10-21-2014, 08:31 AM   #1
Belnan's Avatar
Ricoh lens patent and new q sensor?
Via photo rumors Ricoh lens patent for a new 8.17mm f/1.4 lens for a 2/3 sensor. Could the next q have a 2/3 sensor? Possibly from Fuji?
with the link: http://photorumors.com/2014/10/20/the-latest-patents-from-canon-panasonic-tamron-and-ricoh/
10-21-2014, 08:53 AM   #2
Banned
Well that is a large sensor: 8,8x6,6mm versus 7,6x5,7mm That is 1/3th bigger. I wonder if that still works with all lenses and still havinf SR.
Image sensor format - Wikipedia, the free encyclopedia
10-21-2014, 09:00 AM   #3
Na Horuk's Avatar
I really wish those sensor dimensions would just be expressed as mm instead of fractions of inches.. but nvm that now.
That would be much bigger, does the Q mount (radius and register distance) even allow that?
But an f1.4 lens for the Q would be great. The Q lineup could use some really bright lenses.
QuoteOriginally posted by RonHendriks1966 Quote
Well the latest Q already has a crop mode for the older lenses.
10-21-2014, 09:00 AM - 2 Likes   #4
Ah, I think I'm starting to understand Ricoh's FF strategy. They are going to sneak up on it with the Q while the K series stands around, whistles, and looks innocent. BOOM! Won't everyone be surprised?
10-21-2014, 09:24 AM   #5
A 3.93 crop factor...
The 8.17 f/1.4 would be equivalent to 32mm or so, the 35mm f/1.4 would be ~138mm.
Assuming the older lenses would give us full coverage, we'd have a
~33.4mm prime with the 01 (perhaps this is why the 01 seems to have disappeared as an available kit lens?)
~19.7 - 59 mm kit lens with the 02
~12.6mm with the 03
~24.8mm with the 04
~70.7mm with the 05
~59 - 176.9mm with the 06
~45.2mm with the 07
~14.9 - 23.2mm with the 08
and somewhere, the macro that's been hanging around as a concept for a while.
10-21-2014, 10:21 AM   #6
The fractions of inches have nothing to do with the dimensions (in any way you can make sense of) -- they are essentially meaningless...
10-21-2014, 10:47 AM   #7
ogl
Banned
Really? Could you give us any link or info from manual? Please...
10-21-2014, 11:00 AM   #8
THoog's Avatar
It's the length of the diagonal - but that's only useful if you also know the aspect ratio of the sensor. I suppose it made more sense when it was the diameter of the vidicon tube - or maybe if you convert to the FFF (Furlong/Firkin/Fortnight) system.
10-21-2014, 11:21 AM   #9
Aristophanes's Avatar
Fuji uses Sony sensors for their P&S now.
10-21-2014, 11:25 AM   #10
Mistral75's Avatar
It's not that bigger. The Q sensor is 1/1.7" and 2/3" is also 1/1.5". And 8.8 7.6 = 6.6 5.7 = less than 16% bigger.
But probably enough for the current lenses to show heavy vignetting.
The Q mount and its connectors could accommodate a 1" sensor (just).
10-21-2014, 11:28 AM   #11
QuoteOriginally posted by THoog Quote
It is not the length of the diagonal. The diagonal of a 2/3 sensor is 11mm. 2/3" is about 17 mm...actually I think it gives you the diagonal if you take 2/3rds of that (which is 11mm).
10-21-2014, 11:33 AM   #12
Mistral75's Avatar
It's the length of the outer diagonal (glass envelope) of a video tube that would produce an image of the same size as said sensor.
In short, pure marketing inflated figures (roughly, by a 1.5 multiplicator) but, even inflated, they are coherent among themselves: 1/2.3" - 1/1.7" - 2/3" - 1" - 4/3" (4/3).
10-21-2014, 11:51 AM   #13
QuoteOriginally posted by Mistral75 Quote
Less than 16% bigger in length and width - to get how much larger the area of the 2/3" sensor is over the 1/1.7" sensor you can multiply the ratios of the dimensions: (8.8/7.6) * (6.6/5.7) = 1.34; 34% more area. A third is correct.
10-21-2014, 11:54 AM   #14
Mistral75's Avatar
QuoteOriginally posted by goodnight Quote
Indeed, but for the image circle it's the diameter that matters and it's +16%.
And that's the point when the question is:
Well that is a large sensor: 8,8x6,6mm versus 7,6x5,7mm That is 1/3th bigger. I wonder if that still works with all lenses and still having SR.
10-21-2014, 12:29 PM   #15
Belnan's Avatar
How many lens patents never see the light of day.
No reason that lenses designed for a 2/3 sensor wouldnt work on 1/1.7 inch sensor though. The q system would definitely benefit from some fast lenses too.
lens, patent, pentax news, pentax rumors, ricoh, ricoh lens patent, sensor
ricoh files patent on 2 Q lens designs and on 4/3 design! shaolen Pentax News and Rumors 20 08-21-2014 12:03 AM
Ricoh patent for 24/2 APS-C lens robbiec Pentax News and Rumors 3 03-19-2014 09:40 AM
New lens patent — Ricoh 2/24 for APS-C mirrorless Uluru Pentax News and Rumors 78 03-01-2014 10:00 AM
New Ricoh patent for a 16mm/2.8 lens designed for APS-C MILC NickLarsson Pentax News and Rumors 5 01-17-2014 09:05 PM
New lens ricoh patent for 1/1.7" sensor... wanderography Pentax Q 14 11-07-2012 10:42 AM
All times are GMT -7. The time now is 06:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
