Closed Thread
04-06-2015, 02:41 AM   #406
QuoteOriginally posted by timautin Quote
ok, no problem (and sorry if I upset you, I didn't mean it) !
So DagT had the time to put some RAWs on DropBox (he will put the link here soon I guess), thanks !
The cat is fine, the seagull less, but looking at he exifs (1/400 - ISO100 - f5.6 for the cat & 1/320 - ISO100 - f8 for the seagull) IMHO the results would be better with a shorter shutter speed and higher ISO.
Remember that I used the 1.4 TC on the seagul picture, so the focal length was 630mm, which og course limits the quality i little and make focussing more difficult.
I was testing the limits, and I agree that I usually should use higher ISO.
DagT
04-06-2015, 06:51 AM - 2 Likes   #407
QuoteOriginally posted by DagT Quote
I suddenly had a chance to test the lens yesterday (thanks to Kenspro) and made a small web site with a couple of images: Pentax D-FA 15--450mm | Dag Thrane
Somehow the EXIF data disappeared but Ill look into that and add some more pictures.
For those interested I have added some more pictures and technical details. Also, to get a better impression of the pictures I have added a little sharpening to the processing as this is what you usually would do anyway.
The drop box link to RAW versions of two of the pictures is here: https://www.dropbox.com/sh/kltb76zuwcf17p1/AACrW_nM26W-SvuFavO1UMCXa?dl=0
04-06-2015, 07:03 AM   #408
Thanks Great
04-06-2015, 07:22 AM   #409
Thanks for the raw images. The gull shows substantial movement blur; at 1/320 movement may be the issue, or possibly vibration from the shutter especially with the TC. I'd start at 1/1600 with that combination, and you probably would get better images by removing the TC to get the stop of light back. Set up on a solid tripod as well.
Frankly, for me that would have been a throw away.
I'm saying this because I still don't have an impression of the lens. Above 300mm so much is technique dependent, especially at 630mm there are so many things that can go wrong that have nothing to do with the lens.
04-06-2015, 07:31 AM   #410
Yes, you may be right. It also takes some time to get used to, and I see that the newer pictures are improving over the first ones. I guess the photographer is the limitation, which is a good sign for the lens :-)
I would love to keep it for a few weeks, but Ill have to give it back in a few days.
04-06-2015, 11:52 AM   #411
That detail in the cat shot at 450 mm f5.6 is pretty impressive. According to me atleast. Looks like the sharpness I get out of my DA 35 macro ltd. Or my DA*55 stopped down a bit.
I will buy this lens
04-06-2015, 05:43 PM   #412
Shanti's Avatar
Thanks for the extra shots... I ask again.are they are handheld with SR on? if so 1/320 is very slow I think, I would use 1/600 min
and DNG raw would be nice as can't open PEF in my old CS6
04-06-2015, 06:21 PM   #413
retired sw engineer
reh321's Avatar
QuoteOriginally posted by Shanti Quote
The old rule-of-thumb was to use 1/focal-length as the shutter speed, which would argue for a shutter-speed of roughly 1/640. However, my experience has shown that Pentax's SR system does buy some reduced shutter speed. Last month I was in San Diego visiting my daughter and took pictures using my Q-7 with its SR; I routinely was taking pictures with my 8.5mm 01 prime lens (35mm equiv of 39mm) at insane speeds like 1/15 (because of darkness inside old buildings), and I don't see any blur in these pictures. Of course, the Q-7 is "just" 12MP, which means I can't expect the kind of sharpness that you would expect from a camera with more MP, but even so I'm not convinced that it is unreasonable to expect SR to deliver reasonable pictures under the settings the OP used.
(I posted one of my pictures here https://www.pentaxforums.com/forums/136-pentax-q/290550-future-q-whats-your-t...ml#post3188910)
04-06-2015, 07:56 PM   #414
Stavri's Avatar
Thanks DagT for the shots, this lens is amazing. I'm going back and forth between Kenspos d-FA* 70-200 and your 150-450, every time I pick one dfa as my favorite the other makes me change my mind. I had faith on the lenses ability to deliver, the only concern I ever had was financing such purchases....not justifying them
04-06-2015, 11:20 PM   #415
kenspo's Avatar
QuoteOriginally posted by Stavri Quote
Both lenses are mine But i can see its a hard choice If birds and animal outside are your primary shooting, the 150-450. People, action, sport etc..i would go for the 70-200 with and extender maybe.
04-06-2015, 11:30 PM   #416
Sorry, Im using PEF out of old habit. Have you tried the Adobe DNG RAW converter? :-)
Some of them are hand held, like the cat. The first in the set now (the knitted chicken) is actually hend held at 1/125, which is amazing. I used a tripod with a ball head on most, but mainly as support as the ball was not completely tight.
DagT
04-07-2015, 07:18 AM   #417
QuoteOriginally posted by Michaelina2 Quote
From the EXIF note in LR, I notice that your K-3 firmware is listed at v.1.02 for the cat and seagull images. The most recent update is v.1.11. If I recall correctly, HD 1.4TC support was added to the FW via v.1.03. What effect might this have on the seagull photo, given that its reach was extended using the TC?
Anyway, is there a reason for your v.1.02 preference?
Just curious... M
Hmmm, I thought I had updated. The camera obviously does recognise the TC as it knows the focal length, but maybe I have lost some adjustments in later versions?
04-07-2015, 10:25 AM   #418
acoufap's Avatar
Thank you very much! Used Capture One to apply some adjustments. Nice detail / IQ. Seems I have to save some money.
04-07-2015, 11:26 AM   #419
Shanti's Avatar
DagT
Hi Ok, I wonder as its quite heavy to handhold,but it seems possible...maybe the SR is better on K3 than K5II?
any info on how fast/accurate the AF tracking is
Thanks again for your pics
04-08-2015, 01:45 PM   #420
Hi, some news from the Ricoh website :
- Come out in 2015.04.17
- Android version of the "Pentax Story" app
No release date for the 70-200 though.
Closed Thread
1.4x, 150-450mm, af, barrel, bigma, crop, da*300, dc, focus, grass, hd, image quality, iq, kg, lens, lots, mm, motor, pentax, pentax news, pentax rumors, pentax-d fa 150-450mm, position, price, shots, tc, thread, tripod, wr
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR samples flomat Lens Sample Photo Archive 53 08-29-2021 03:31 PM
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR Adam Pentax News and Rumors 917 03-13-2015 12:59 PM
Three-part review of HD Pentax 16-85mm F3.5-5.6ED DC WR (Japanese) odyseuss Pentax SLR Lens Discussion 94 12-01-2014 10:44 AM
First Look Video: HD PENTAX DA 645 28-45mm F4.5 ED AW SR Thomasbrowphoto Pentax Medium Format 10 08-06-2014 06:37 PM
HD PENTAX DA 645 28-45mm F4.5 ED AW SR Lens Review i83N Pentax News and Rumors 2 08-04-2014 07:38 PM
All times are GMT -7. The time now is 05:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
