01-07-2015, 01:32 PM   #301
The Kit looks sexy.... 15/35/18-50WR/50/50-200WR for a lightweight setup....
01-07-2015, 01:33 PM   #302
THoog's Avatar
Nice camera.
Yeah, looks pretty nice, but too bulky, and it needs some yellow rubber and LEDs on the grip.
I'm holding out for something bigger.
Shouldn't the next Q be due this fall?
01-07-2015, 01:44 PM   #303
Zygonyx's Avatar
There is a product development model in which a new feature or technology you don't already own / haven't self-developed is introduced in steps:
  1. License the basic technology (Flucard for Pentax - Eye-Fi Menu integration)
  2. Learn and develop while implementing the licensed technology
  3. Implement the licensed technology on 'test bed', secondary platforms (Q, Q7, MX-1)
  4. Implement self-developed technology on a 'test-bed' platform (Wi-Fi on WG-30)
  5. Implement nearly finalized technology on a major product (K-xx)
  6. Continue improving future implementations of technology
If you look back at things we've asked for (Hinged LCD - MX-1, 645z - K-xx; Wi-Fi; find your own) you'll find this pattern recurring since Ricoh took over. IMHO it reflects the necessity to spread limited resources across a rich panoply of products and platforms, staying relevant while growing revenue and is part of the long term Plan to make Pentax one of the market leaders over the next 5 years.
The same type of development is happening at Ricoh Imaging America, but it is harder to see that since there aren't physical products to show in display cases.
Bravo.
01-07-2015, 01:55 PM   #304
Banned
Wi-fi
Putting WI-FI in the camera isn't free. Cameramakers have to pay for this future. I guess that putting WI-FI in the camera is cheaper then the rescently free of charge FluCards you can get with camera's like the K-3 and K-S1. It's about $ and not technology.
01-07-2015, 02:05 PM - 1 Like   #305
monochrome's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
It's also an engineering issue. When small size is your mantra and the entire interior of the camera is already jammed full of electronics, and especially when you insist on using a lot of metal in the frames and shells of your cameras (reducing the possible locations for the Wi-Fi antenna) -
  • Where do you put the antenna?
  • Where do you put whatever you moved to put the antenna there?
  • Where do you put whatever you moved to put whatever you moved wherever you moved it?
  • and so on -
In that situation the FluCard for Pentax was actually a decent Quick'nDirty solution.
01-07-2015, 02:10 PM   #306
I like the looks of it excet for that carbon fiber top plate. Things like NFC add very little cost... just check out how much NFC tags cost... but are cool features. For the US market, if Ricoh wants Pentax to grow they need to be in brick & mortar stores... Where I live I have 0 options to see a Pentax and would go with Canon or Nikon if I wasn't such a researcher. Most people don't research like I do. I hope they get this model in some local stores... Sam's, Best Buy, Wal-Mart, Target... anything
01-07-2015, 02:16 PM - 1 Like   #307
Conjecture: The carbon fiber looking top plate is the WiFi antenna in disguise, cleverly solving internal space problems. It falling off is not a bug, but a feature allowing you to re-position it for better reception.
01-07-2015, 02:29 PM   #308
THoog's Avatar
  • and so on -
Plus power requirements. Pentax engineers seem to favor shot count over power consuming additional features.
01-07-2015, 02:31 PM   #309
cxdoo's Avatar
QuoteOriginally posted by THoog Quote
As long as it can be turned off & never used, I'm fine with them adding it.
01-07-2015, 02:37 PM   #310
jcdoss's Avatar
QuoteOriginally posted by filoxophy Quote
Wow, looks great! After all this time agitating for an articulated LCD, I wish it were just up/down like the MX-1, 645Z, X5... Mainly I just want a digital WLF! .
Me too! I've grown quite used to the vertical articulation of the LCD on my Sony. At any rate, this looks like an excellent path forward in every way except apparently one... full frame.
01-07-2015, 02:59 PM   #311
mrNewt's Avatar
Still no back shots of this camera ... !?
01-07-2015, 05:26 PM   #312
Docrwm's Avatar
The Flu Cards were an extra $20 with the K-3 kits FYI. I happen to like the idea of the Flu card because it's hardware can be upgraded with a new tech, where in-camera wifi an only have its firmware upgraded.
---------- Post added 01-07-15 at 07:27 PM ----------
Thank you Pentax Engineers.
---------- Post added 01-07-15 at 07:28 PM ----------
QuoteOriginally posted by cxdoo Quote
Excellent point.
01-07-2015, 06:00 PM   #313
richandfleur's Avatar
QuoteOriginally posted by mrNewt Quote
Yeah frustrating isn't it, - would answer a few more questions.
01-07-2015, 08:40 PM   #314
JPT
I've thought the flucard was a poor solution from the start. It doesn't make sense to package Wi-Fi with storage. Why should you lose you Wi-Fi capability when you change the memory card?
I have a $600 smartphone and a camera that costs around the same. If a simple and cheap component can give me more value from both devices, I want that. In fact I might save money by not having to buy an IR remote.
On the subject of cost, should I object to the cost of the mic input in my K-01, which I've never used? Or should someone with 20:20 vision object to the diopter adjustment in DSLR viewfinder? Ricoh, like all manufacturers, has to make some generalisations about what most people want.
Finally, they already made the remote application, so it makes sense to leverage that as much as possible. I only hope that the application gets better and better with future updates.
01-07-2015, 09:56 PM   #315
Not a Number's Avatar
QuoteOriginally posted by JPT Quote
What's wrong with that? I can put a Flu-Card into my K10D and have some Wi-Fi capability. How else could it be done? Some USB dongle that uses the tethering capabilities of the K10D? What about cameras that don't have tethering? With the cover open there goes the WR. So what if the Wi-Fi capability goes when I change the memory card if the camera never had it in the first place.
By putting Wi-Fi on the storage card you can have a universal lowest common denominator function of being able to transfer files to another Wi-Fi device and not have to worry about what brand and model camera the card is being used in.
af, bodies, body, button, camera, cameras, ces, da, diaphragm, dslr, engineers, flu, k-3, lens, light, macro, nikon, pentax, pentax news, pentax rumors, plastic, power, release, ricoh, sdm, watches, wi-fi, wr
Ricoh's Booth at CP+ 2015 Docrwm Pentax News and Rumors 80 02-10-2015 04:37 AM
Pentax / Ricoh Full Frame at CES ClinchShots Pentax Full Frame 44 01-01-2015 02:44 PM
Pentax at CES i83N Photographic Industry and Professionals 38 01-10-2014 10:34 AM
Where is the Pentax news from CES 2010? KungPOW Pentax News and Rumors 29 01-19-2010 11:31 AM
Pentax at Jan 7th 2010 CES ? Samsungian Pentax News and Rumors 34 01-08-2010 03:58 PM
All times are GMT -7. The time now is 02:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
