Show Printable Version 123 Likes Search this Thread
09-16-2014, 08:57 AM   #256
QuoteOriginally posted by Mistral75 Quote
Indeed but unfortunately the patented lens is shorter .
Sorry, I am actually looking at a different patent to you -_-, here the link to the one I'm looking at (Pentax patent for a 70-200mm f/2.8 lens | Photo Rumors)
Pentax filed a patent 2012-189817 in Japan for a 70-200mm f/2.8 lens:
  • Patent filing date: October 3, 2010
  • Zoom ratio: 2.82
  • Aperture: 2.9 - 3.0
  • Focal length: 70.21 - 198.32mm
  • Image height: 21.64mm
  • Lens length: 296.16mm
  • 17 images lens group configuration 14
  • 4 ED elements
  • 2 low-dispersion elements
  • Internal zoom and f focusing
09-16-2014, 08:58 AM   #257
cali92rs's Avatar
Those two big @ss lenses gotta be FF lenses in my opinion. They are not the compact lenses that PRIC have been releasing for the APS-C line for some time now.
09-16-2014, 09:00 AM   #258
normhead's Avatar
Notice the image height... 21.64.. that's not enough for a FF, you'd need almost 24mm. If that's the lens they just released, it's not for a Full Frame. It is big enough for APS-c with shake reduction, with room to spare.
09-16-2014, 09:02 AM   #259
Notice the image height... 21.64.. that's not enough for a FF, you'd need almost 24mm. If that's the lens they just released, i's not for a Full Frame.
Isn't that 21.64mm measurement actually the radius of the circle of enlightenment (as in, the radius of light projected by the lens. If so, it is more than large enough for full frame coverage. Correct me if I am wrong though, information is power.
09-16-2014, 09:02 AM   #260
Mistral75's Avatar
QuoteOriginally posted by D1N0 Quote
Just be clear Mistral. What are you saying? This is not a 70-200? Or it is not full frame or there will never be a full frame?
(deep breath...)
I am saying
the patent some here are referring to and/or have provided a (direct or indirect) link to
and which includes embodiments that describe 22 to 30cm-long 70-200mm or 70-210mm f/2,8 lenses for 24x36 sensors
also includes embodiments that describe 15-45mm f/2.8 lenses for 1/1.7" sensors
and happens to be the patent of Pentax Q's 06 Telephoto Zoom 15-45 mm f/2.8.
I am saying
one won't ever hear about this patent in the context of an actually produced 70-200mm f/2.8 24x36 lens. The corresponding embodiments are mere red herrings put into the patent for camouflage purposes.
(exhale... inhale again... pulse back to normal...)
When time comes and Ricoh launch their 70-200ish lens a.k.a. * Tele Zoom a.k.a. Large Diameter Zoom, this lens will correspond to a totally different patent, yet to be published/spotted.
09-16-2014, 09:03 AM   #261
I completely agree with this assessment. If they did release the patented lens it would simply be too massive to be competitive in my opinion.
---------- Post added 09-17-14 at 01:36 AM ----------
Also, when I compared the telezoom to lenses of know quantities (in this case, the 18-135mm), the lens was simply too small to be of the same design.
09-16-2014, 09:07 AM   #262
Mistral75's Avatar
QuoteOriginally posted by Joshua A Quote
It's the same patent, follow the link within the message from Photo Rumors:
Pentax 70-200mm F2.8 ?????????????So-net???
and read
実施例3 [embodiment #3]
ズーム比 2.83
FNO. 2.9
焦点距離 f=15.45 - 26.01 - 43.65mm
半画角 W=17.4 - 10.1 - 6.0°
像高 Y=4.65
fB 0.53mm
全長 L=73.00mm
レンズ構成 14群17枚
スーパーEDガラス 1枚
EDガラス 2枚
低分散ガラス 3枚
正負正正の4群ズーム
Of course in the same patent there is also embodiment #5
実施例5
ズーム比 2.82
FNO. 2.9 - 3.0 - 2.9
焦点距離 f=70.21 - 118.15 - 198.32mm
半画角 W=17.8 - 10.4 - 6.1°
像高 Y=21.64mm
fB 2.49mm
全長 L=296.16
レンズ構成 14群17枚
EDガラス 4枚
低分散ガラス 2枚
正正負正正の5群ズーム
09-16-2014, 09:09 AM   #263
This is the patent (or part of the patent I guess) that I was referring to. Sorry if I've frustrated you in anyway, I don't mean to start a flame war over nothing serious.
