01-10-2015, 02:33 PM   #136
QuoteOriginally posted by RobA_Oz Quote
Ever since the K-5, HDMI has been available to connect a monitor in place of the LCD screen, so I'm not sure what you mean by that.
The HDMI on the K-01 is for playback only, no HDMI live view.
The K-50 has no HDMI port. I expect the K-500 to be the same. I don't have a K-30.
01-10-2015, 03:09 PM   #137
jeff knight's Avatar
QuoteOriginally posted by mee Quote
Switching threads with your comment?
Yep, but not switching brands with my camera....
01-10-2015, 08:50 PM   #138
So it does. I obviously overlooked that image. It shows the USB symbol as well.
Many cameras can't display only the video feed onto the screen, without any overlays. They may not be able to display a 1920x1080 video, it might have compression artefacts, etc. What some people want though is an output that can be recorded via an external HDMI recorder... and for that the full resolution is needed, without overlays etc. AFAIK no Pentax has been able to do that.
01-10-2015, 09:02 PM   #139
RobA_Oz's Avatar
QuoteOriginally posted by Steve.Ledger Quote
QuoteOriginally posted by kadajawi Quote
Thank you both. Not having an interest in video, I wasn't aware of the video feed issue.
01-11-2015, 06:19 AM   #140
Na Horuk's Avatar
Just one thing I noticed. Traditionally the top tier Pentax had a top LCD, and the mode dial on the left side of the camera. So I guess this is a not a flagship. I assume the K-S1 is the "sideways" product (not part of the main product hierarchy, like K-01 before), this one is the new K-r/K-30/K-50 (the mid tier, just below the flagship). So it will probably have the same sensor as K-S1. And maybe we will get another flagship, a true K-3 replacement, WR (maybe without articulated back LCD) and the works, sometime later.
Still, I think I will start saving up now This looks like a great camera and it has that articulating screen I wanted! Wifi is okay, as well, I guess. Maybe can connect it to a tablet or smartphone. Can't wait for more info to come out!
01-11-2015, 06:47 AM   #141
Just one thing I noticed. Traditionally the top tier Pentax had a top LCD, and the mode dial on the left side of the camera. So I guess this is a not a flagship. I assume the K-S1 is the "sideways" product (not part of the main product hierarchy, like K-01 before), this one is the new K-r/K-30/K-50 (the mid tier, just below the flagship). So it will probably have the same sensor as K-S1. And maybe we will get another flagship, a true K-3 replacement, WR and the works, sometime later.
Yes, this should be the K-50 replacement... Some of the design elements of the K-S1 clearly went into this, though it's a shame that the lit up 5 way selector didn't make it... or, hopefully, it's lit up in a more subtle way. Lit up buttons in general can be a nice thing when it's dark, especially the mode dial.
A repackaged, hopefully enhanced K-S1 seems reasonable. I can only hope that they use the hardware in the D5300 for this new Pentax. The Milbeaut used there does a good job with video, it produces clean, aliasing and moire free FullHD content, and the encoder, for a h264 one with around 24 Mbps does a good job (maybe Pentax can raise that, offer 18 Mbps, 24 Mbps and 36 Mbps? Or even more), and likewise the D5300 sensor or something like that, something that is fast enough for full sensor readout at a high enough frame rate. If they'd enable SR (just as an option...) that would be a pretty tempting video package IMHO. It would certainly beat Nikon's and Canon's offerings. If the firmware developers then get some inspiration from the NX1 or GH4 or Magic Lantern...
Pentax IIRC did say that the S line is for experiments, so for example the K-01 would have been the K-S1 if they had come up with that earlier (or maybe K-0x was supposed to be that, but since that experiment didn't go so well they decided to do a fresh start).
Since the camera seems to have WiFi and NFC I think it is safe to assume that the reason is so that you can connect it to your smartphone or tablet. Instead of having to set up the phone to connect to the camera, you just tap together phone and camera, and that should more or less be all. Maybe install an app or so, but the process will be much easier. And being properly built in WiFi the speed will be much better than what a FluCard (or so) can provide.
Pentax has got a lot of things right with this camera, it seems. That's great news.
01-11-2015, 07:42 AM   #142
QuoteOriginally posted by rrstuff Quote
The question is if it is mid-grade, like K-50, or an entry level like K-500. This camera looks a bit flashy, but everything seems to be there - so it could be either.
