11-28-2014, 09:48 AM   #646
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
QuoteOriginally posted by Mistral75 Quote
You're welcome.
Considering their protocol "The principal idea is to take the AF focus distance as a rough guidance and do several manual focus iterations within a radius of roughly +/-20% around the suggested focus distance. The images with the highest resolution are then analyzed and presented in the final MTF chart.", I do not see how they could miss a lens's field curvature.
I must confess I have a hard time understanding what you mean when you write "Field curvature is not something a lens suffers from, it's a feature, and a good one, if you ask me."
If a particular lens has field curvature such that the DOF in the corners of an image is closer to the camera, I may actually agree. Because then it can actually help to compensate for focus error when using the focus-and-recompose technique with a wide-angle lens.
But I believe that in most cases, the DOF of a lens with field curvature actually moves away from the camera in the corners, i.e. the exact opposite. So it would only make things worse.
11-28-2014, 10:00 AM   #647
Simply because I don't photograph focus charts a lot.
I prefer to photograph the world as I see it, in three dimensions, not flat. When I watch a wall in real life, I see the objects in the corner as further away than a centered object. You loose that dimension when using a flat field lens. And that's why good lens designers usually makes lenses with field curvature, ON PURPOSE.
The exception is macro lenses, they usually are designed with flat field on purpose. Because they are intended for a different purpose, to reproduce the word differently.
11-28-2014, 10:17 AM   #648
Mikesul's Avatar
QuoteOriginally posted by LensBeginner Quote
What can we infer from that "large diameter" wording? Also "large(r) image circle"?
Must/gotta be!
11-28-2014, 10:25 AM   #649
audiobomber's Avatar
Must/gotta be!
It simply means the 16-85mm won't have the excessive vignetting shown by the 18-135mm.
11-28-2014, 10:31 AM   #650
Mistral75's Avatar
QuoteOriginally posted by audiobomber Quote
The 'Large diameter telephoto zoom' has nothing to do with the 16-85mm f/3.5-5.6, it's the name of one of the two mock-ups shown at Photokina, corresponding to a 70-200ish f/2.8 lens.
11-28-2014, 10:35 AM   #651
Mikesul's Avatar
And that is a HUGE looking lens!
11-28-2014, 11:10 AM   #652
kh1234567890's Avatar
It still looks a pretty poor lens ...
DA 16-85 at 26mm f/7.1
??? Isuien Garden ?? 2014 ? HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR ?????????? - ??????
Some of the sample shots are really bad - click on the small thumbnails to see the full size images.
11-28-2014, 11:21 AM   #653
jatrax's Avatar
QuoteOriginally posted by kh1234567890 Quote
Poor lighting, and moss. I hate moss. I have been trying to take a good picture of moss for at least 5 years. Moss exudes some sort of optical defense system that causes all cameras to take soft pictures. I think it was originally a defense system against reindeer so they would get confused and not eat it.
But no, not a great image. Still waiting to see some taken in good light and of subjects that make it easier to evaluate the lens.
11-28-2014, 11:21 AM   #654
Please don't post gigantic files like that directly at the forum. Takes ages to load if you are on a bad connection, and makes large bills if you are at a phone.
Make links, or downsize.
11-28-2014, 12:43 PM   #655
QuoteOriginally posted by Fototim Quote
I also prefer to photograph the world as I see it, but I am puzzled by how field curvature is of any consequence to that. I think you might be refering to barrel distortion instead. And indeed some lenses are designed with deliberate barrel distortion (fish-eye lenses).
But what we are talking about here - or at least what I think we are talking about - is curvature of the focus plane. E.g. you focus at 10 meters, take a photo, and find that the bird in the corner of your frame, which was also at 10 meters distance from your camera, is not sharp. Instead, some stupid lamp post at 13 meters is.
11-28-2014, 01:08 PM - 1 Like   #656
bernhardn's Avatar
One more sample shot withe 16-85mm on a K-3
11-28-2014, 01:15 PM   #657
Sorry, I lost the trail of the thread. I also think the 70-200ish will be FF.
11-28-2014, 01:20 PM   #658
I attached 1 shoots (not very good but that for showing the problem) and 2 crops. 1 center and one border crop. This shoot as the problem and it is not a wall // to the camera. In fact it is almost as plane as a wall but not parallel to focal plane.
Field curvature at this level is not on purpose. On FA77 I never have the problem even through it is a lens known to have been designed to be pleasing and not give highest possible resolution numbers. Many thing are under corrected on purpose. But FA77 is tele, with almost no distorsion and no field curvatuve. At f/8 everything is razor sharp borders to borders.
But as you can see on theses DA15 pictures really show the DA15 can be quite soft on border in bad cases. I don't need the crop personnaly, I notice it at normal viewing size. On the example it seems that if focus is put near infinite on center, border are not focussed on infinite and subjects futher away are really soft.
I think I need to investigate more, but if somebody can explain how to solve this issue (I have heard here to use hyperfocal distance ?) I'am glad to ear.
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
11-28-2014, 01:38 PM   #659
Here another example, where there no subject that much futher away from the focus point... And the focus point also not as distant. The border are soft but overall you don't notice it if you don't crop and the crop while not very good, are already far better.
PENTAX K-3  Photo
PENTAX K-3  Photo
11-28-2014, 01:46 PM   #660
Ok. Technically you are right. Let me rephrase mysef.
Field curvature is a aberration, that is tried corrected to a certain point in most lens designs.
But it when field curvature is well controlled, it is also a feature. I hope I explained the reasons in previous post.
16-85mm f3.5-5.6ed dc, a.k.a, aps-c, button, camera, competition, dc, drive, ff, focus, glass, hd, hd pentax-da 16-85mm, image, length, lens, lenses, mount, pentax news, pentax rumors, pentax-da, release, sigma, sr, tamron, tele, w/a, wr
For Sale - Sold: SMC Pentax-DA 18-135mm f3.5-5.6 ED AL (IF) DC WR sholtzma Sold Items 2 02-05-2014 01:11 PM
For Sale - Sold: Pentax-DA 18-135mm F3.5-5.6 ED AL [IF] DC WR - reduced price tjwaung Sold Items 8 12-21-2013 05:56 AM
new smc PENTAX-DA 18-135mm F3.5-5.6ED AL [IF] WR DC KeesdH Pentax News and Rumors 227 06-22-2011 03:57 AM
PENTAX-DA 18-135mm F3.5-5.6ED AL [IF] WR D Fl_Gulfer Pentax News and Rumors 20 11-26-2010 05:13 PM
All times are GMT -7. The time now is 12:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
