Originally posted by Mccsiz I'm trying to improve my photos of songbirds and other small birds that flit about. In some cases, I can sneak up to within 25 feet. Mostly, however, the small birds are farther away. My camera body is the K3 (I also have a K5). Any suggestions?
It's going to be hard unless you can get closer. If you're shooting from a fixed location, a tripod will help to reduce motion blur. DXO Photolab works with the K3 (not yet with the K3iii) and has some excellent AI noise reduction on RAW. I find however that its JPEG engine tends to produce artifacts in subtle shades like sunsets. I mention it because it may help you use a higher ISO like 1600 to get a better shutter speed. The sort of settings I was using on the K3 was - spot focus AFS, centre weighted AE, aperture priority, auto ISO up to 1600, and I think you can also set the camera to bias for high shutter speeds. On APS-C, the DFA 150-450 is reasonably sharp wide open and gives really nice bokeh. Make sure that SR is on, of course.
The only other thing if you have enough light is to consider the HDDA 1.4x TC but honestly I don't use mine very much. It adds a little softness and creates a field of view which is very small. I am generally shooting hand held while I walk around rather than from a specific spot with a tripod. Maybe try camouflage clothes to see if you can get closer? It doesn't seem to help me much though!
