11-04-2014, 04:17 AM   #121
QuoteOriginally posted by macTak Quote
I seem to recall that some people were even shimming it with paper to, like your finger, support the barrel.
Forgive me for my ignorance. Can anyone help me how to test if my lens is decentered?
11-04-2014, 05:49 AM   #122
gazonk's Avatar
QuoteOriginally posted by totsmuyco Quote
Typical symptoms is softness on only one side of the picture. For instance, if I take a picture of a brick wall in portrait mode with my 16-45 set to 16-18 mm, with the camera perpendicular to the wall and with the center in focus, the upper part of the picture will typically look more out of focus than the lower part. Sometimes, if I'm unlucky, I can see slightly more softness on the right side than on the left side when used in landscape mode, too.
11-04-2014, 06:03 AM   #123
Clothears's Avatar
QuoteOriginally posted by gazonk Quote
If you hold near the end and it's decentring, that implies that the lens + camera weight is enough to cause that. Does that mean that the weight of the lens alone, when fully extended, wouldn't be enough to provoke the problem? With the camera on a tripod, for example.
11-04-2014, 06:27 AM   #124
Thanks. I'll give that a try. By the way, which Pentax lenses are prone to being decentered?
11-04-2014, 08:17 AM   #125
gazonk's Avatar
QuoteOriginally posted by Clothears Quote
I'm not sure what you mean, but I'm not holding near the end, just pushing with a finger to prevent the lens from "falling down". The wobbliness of a wobbly DA16-45 fully extended @16mm is certainly enough for it to get decentered by its own weight only. The wobbliness of my copy is mostly in the horizontal direction, thus the problem is worse when the camera is held in the portrait direction.
11-04-2014, 08:30 AM   #126
Typically, wide-angle lenses.
And it's not just a Pentax thing.
11-04-2014, 09:38 AM   #127
Clothears's Avatar
Ouch. OK, that's what I was afraid of. Is it as bad as that for the 55-300?
11-04-2014, 02:18 PM   #128
I'm afraid that, despite the "newer" technology, this lens won't be any better than the 17-70 I assume it is supposed to replace. The weight is about the same (488 vs 485 g) and just one size greater filter diameter (72 vs 67 mm), which leads me to believe that it will have the same type of construction (i.e. plastic barrel).
The MTF doesn't look like the increase in diameter has resulted in sharper corners or lower distortion, maybe sharper/better bokeh, but at the expense of a non-fixed aperture. Of course it's difficult to tell without better samples, but it doesn't seem like an improvement so far on paper. Plus the MTFs posted are duplicates, usually they post two sets based on wide open and stopped down... Is anyone paying attention to these details???
11-04-2014, 02:29 PM   #129
QuoteOriginally posted by thigmo Quote
It's been discussed elsewhere.
The Japanese page has differing MTF charts,
but not for distinct apertures,
just one geometric, and the other accounting for diffraction.
11-04-2014, 03:21 PM   #130
jatrax's Avatar
It's not SDM................
11-04-2014, 05:12 PM   #131
Mikesul's Avatar
Are there any user photos with the lens yet?
11-04-2014, 05:29 PM   #132
With my all-plastic DAL 55-300, the issue only arises when I apply some pressure on the tip of the extended lens by resting it on a hard surface. Otherwise, no issues.
I wouldn't overstate the problem. The plastic of a lens isn't really an issue. Even the most solidly built lenses can get de-centred because they may have taken a knock. And the more complex the design of a lens (23 elements in 19 groups etc), the harder it becomes to ensure perfect optical performance even straight from the factory, let alone over time, as wear, heat, the loosening of screws etc take their toll.
11-04-2014, 06:23 PM   #133
FantasticMrFox's Avatar
It will be released end of November, how could there be any user photos yet?
Unless Ricoh is handing out models to trusted reviewers early - which I doubt.
11-04-2014, 07:13 PM   #134
RGlasel's Avatar
QuoteOriginally posted by Sam N. Quote
Good question. Is anyone out there thinking to get the 16-85mm. I am thinking to get it, I presently use 16-50mm DA* lens as all purpose
Not me, but if you decide to replace your DA* 16-50, I'll be happy to give it a good home. You would be going from a constant f2.8 to f3.5-5.6 for starters, and from "*" optics to similar IQ as the much maligned (unfairly in my opinion) DA 18-135. If you are good with 50mm as the long end of your all purpose lens, you probably won't use 51-85mm that much, either. The only advantage to you getting the new 16-85 is the DC autofocus motor compared to SDM in your 16-50. Makes no sense to me, but it's your money.
11-05-2014, 05:46 AM   #135
gazonk's Avatar
My own 55-300 isn't wobbly at all.
16mm, 72mm, af, barrel, bundle, da, da 16-85, f4, fa, fe, ff, filter, hd, iq, kit, lens, lenses, lot, page, pentax, pentax da, pentax da 16-85, pentax news, pentax rumors, philosophy, price, usd
16-85mm vs 18-135mm wr Conqueror Pentax SLR Lens Discussion 17 10-12-2014 02:41 PM
Aargh! Just bent the metal lens hood on my Sigma 8-16 Unsinkable II Pentax SLR Lens Discussion 31 12-21-2012 08:20 AM
Sigma 85mm/1.4 price for Pentax mount now released. Pentaxor Pentax SLR Lens Discussion 91 10-25-2010 08:14 PM
Just bought myself the 16-50mm lurchlarson Pentax SLR Lens Discussion 12 05-24-2010 07:48 AM
Topaz Denoise 4 just released! JohnBee Digital Processing, Software, and Printing 3 05-07-2010 07:46 AM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
