images are from PENTAX K-S1???????????????????? - ????info - I suppose.
Not bad, for an entry level - and it even has some of the K-3 goodies
08-20-2014, 11:34 AM   #320
Otis Memorial Pentaxian
QuoteOriginally posted by Fogel70 Quote
I don't see a major difference in size compared to the standard K10D.
Looking at this picture I even looks like the prism bump on the anniversary model is higher than K10D with built in flash.
BTW is the anniversary model a fully working camera, or is it only a mockup?
I probably should not have used the anniversary model as an example. Any of a number of film SLRs would have worked better.* This page shows how the space is allocated:
Pentax K-30 vs K-5 IIs Cross Sections - Photokina 2012 - Pentax News & Photo Resources
To see the impact of the flash, simply flip it up and imagine it gone.
Here is a photo lifted from photographybanzai.com showing the K-7 with top cover removed. Yes, the prism is the little pointy black thing.
* FWIW, the prism housing has been used as sort of a catch-all space for a long time. On a couple of my film cameras, the prism itself is flanked by integrated circuit modules.
08-20-2014, 11:36 AM   #321
Definitely picking up the white one when it's cheap just for collection purpose, lol. Curious to see what other 10 colors are like.
08-20-2014, 11:41 AM   #322
Mistral75's Avatar
QuoteOriginally posted by jcdoss Quote
Mistral, are those creations of yours? (...)
No, they aren't.
QuoteOriginally posted by Mistral75 Quote
A few specifications, courtesy of Digital Camera Info Image of White & gray body and spec of PENTAX K-S1 - Digital Camera Info
08-20-2014, 11:43 AM   #323
Na Horuk's Avatar
The white one looks pretty good, even though its no longer the panda stormtrooper scheme. The grey one.. would look okay if the lens would also be a fitting grey
So, how is that Sony a3000 sensor? Does it beat the 16MP one in the K-01, K-30, K-5 in anything other than resolution?
08-20-2014, 11:56 AM   #324
I am always, very much, in love with everything in the color of green. For instance green diodes, like this camera seem to have lot of.
08-20-2014, 11:56 AM   #325
Unregistered User
Guest
I wonder if it could be the Samsung sensor...sold dirt cheap to Pentax.
08-20-2014, 12:00 PM   #326
QuoteOriginally posted by ruggiex Quote
I am curious about the light grey lens grip.
08-20-2014, 12:02 PM   #327
Banned
The sensors score the same on DxO, so that will be good.
The camera is bigger then the Canon Rebel SL1
08-20-2014, 12:08 PM   #328
Fogel70's Avatar
Yes, I posted this link a few pages back. Which you then made a comment on.
But you still need the other parts like AF point display and light meter in the prism housing. The flash usually use some of the empty space between the other parts that takes up space in the prism housing. The hot shoe it usually the highest part of the camera and it sits on top of the light meter. So removing the flash will only cut off some of the front part of the prisma housing, but not make any major difference of size on the camera.
08-20-2014, 12:08 PM   #329
Mistral75's Avatar
QuoteOriginally posted by DominicVII Quote
It's more presumably a Sony sensor, the one you find in Alpha 3000, but with a boosted ISO range.
http://www.dpreview.com/products/sony/slrs/sony_a3000
08-20-2014, 12:12 PM   #330
Banned
That is also a good enough sensor for entry level.
af, camera, care, colour, design, ff, flash, format, iso, k-01, k-3, k3, kit, kit lens, leds, lens, level, look, medium, pentax, pentax k-s1, pentax news, pentax rumors, performance, price, scheme, steve, value
Some Thoughts on the K-01 and Mirrorless From Pentax Biro Pentax Mirrorless Cameras 108 06-25-2014 03:20 PM
Mirrorless K-Mount Camera Joshua A Photographic Industry and Professionals 12 08-22-2013 04:28 AM
K-mount mirrorless....FF RonHendriks1966 Pentax Full Frame 13 05-28-2013 03:13 PM
Waiting on my first mirrorless: K-01! Penta Welcomes and Introductions 2 01-30-2013 05:49 AM
New Pentax: K-5, K-r and Mirrorless models coming JohnBee Pentax News and Rumors 32 08-08-2010 01:57 AM
All times are GMT -7. The time now is 04:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