09-16-2014, 09:11 AM - 1 Like   #264
Mistral75's Avatar
Yes it is. Image height = radius. Diameter = Image height x 2 = 43.28
Sqrt (24^2 + 36^2) = 43.27
09-16-2014, 09:14 AM   #265
Yes it is; Image height = radius. Diameter = Image height x 2 = 43.28 Sqrt (24^2 + 36^2) = 43.27
I thought so, but it is nice to have someone with more knowledge on that matter confirm that I had the right idea in the first place.
09-16-2014, 09:16 AM   #266
Mistral75's Avatar
Don't be sorry! It's just that manufacturers do not simply patent an optical formula, they indicate a purpose (how to improve such and such characteristics of existing lenses) and the way to obtain such improvements and they illustrate their statements with examples of optical formulas, also called embodiments.
Among this embodiments is carefully hidden the actual optical formula of a future lens; most of the other embodiments, if not all, are just red herrings.
09-16-2014, 09:17 AM   #267
angus's Avatar
QuoteOriginally posted by Snappertim Quote
... now the first of the other lens is a rebadged Tokina 70 200 f4 the size is exactly right, its large enough to be full frame but not large enough to be f2.8, ... now the second lens probaly a version of tokina's 80-400 about the same size...
Just look at the lens caps in relation to the front bit - no way is the bigger one the same size as a Tokina 80-400, I had/have one (it's broken) and it is a comparably small lens. I mentioned above that the front diameter of the smaller of the two lenses seems likely to be at 77mm - too big for f4 and what would be the use of a f4 when you have 60-250/4 already?
09-16-2014, 09:20 AM   #268
Don't be sorry! It's just that manufacturers do not simply patent an optical formula, they indicate a purpose (how to improve such and such characteristics of existing lenses) and the way to obtain such improvements and they illustrate their statements with examples of optical formulas, also called embodiments. Among this embodiments is carefully hidden the actual optical formula of a future lens; most of the other embodiments, if not all, are just red herrings.
All I'm going to say is that you can never be too careful on a forum, though this one seems to be one of the best around in the regard of members not holding grudges.
Also, it's smart on a corporate level for Ricoh to do all this patenting of stuff they'll never release, but it'd be nice to have a more informative road map or some more indicators of what is to come, lens wise that is.
09-16-2014, 09:26 AM   #269
ogl
Banned
QuoteOriginally posted by boriscleto Quote
the fa 28-200, da 18-250 & da 18-270.
fa 28-105/4-5.6 [if]
09-16-2014, 09:54 AM   #270
QuoteOriginally posted by angus Quote
Yes OK its hard to see what size a object is when you can only see it against other objects the size of which you also do not know, but even if its not the same lens its DNA looks similar, on the larger lens the zoom lock switch is a clear clue as to its origins, the smaller is a rebadged Tokina 70-200 f4 for sure, and the reason for the larger lens is Full Frame the 60-250 is only APSC, and the future is full frame, Sony has just stated it intends to have 20 full frame lens on the market in a few years, maybe the have come to the conclusion if you want to be number one you have to do what the guy at number one is doing Nikon!!
16-85mm f3.5-5.6ed dc, a.k.a, aps-c, button, camera, competition, dc, drive, ff, focus, glass, hd, hd pentax-da 16-85mm, image, length, lens, lenses, mount, pentax news, pentax rumors, pentax-da, release, sigma, sr, tamron, tele, w/a, wr
For Sale - Sold: SMC Pentax-DA 18-135mm f3.5-5.6 ED AL (IF) DC WR sholtzma Sold Items 2 02-05-2014 01:11 PM
For Sale - Sold: Pentax-DA 18-135mm F3.5-5.6 ED AL [IF] DC WR - reduced price tjwaung Sold Items 8 12-21-2013 05:56 AM
new smc PENTAX-DA 18-135mm F3.5-5.6ED AL [IF] WR DC KeesdH Pentax News and Rumors 227 06-22-2011 03:57 AM
PENTAX-DA 18-135mm F3.5-5.6ED AL [IF] WR D Fl_Gulfer Pentax News and Rumors 20 11-26-2010 05:13 PM
All times are GMT -7. The time now is 06:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
