If you take a photos at 2900isos on FF and you are not limited by the lens on either side, the equivalent shoot in deph of field, speed and framing would show 1260 isos on the metering of APSC. So this important only if the APSC lens can't be more wide open or if the optical quality is lesser at this apperture on the APSC than by the equivalent FF lense.
So the high iso adventage of FF is there, that's for sure, but it only kick in on wide appertures. Shoot at f/4 on your FF and the adventage is not that big anymore already has it is fairly possible to get very good f/2.8 shoot on an APSC. The image quality might suffer a bit on zooms or some prime, through. f/5.6 and smaller apperture, there no more high iso adventage for FF on most common focal lenses as it is easy to find an affordable lens that would perform good enough at f/4 and allow to reduce the isos. This is while A7s is a really strange marketing position. It has slightly better high iso but the Sony lens offering in term of appertures make it rougly at a level on any APSC with an f/2.8 zoom and it get kicked by any Nikon/Canon FF with some f/2.8 zoom... Still many think their A7s is the low light kind
The real FF adventage here is with an f/2.8 zoom or shooting prime f/2 or f/1.4... The APSC would manage to handle a transtandard zoom with some success due to sigma 18-35 f/1.8 that is quite affordable and quite a good performancer but that would work only for this focal range (27-52mm FF equivalent). And it is likely than an FF prime shoot at f/2 look better than the equivalent APSC prime shoot at f/4. Lastly, if you use f/1.4 on FF, there no real equivalent on APSC.
