09-16-2014, 03:30 AM   #166
bossa's Avatar
QuoteOriginally posted by elpolodiablo Quote
With the bulk of the 70-200 I am guessing it's a constant f2.8, wonder what those switches are for though, 1 is for AF/MF as per existing DA* lenses, what's the other one for? OIS? Focus Limiter?
As for the 100-450, again 2 switches on the left hand side of the lens, same question as above, but what looks like a focus lock on the right so it's not a IF lens.
And crucially, how's the optical performance stack up against offering from other manufacturer
The 70-200 is probably a FF lens so I'd expect one of the switches to be an OS activation switch.
09-16-2014, 03:30 AM   #167
VisualDarkness's Avatar
QuoteOriginally posted by D1N0 Quote
Let's hope that Pentax will accomodate lens sr as well als ibis. For long lenses in lens stabilisation is better. So just turn of sr when detecting a stabilized lens. You would have the best of both worlds and Tamron/Sigma wouldn't have to omit it from their lenses for Pentax any more. When really adventurous they could even try to combine lens and body sr, for super stabilisation.
The problem is that it would most likely end up atleast 30% more expensive and slightly heavier, both enought to scare away enough buyers to do more harm than good.
09-16-2014, 03:39 AM - 1 Like   #168
Cynog Ap Brychan's Avatar
I know the debate has moved on a little from the 16-85mm, but I still want my two-penn'orth. If it is offered as a kit zoom, and is priced between the 18-55 and the 18-135, I think it makes quite a lot of sense. It is quiet, so maybe it can get rid of reviewers' perennial whine about the whine.... (sorry). Also, 24mm equivalent FoV is the new 28: I certainly find 16mm much more useful than 18mm for my photography. Finally, although it is relatively slow, is this such a big deal for most people, especially ones who maybe never buy a second lens? With ISO on Auto, and good performance up to 3200, f5.6 is not such a bad deal for general use, especially outdoors, where its weather sealing comes to the fore. I just hope it is not priced too close to the 18-135, and is a bit better optically.
09-16-2014, 03:40 AM   #169
Franc's Avatar
QuoteOriginally posted by VisualDarkness Quote
if the IQ is execptional i don't mind the extra price, so are others
09-16-2014, 03:42 AM   #170
In generell those 16-85 lenses are more expensive as the 18-135, look at Nikon or Canon. I hope this is an optically better option as the 18-135!
09-16-2014, 03:42 AM   #171
Paul the Sunman's Avatar
It doesn't work. Saw a video a few years ago using Olympus. With stabilization on in both body and lens, the shake went wild. They were each interfering with each other.
09-16-2014, 03:43 AM   #172
Digitalis's Avatar
QuoteOriginally posted by bossa Quote
As for the 100-450, again 2 switches on the left hand side of the lens, same question as above, but what looks like a focus lock on the right so it's not a IF lens. And crucially, how's the optical performance stack up against offering from other manufacturer
I call dibs on the first 100-450mm in Australia... My sigma 100-300mm f/4 that does not have a focus limiter has been really bugging me lately.
09-16-2014, 03:45 AM   #173
Otis Memorial Pentaxian
RobG's Avatar
QuoteOriginally posted by Asahiflex Quote
The middle big lens (the ~450mm one) seems to be of the IF (Internal Focusing) type. So easy to make it fully weather resistant (the gold ring). The third one, the 70-200mm version, is not and that's why there's a zoom lock on it.
But the 16-85 is clearly labelled WR. Isn't the gold ring a hint of a * lens?
09-16-2014, 03:48 AM   #174
QuoteOriginally posted by Cynog Ap Brychan Quote
Other way to see it is that DA 18-135 is too pricey for what it brings.
I was hoping this 16-85 could be a f2.8-4 to be a flagship kitlens for K3 and upcoming APSC body but from what we know now I only see it as a useful replacement of 18-55.
I do not see this 2mm difference between 16 and 18 a big enough argument to compete against perfect walkround lens that is 18-135
09-16-2014, 03:50 AM   #175
Mistral75's Avatar
The High Magnification Super Zoom / Tele Zoom : http://news.ricoh-imaging.co.jp/rim_info/3_telephotozoomlens_photokina2014.jpg seems to have four buttons:
- zoom lock on top (in the picture below)
- focus lock in the middle (the round one)
- AF/MF switch and focus limiter on the bottom.
---------- Post added 09-16-2014 at 12:53 PM ----------
QuoteOriginally posted by RobG Quote
Indeed, the lens below is the Large Diameter Zoom / * Tele Zoom http://news.ricoh-imaging.co.jp/rim_info/2_telephotozoomlens_photokina2014.jpg.
09-16-2014, 03:55 AM - 1 Like   #176
Sandy Hancock's Avatar
QuoteOriginally posted by fsge Quote
Seriously? On APS-C, the difference between 16 and 18 is *big*. Especially as the 18-135 isn't too strong at the long end.
09-16-2014, 03:56 AM   #177
D1N0's Avatar
QuoteOriginally posted by Paul the Sunman Quote
It doesn't work because both systems don't know about each other. So the sensor goes hay wire. You'd have to make them act as one system of sr. But an automatic or selectable sr-choice (in body in lens or neither) would also be fine.
09-16-2014, 03:58 AM   #178
pjalves's Avatar
I've posted this on "front page" but it's still «pending approval», so I'll re-post here (also on DPR):
16-85 vs 18-135 size comparision
side-by-side
09-16-2014, 04:00 AM   #179
QuoteOriginally posted by Mistral75 Quote
PentaxIsDoomed™ , as many say. The corporate grim reaper on the other hand, seems to have left Pentax's doorstep again.
It's not big as in huge, but a very useful extension. Probably around 10 degrees or more FOV. I think it's a welcome feature. But I wonder why the name is still "tentative" -- what else can be added (or omitted) in this lens' name? (Still hoping for it to be 3.5-4.5 aperture max aperture!)
09-16-2014, 04:04 AM   #180
JinDesu's Avatar
That large diameter telephoto looks gorgeous to me. When it comes out, I might have the ability to just buy it outright.
16-85mm f3.5-5.6ed dc, a.k.a, aps-c, button, camera, competition, dc, drive, ff, focus, glass, hd, hd pentax-da 16-85mm, image, length, lens, lenses, mount, pentax news, pentax rumors, pentax-da, release, sigma, sr, tamron, tele, w/a, wr
For Sale - Sold: SMC Pentax-DA 18-135mm f3.5-5.6 ED AL (IF) DC WR sholtzma Sold Items 2 02-05-2014 01:11 PM
For Sale - Sold: Pentax-DA 18-135mm F3.5-5.6 ED AL [IF] DC WR - reduced price tjwaung Sold Items 8 12-21-2013 05:56 AM
new smc PENTAX-DA 18-135mm F3.5-5.6ED AL [IF] WR DC KeesdH Pentax News and Rumors 227 06-22-2011 03:57 AM
PENTAX-DA 18-135mm F3.5-5.6ED AL [IF] WR D Fl_Gulfer Pentax News and Rumors 20 11-26-2010 05:13 PM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
