Originally posted by Jantus which is quite funny
Having received a lot of help while ready through the two forums in the past years I thought like giving back something by sharing some first (subjective) thoughts on this new lens and helping others. I guess this is like forums work, especially as this lens seems to be quite seldom available yet. I do not see something odd in sharing these thoughts here and there.
---------- Post added 12-09-2014 at 06:59 AM ----------
Originally posted by FantasticMrFox The only zoom I currently own is the DA L 18-55 WR, how do the two (16-85 and 18-55) compare at 55 mm
You have to take into account that there are better and worse copies of lenses especially in the zoom sector. So, if it compares in a way to me copy of a 18-55 it must not be true for others in all cases.
However, I found the 18-250 to be superior to the 18-55WR in the range they share. Only considering sharpness of the lens, the DA 16-85 is somewhat similar to the 18-55 @ 55. This is not true for other parameters like CAs, where the new HD coating seem to show it's strengthness. But don't geht me wrong, in real day life, the lens seems to be also in the range 55 to 85 a quite good performer.
---------- Post added 12-09-2014 at 07:02 AM ----------
Originally posted by FantasticMrFox 16-85 equals the DA 35 f/2.4 in sharpness at 35 is certainly exceeding most expectations
As I said sharpness performance between 16 and 35 is excellent with a sweet spot around 24mm. At 35mm the DA35/2.4 and the HD16-85 show similar performance regarding sharpness (I must admit, sometimes I fear I do not own one of the best copies of a DA 35/2.4 though it's fine for sure).
