Closed Thread
04-20-2021, 08:47 AM - 1 Like   #1471
QuoteOriginally posted by Mccsiz Quote
I am almost ready to buy. I will go with new: 2700.00 Canadian dollars, cash upfront because it is a special order. I hope I'm not making a mistake.
Cheers,
Loyd
This is one of my prized acquisition - feels wonderful in hand, heavy but substantial in a good way. I am still learning how to make good wildlife photos, but I enjoy it.
04-20-2021, 10:24 AM   #1472
Mccsiz's Avatar
Thanks mlt
It's photos like yours that reassure me. I too have a K3.
Cheers,
Loyd
04-21-2021, 01:58 PM - 2 Likes   #1473
QuoteOriginally posted by harish Quote
From the backyard.
04-21-2021, 05:46 PM   #1474
Mccsiz's Avatar
From the backyard.
Thanks Harish. Every lens is about learning.
Cheers,
Loyd
---------- Post added 04-21-21 at 05:51 PM ----------
Will this lens require a camera software update? I have no idea how to update the software in my K3. Necessary or not, does anyone have any advice about software (firmware??) updates?
Cheers,
Loyd
04-22-2021, 12:10 AM   #1475
Nice discussion. I used to carry my 150-450 on a monopod when I first got it, but quickly found this rather bothersome since I left it extended to be able to setup fast fro a shot. I carried the lens attached to a BlackRapid sport strap in one hole of the tripod mount and the monopod attached to the other hole and pointing up. It worked, but involved a dangerous swing to get the monopod to the ground in a stable position. Dangerous for people standing close to me that is.
I abandoned that approach and left the monopod, esp since I found the recent cameras having more than decent SR to stabilize the lens in most conditions. Esp with high ISO IQ improving over the years I expect the need for support for sharp shots to become less and less.
Wim
04-22-2021, 02:59 AM   #1476
Andrea K's Avatar
At 300mm what is the maximum aperture value?
04-22-2021, 05:44 AM   #1477
QuoteOriginally posted by Andrea K Quote
At 270mm its 4.5 and at 300mm its 5.6.
04-22-2021, 07:59 AM - 1 Like   #1478
dlhawes
Guest
QuoteOriginally posted by siva.ss.kumar Quote
Wow. Great shots. I sometimes think I should have gotten the 150-450 instead of 560
I've got both, but I don't think they're equivalent enough to make a "which should I get" distinction. "Yo' lens is DIFFr'nt, Mrs. Gump." The 560 is great where you can get set up and not have to move around, given its length, diameter, and weight, all of which militates against flexibility in the field. The only gripe I have with the 150-450 lack of a focus-lock switch; if the front end is pointed up at all at maximum, it'll slide back in, or if it's pointed downwards at all at the minimum, it'll slide out. You need to put a rubber band on the barrel, or some thick tape to make it stay put (and neither of those options will prevent surreptitious extension). You can use the 150-450 hand-held, I find, but that's totally impractical with the 560 (I've seen folks do it, and I've tried it even with a strap attached, but by my lights, that's a tripod-only sort of lens).
Too bad Tamron doesn't make its 150-600 available for Pentax.
04-22-2021, 08:14 AM   #1479
Mccsiz's Avatar
QuoteOriginally posted by dlhawes Quote
Does this sliding in and out of focus happen when the lens is set to auto?
And, what happens when you follow a moving object? Does the lens lose focus?
This sounds like a serious problem.
Cheers,
Loyd
04-22-2021, 10:04 AM   #1480
Denver's Avatar
Cheers,
Loyd
Cheers,
Loyd
most firmware updates require you to download the update to an sd card, put the card in your camera and turn it on and it will usually see the update and install it.
04-23-2021, 01:03 AM - 1 Like   #1481
redpit's Avatar
Cheers,
Loyd
@dlhawes talks about lens creeping due to its weight when you hold it upwards or downwards, not sliding out of focus!
For me this is not such a problem as I shot aviation and always have my hand on the zoom ring to zoom in and out, so I just stop it to the focal length I want.
04-23-2021, 01:36 AM   #1482
Andrea K's Avatar
300mm f5,6.....
04-23-2021, 05:35 AM   #1483
dlhawes
Guest
QuoteOriginally posted by redpit Quote
@dlhawes talks about lens creeping due to its weight when you hold it upwards or downwards, not sliding out of focus! ....
Right, I should have said "focal length lock switch" instead of "focus-lock". My error. So it has nothing to do with whether you're using autofocus or manual focus.
04-23-2021, 06:02 AM   #1484
Strange, my DFA150-450 does come with a zoom lock switch on the barrel (on the righthand side when mounted). I keep it engaged when the lens is in storage, though not while photographing. But you can set it to the locked position once your focal length is set, and it won't creep anymore. Corrected by noelpolar (see below): indeed the lock only locks in retracted position.
Wim
04-23-2021, 06:32 AM - 1 Like   #1485
noelpolar's Avatar
QuoteOriginally posted by Ishpuini Quote
Wim
My switch only locks the lens in it's retracted position...... has this changed during the lens production life? (mines 5+ years old).
Closed Thread
1.4x, 150-450mm, af, barrel, bigma, crop, da*300, dc, focus, grass, hd, image quality, iq, kg, lens, lots, mm, motor, pentax, pentax news, pentax rumors, pentax-d fa 150-450mm, position, price, shots, tc, thread, tripod, wr
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR samples flomat Lens Sample Photo Archive 55 10-21-2021 03:00 PM
HD PENTAX-DA 16-85mm F3.5-5.6ED DC WR Adam Pentax News and Rumors 917 03-13-2015 12:59 PM
Three-part review of HD Pentax 16-85mm F3.5-5.6ED DC WR (Japanese) odyseuss Pentax SLR Lens Discussion 94 12-01-2014 10:44 AM
First Look Video: HD PENTAX DA 645 28-45mm F4.5 ED AW SR Thomasbrowphoto Pentax Medium Format 10 08-06-2014 06:37 PM
HD PENTAX DA 645 28-45mm F4.5 ED AW SR Lens Review i83N Pentax News and Rumors 2 08-04-2014 07:38 PM
All times are GMT -7. The time now is 09:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
