Closed Thread
02-13-2015, 05:38 PM   #136
What is the difference between AW and WR, or I should ask, what makes AW better than WR?
02-13-2015, 06:09 PM   #137
QuoteOriginally posted by Newtophotos Quote
Well, you'd have to ask the engineers, but AW has always been positioned above WR, which has been described as "simplified" sealing.
02-13-2015, 06:37 PM   #138
Yes AW is supposedly better than WR. All Weather against Weather Resistant.
02-13-2015, 09:38 PM   #139
Blue's Avatar
There is also a lesser third level that is found in lenses such as the kit lens 18-55 WR as well as the 18-135mm.
02-13-2015, 09:39 PM   #140
Blue's Avatar
QuoteOriginally posted by thibs Quote
Indeed. Variable aperture I guess.
That was the only thing I could see that would hold it back. It has 3 ed elements in it.
02-13-2015, 11:14 PM   #141
thibs's Avatar
QuoteOriginally posted by filoxophy Quote
Also AW has been used (but not put up front) from the release of 16-80 and 50-135.
All DA* (and DFA* it seems) are AW, not simple WR.
---------- Post added 14-02-15 at 07:15 ----------
Agreed, can't see anyting else, specially with all those focus buttons etc.
02-14-2015, 01:35 AM - 1 Like   #142
Digitalis's Avatar
The number of ED* elements alone cannot determine the performance of the lens, it is the grade of ED glass used and how they are employed in the optical design that makes a difference. It appears to me that Pentax is using High grade ED glass as it is expensive and use of exotic glass types is a requisite for apochromatic lens design - but the upshot is with high grade ED glass that you can get away with using less of it to obtain a high degree of optical correction. I will point out that the Sigma 100-300mm f/4 APO EX DG has only four SLD** elements in it and while it is a superb lens, it still suffers from a small amount of chromatic aberration.
*Extra-low Dispersion - was historically made using regular borosilicate glass with thorium dioxide added to it, this glass type was discovered to be potently radioactive and was phased out. Modern ED glass is typically composed of a small percentage of Lanthanum along with other elements such as titanium dioxide added to stabilize the glass structure and improve durability - however with high amounts of lanthanum, even with these additives ED glass can become very soft compared to standard optical grade borosilicate glass.
**Super-Low Dispersion - the differences in chemistry between this and standard ED glass is an increase in the percentage of lanthanum dioxide, along with zirconium dioxide which adds to the expense of production as this glass requires the use of Platinum crucibles in order to make it.
02-14-2015, 01:43 AM   #143
Barry Pearson's Avatar
Here is a quote from a Pentax "Lenses and Accessories" catalogue dated 13 January 2013:
Water and Dust Protection
Humidity and dirt are the natural enemies of high performance electronics and precision optics. AW lenses provide maximum weather-resistant and dustproof performance preventing the intrusion of drizzle and dust into the lens barrel.
The next category of “all weather” PENTAX lenses is designated as WR or weather-resistant. These affordable lenses utilize a simplified weather-resistant construction, making it more difficult for water to enter the lens and are designed to repel a light splash of water.
Up to now, AW was mainly or entirely reserved for the DA* lenses and the HD DA 560mm F/5.6 ED AW.
02-14-2015, 07:47 AM   #144
Blue's Avatar
You are preaching to the choir Digi. The non-* lens announced is has a higher MSRP than the faster * lens. The 1st Pentax lens to carry a * was the M* 300/4. It nor the A* 300/4 that replaced it seem to have any special glass while the A* 300/2.8 had 2 elements made of Extra-Low Dispersion glass. Best I can tell, there has never been a variable aperture * zoom lens.
02-14-2015, 07:43 PM   #145
Hey, guys. I know most of us were wondering just how big these lenses would be on a K-3. Well, the other forum has a report from CP+ with both lenses on a K-3. Check it out. They are not small.
Jack
02-14-2015, 07:50 PM - 1 Like   #146
Digitalis's Avatar
QuoteOriginally posted by jbinpg Quote
These D-FA zoom lenses are intended to be high performance full frame lenses, did you really expect them to be small?
02-14-2015, 08:00 PM   #147
Blue's Avatar
Jack
As Digitalis said, these are some serious zooms and the 70-200 is f2.8 on top of that which is considered fast, especially for a zoom.
02-14-2015, 08:08 PM   #148
JPT
Having handled these lenses briefly, they are truly massive and very well built. DPR just posted some pictures and impressions from CP+.
CP+ 2015: Ricoh gets serious with new Pentax full-frame zooms: Digital Photography Review
When you get your hands on one of these, you'll wonder whether to mount it to a camera or dock it to a space station.
02-14-2015, 11:33 PM   #149
QuoteOriginally posted by JPT Quote
If they perform well, and are built tough for many years of reliable use, few will be-grudge them their weight or size.
02-15-2015, 01:00 AM   #150
Asahiflex's Avatar
Actually I'm 99% sure those two lenses have ED glass in them. As a proof I have copies of the original Dutch Pentax price lists from that era listing them as SMC Pentax-M* and A* 300mm F4 ED!
Closed Thread
1.4x, 150-450mm, af, barrel, bigma, crop, da*300, dc, focus, grass, hd, image quality, iq, kg, lens, lots, mm, motor, pentax, pentax news, pentax rumors, pentax-d fa 150-450mm, position, price, shots, tc, thread, tripod, wr
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR samples flomat Lens Sample Photo Archive 53 08-29-2021 03:31 PM
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR Adam Pentax News and Rumors 917 03-13-2015 12:59 PM
Three-part review of HD Pentax 16-85mm F3.5-5.6ED DC WR (Japanese) odyseuss Pentax SLR Lens Discussion 94 12-01-2014 10:44 AM
First Look Video: HD PENTAX DA 645 28-45mm F4.5 ED AW SR Thomasbrowphoto Pentax Medium Format 10 08-06-2014 06:37 PM
HD PENTAX DA 645 28-45mm F4.5 ED AW SR Lens Review i83N Pentax News and Rumors 2 08-04-2014 07:38 PM
All times are GMT -7. The time now is 05:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
