11-02-2014, 05:34 AM   #106
thibs's Avatar
Well, my 16-45 is IMO decentered. I certainly don't like its rendering anymore.
I'm not sure it's worth to repair considering the price it can be sold at.
Although, I'd lean to FF, that lens may be a worthwhile replacement.
My problem is, the wife as a K100D (non super) and can't use SDM/DC lenses.
Otherwise, it'd be a no brainer, if I go FF, she takes that lens and that's it; but she can't use (no she won't focus manually) neither the 17-70 or the 16-85.
Maybe I'll get the Tammy /2.8.
11-02-2014, 06:03 AM   #107
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
They definitely have SMC coatings, both the smc PENTAX-DA35mmF2.4AL and the smc PENTAX-DA50mmF1.8.
All green-ring lenses have SMC coatings (AFAIK), but not all SMC lenses have green rings.
Indeed. The green ring does not indicate a coating type, but rather the fact that the lens is a DA lens ("made for digital"). Silver ring means "digitally-optimized, but compatible with film". Red means HD coating and is probably a marketing move since Canon's L series lenses have red rings too.
So the ring "normally" indicates the DA/DFA-ness of the lens. Unless the lens has HD coating, in which case the ring indicates that fact.
11-02-2014, 06:11 AM   #108
RuiC's Avatar
QuoteOriginally posted by thibs Quote
At first I thought my 16-45 was decentered too, but I noticed that when extended for wider angle the barrel plays a bit and I usually held the lens by the barrel. Now I hold it near the mount and that avoids that play which provoked decentering.
11-02-2014, 06:33 AM   #109
thibs's Avatar
QuoteOriginally posted by RuiC Quote
I'll try that, thank you Rui
(/off: hope everything's fine for you)
11-02-2014, 07:28 AM   #110
RuiC's Avatar
All OK! Thanks
11-02-2014, 08:27 AM   #111
LensBeginner's Avatar
Well, that's not reassuring at all... :-S
11-02-2014, 08:33 AM   #112
aleonx3's Avatar
I have never seen people holding the extended part of the lens before... how do you do that? Do you zoom the lens out and then re-position your left hand to the front part of the lens to steady the shot?
---------- Post added 11-02-2014 at 10:41 AM ----------
QuoteOriginally posted by Sam N. Quote
Good question. Is anyone out there thinking to get the 16-85mm. I am thinking to get it, I presently use 16-50mm DA* lens as all purpose
I am wondering if the new 16-85 lens would be an upgrade kit lens bundle in the future (much like the 18-135). Hopefully someone will buy the bundle with camera and sell the lens separately, I am thinking.....
---------- Post added 11-02-2014 at 10:47 AM ----------
QuoteOriginally posted by LensBeginner Quote
Well, the 18-135 reaches f/5.6 pretty fast, around 70-78mm...
It remains to se what the aperture steps are on this one...
On the 18-135, from 69-135mm it is f5.6. I hope it stays at f4.5 further out before it reaches f5.6 like 75-85.
11-02-2014, 09:44 AM   #113
thibs's Avatar
Nope indeed but the 16-45 is very well known for that barrel play.
11-02-2014, 12:19 PM - 1 Like   #114
The DAL 55-300 has a similar issue. Rest the lens near the tip of the extended barrel while shooting = softer shots.
11-02-2014, 12:45 PM   #115
Nakedgun's Avatar
Although I will wait until the jury decides IQ (and the price drops a bit), I am planning to pair this with my DA55-300 as a two-lens travel kit for the K5.
I have the DA18-135 now, and not sure now what role it will then play, if any.
11-02-2014, 01:27 PM   #116
RuiC's Avatar
Indeed! Only my 2 cents!
---------- Post added 02-11-14 at 13:30 ----------
QuoteOriginally posted by aleonx3 Quote
Well, you have to give me some allowance as I am not such a great shooter as you are !
11-03-2014, 01:57 AM - 1 Like   #117
gazonk's Avatar
Mine is fine when used in landscape mode, but when I use it in the portrait direction I have to keep a finger on the wobbly barrel so it doesn't "fall down" in order to avoid decentered shots
11-03-2014, 05:39 AM   #118
robjmitchell's Avatar
After reading the the sigma 18-35 review I cant wait for this lens to come out. I really would like something to complement the 50-135 on the wide end. The limited zoom is starting to look tempting for outside work.
11-03-2014, 12:06 PM   #119
Zygonyx's Avatar
It is been available in K-mount since last June
11-04-2014, 03:54 AM   #120
macTak's Avatar
QuoteOriginally posted by gazonk Quote
I seem to recall that some people were even shimming it with paper to, like your finger, support the barrel.
16mm, 72mm, af, barrel, bundle, da, da 16-85, f4, fa, fe, ff, filter, hd, iq, kit, lens, lenses, lot, page, pentax, pentax da, pentax da 16-85, pentax news, pentax rumors, philosophy, price, usd
16-85mm vs 18-135mm wr Conqueror Pentax SLR Lens Discussion 17 10-12-2014 02:41 PM
Aargh! Just bent the metal lens hood on my Sigma 8-16 Unsinkable II Pentax SLR Lens Discussion 31 12-21-2012 08:20 AM
Sigma 85mm/1.4 price for Pentax mount now released. Pentaxor Pentax SLR Lens Discussion 91 10-25-2010 08:14 PM
Just bought myself the 16-50mm lurchlarson Pentax SLR Lens Discussion 12 05-24-2010 07:48 AM
Topaz Denoise 4 just released! JohnBee Digital Processing, Software, and Printing 3 05-07-2010 07:46 AM
All times are GMT -7. The time now is 08:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