A K-50 replacement. Difference between the K-50 and K-500 was the weather sealing in the K-50. This unnamed camera is most likely weather sealed since it comes with a WR kit-lens.
01-11-2015, 08:18 AM   #143
THoog's Avatar
IIRC, a Pentax rep at Photokina flatly stated that the K-S1 was not a K-50 replacement, but no one seemed to accept that, and that just added to the negative reaction to it.
A PF member (sorry, don't remember who) did an analysis of time between new Pentax models, and found that it was consistently in the 17-21 month range. We are at 19 months on the K-50, and 14 on the K-3. So we aren't due for a K-3++ for a few more months (CP+ may still be too early), but we are very much due for a K-50++. The plastic body, colors, and control layout very much indicate that the K-?? is that K-50++.
01-11-2015, 06:00 PM   #144
QuoteOriginally posted by THoog Quote
People couldn't accept that a brand new model (with newer sensor, etc) was priced the same as a 16 month old model that was ostensibly in a higher bracket.
Don't think I worded that very smoothly, but I just expect Pentax to release bodies at an aggressive price point before letting them fall.
At least they DO fall...circa 2009 7D for $1000 anyone? E-M1 for $1100+? The 7DII is still $1800, or $500 more than the K-3 at launch.
Now the K-S1 has dropped to $600, making room for this new body. Market segments and product cycles, people.
So if this new body is announced and priced before the K-3 replacement, expect a lot of wailing and gnashing of teeth on the PF boards...
01-11-2015, 10:18 PM   #145
stillshot2's Avatar
Am I the only one who thinks there isn't a whole lot of room to place your thumb at the back of the camera? It seems the play button will be too easy to push by mistake and should have been put somewhere else.
01-11-2015, 11:19 PM - 1 Like   #146
QuoteOriginally posted by stillshot2 Quote
Am I the only one who thinks there isn't a whole lot of room to place your thumb at the back of the camera?.
No idea, are you?
Seriously though, there's a lot of Q and MX-1 users who don't push buttons by mistake (I have both).
They are much smaller bodies with even less room for fat sausage-like westerner digits
I have a hunch the designers did their homework.
01-11-2015, 11:33 PM   #147
It may be mid-level, but, I am not sure that this camera is much bigger than the KS-1, with flippy screen (must take certain room) and layout on back a bit like the KS-1 this is the look they are going for, it will be interesting to see what they will do for a K3 replacement.
01-11-2015, 11:37 PM   #148
I like that the articulating screen sits flush with the rest of the body, rather than protruding partially. The use of the OVF doesn't appear to be impacted, which isn't always the case with these screens.
01-12-2015, 01:24 AM   #149
QuoteOriginally posted by ofer4 Quote
Good point. It can't have been easy to fit the SR and the flippy screen behind the sensor without pushing the back out.
01-12-2015, 03:01 AM   #150
Cynog Ap Brychan's Avatar
Judging by other comments in this thread, no you are not (To paraphrase Lincoln; "You can't satisfy all of PF members all of the time"). However, if you want a flippy-out screen and a compact body, this is probably the price that has to be paid. If you don't.... well, get a K-3! I'm not worried - I've used smaller cameras than this without problems,. I guess I don't have fat thumbs.
body, brother, buttons, camera, cameras, k-50, lcd, pentax, pentax news, pentax rumors, pictures, post, ricoh, school, screen, team, vari-angle, width
K-3: Best Of The Best for 2013? Doundounba Pentax K-3 & K-3 II 8 01-04-2014 08:06 PM
Camera Store TV team :Sony A7r is the best camera of the year 2013 jogiba Canon, Nikon, Sony, and Other Camera Brands 21 12-29-2013 06:30 AM
K-3 in the top 3 best cameras of the year...as per Camera Store mamethot Pentax K-3 & K-3 II 3 12-26-2013 05:58 PM
Best of the used (K-5, K-x, K-7) ASheffield Pentax DSLR Discussion 12 10-04-2013 05:25 PM
OK, what is the best way to send my camera back? NaClH2O Photographic Technique 10 07-06-2008 08:41 AM
All times are GMT -7. The time now is 07:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
