Closed Thread
Show Printable Version 414 Likes Search this Thread
02-15-2015, 02:57 AM   #151
Barry Pearson's Avatar
QuoteOriginally posted by JPT Quote
Having handled these lenses briefly, they are truly massive and very well built. DPR just posted some pictures and impressions from CP+.
CP+ 2015: Ricoh gets serious with new Pentax full-frame zooms: Digital Photography Review
When you get your hands on one of these, you'll wonder whether to mount it to a camera or dock it to a space station.
I've pre-ordered those 2 lenses. In order to afford this, I'm part-exchanging my Sigma 500mm f/4.5 APO EX DG, which weight 3 kilograms and was too heavy for me, except on a gimble.
I am worried that the new lenses will also be too heavy! I'm happy with the DA* 60-250mm f/4, which weights 1 kilogram. But what will it be like hand-holding the 2 kilogram D-FA 150-450mm for hours at an airshow? I guess I'll find out during June!
If they perform well, and are built tough for many years of reliable use, few will be-grudge them their weight or size.
I will begrudge that! But I am simply going to have to bite my lip and put up with it.
02-15-2015, 03:42 AM   #152
Digitalis's Avatar
QuoteOriginally posted by Barry Pearson Quote
I use a Nikon D4s with a Nikkor 400mm f/2.8G ED VR - that combination weighs significantly more than 3Kg, and I don't have a problem with hand holding for short periods of time. Monopods go a long way to reduce fatigue and shoulder strain when using heavy lenses.
I seriously suggest you look into getting a monopod. A head like the Krik King cobra on a carbon fibre monopod would be an effective combination with such a long lens.
02-15-2015, 06:13 AM   #153
For aps-c sensor DFA 150-450 is a super telephoto lens, like a second coming of the FA* 250-600. People just not appreciate how much cheaper is now to work with telephoto. Even with no fullframe this lens should have a niche in the market.
02-15-2015, 07:12 AM   #154
Digitalis's Avatar
QuoteOriginally posted by pacu Quote
These two lenses are very different beasts. The FA* 250-600mm f/5.6 ED [IF] is an amazing lens, I'm not sure if the D-FA150-450mm f/4.5-5.6 ED DC AW can topple it.
02-15-2015, 07:45 AM   #155
Blue's Avatar
QuoteOriginally posted by Asahiflex Quote
Actually I'm 99% sure those two lenses have ED glass in them. As a proof I have copies of the original Dutch Pentax price lists from that era listing them as SMC Pentax-M* and A* 300mm F4 ED!
Thanks. I thought so as well, but when I checked the Dimitrov site, I couldn't confirm that they did. I need to dig through some of my references.
02-15-2015, 08:32 AM   #156
Today's expectations are far higher than in the film days, pixel peepers don't need a microscope like the good old days... For example the old nikon 80-400 d with film was something like a pentax da 55-300 with a modern sensor in end photograph quality. When the new nikon 80-400 g came, designed for today's high resolution sensors, the price doubled. I am sure you can achive the same equality you had in the 90s with a FA* 250-600mm f/5.6 ED [IF] with a D-FA150-450mm f/4.5-5.6 ED DC AW today thanks to digital sensors. If a equaivalent focal length of 675mm can't help you then probably nothing will. The atmosphere frequently becomes a limitting factor as the narrow field of view.
02-15-2015, 08:48 AM   #157
I've tried various things at airshows. I have a good monopod. I have a useful gimbal head. They simply don't give me the all round flexibility I need, for example shooting pretty well straight up. Ditto for birds in flight.
I find a gimbal useful for some positions at motor sports. Motor bikes and cars rarely fly overhead! Unfortunately, when they (nearly) do so, hand-held is best!
02-15-2015, 05:46 PM   #158
Digitalis's Avatar
Digital sensors cannot change the laws of physics - the optics of the FA*250-600mm f/5.6 are absolutely first rate, pretty much as good as a prime when stopped down to f/8. Will the D-FA150-450mm f/4.5-5.6, a variable aperture zoom be able to match it? possibly.
02-15-2015, 09:29 PM   #159
Blue's Avatar
Well, for one thing, it is going to be a whopping 150mm shorter in focal length. I am not convinced that the HD coating is going to be any better than the coatings used on that FA*.
02-16-2015, 12:27 AM   #160
Actually, F*250-600/5.6 is at its best at f/5.6. Diffraction is limiting at smaller apertures. I tested F*250-600/5.6 against DA*300/4 and the zoom was better at f/5.6 than the prime at f/5.6
02-16-2015, 01:00 AM   #161
Digitalis's Avatar
QuoteOriginally posted by StigVidar Quote
I tested the FA*250-600mm f/5.6 ED [IF] On full frame against the Pentax FA*300mm f/2.8 ED [IF] and A*400mm f/2.8 - on my testing bench* the Primes held an edge over the zoom, due to their inherently wider initial apertures but at f/8 all three lenses delivered essentially identical performance.
*Testing long 35mm lenses on an optics bench is a nightmare, the tiniest mis-focus can reduce resolution from a lens by 40%. I had one hell of a time comparing the Nikkor 400mm f/2.8 with a 2X teleconverter against the Nikkor AF-S 800mm f/5.6E FL ED VR.
02-16-2015, 03:42 AM - 1 Like   #162
Mike.P®'s Avatar
I tested my FA* 250-600mm at f5.8 and f8 .... I have to say that the results at all apertures were pretty bad.
Although now I think about it maybe it was because I was trying to shoot a 7kg combination handheld
02-16-2015, 04:17 AM - 2 Likes   #163
This is an image og Jupiter and four of its moons. Shows how much cropping you can do on images taken with F*250-600/5.6. Taken with Q7 and cropped.
02-16-2015, 07:23 AM - 1 Like   #164
Clinton's Avatar
Looks blurry to me. To make it sharper next time, please use this technique:
02-16-2015, 07:07 PM - 1 Like   #165
johnmflores's Avatar
Galileo, Kepler, Newton, and others would be amazed!
Closed Thread
1.4x, 150-450mm, af, barrel, bigma, crop, da*300, dc, focus, grass, hd, image quality, iq, kg, lens, lots, mm, motor, pentax, pentax news, pentax rumors, pentax-d fa 150-450mm, position, price, shots, tc, thread, tripod, wr
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR samples flomat Lens Sample Photo Archive 55 10-21-2021 03:00 PM
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR Adam Pentax News and Rumors 917 03-13-2015 12:59 PM
Three-part review of HD Pentax 16-85mm F3.5-5.6ED DC WR (Japanese) odyseuss Pentax SLR Lens Discussion 94 12-01-2014 10:44 AM
First Look Video: HD PENTAX DA 645 28-45mm F4.5 ED AW SR Thomasbrowphoto Pentax Medium Format 10 08-06-2014 06:37 PM
HD PENTAX DA 645 28-45mm F4.5 ED AW SR Lens Review i83N Pentax News and Rumors 2 08-04-2014 07:38 PM
All times are GMT -7. The time now is 02:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
