02-06-2015, 01:02 PM - 1 Like   #376
konraDarnok's Avatar
QuoteOriginally posted by harrisonww Quote
Sigma 50mm 1.4 EX DG HSM
Pentax 10-17mm
Will these lenses both work on the FF and what will the range be in mm approx?
The 10-17mm will look something like this on FF
02-06-2015, 01:04 PM   #377
harrisonww's Avatar
QuoteOriginally posted by kooks Quote
The sigma yes, all Sigma DG are FF compatible... the Pentax not until 14mm + .. but at 10mm it will have an strong vignetting unless you use the Crop Mode.
Thanks Kooks
---------- Post added 02-06-15 at 03:05 PM ----------
QuoteOriginally posted by konraDarnok Quote
COOL! haha.
02-06-2015, 01:20 PM   #378
Zygonyx's Avatar
QuoteOriginally posted by GioFX Quote
I hope, and think, it will be just K-1.
I bet K-F1
02-06-2015, 03:10 PM   #379
GioFX's Avatar
QuoteOriginally posted by Zygonyx Quote
I bet K-F1
Uhm yep could be, sounds reasonable.
02-06-2015, 03:34 PM   #380
Raffwal's Avatar
QuoteOriginally posted by tuintu Quote
The name will be K1D or something else ?
Exactly - the name will be K1D or something else. The name has not been announced and AFAIK there are no plausible rumors of the name either.
02-06-2015, 03:38 PM   #381
ChristianRock's Avatar
They might not even have decided on the name yet. And honestly, the name is the least important detail for me But as we have no confirmed specs, I understand the need of something to talk about
By the way, K1D won't happen, they stopped using the D a long time ago, since the K7...
02-06-2015, 03:47 PM   #382
Or maybe K-P1, going with the K-letter number scheme.
02-06-2015, 04:04 PM   #383
FantasticMrFox's Avatar
QuoteOriginally posted by ChristianRock Quote
Unless they call it 'KZ', then Germans will riot ...
02-06-2015, 05:17 PM   #384
QuoteOriginally posted by GlassJunkie Quote
There were several sites like rice that used MZS to look at Vignettes. Post can fix the fringy (not hard image circle) vignettes in dark corners. Based on the DA* & HD coatings and integration, I'd stick with the newer glass. FA* is nice, (own several) but CA has to be taken out in post...
I am hopelessly in love with the FA limited 3 amigos. They are beautiful and temperamental. Sometimes they handle the contrast of light perfectly and then one stop on, it's a totally different story. Focusing can be challenging, particularly if you are just trying to keep a particular area in focus. I am going to move to a tripod and use a loop to be sure in my close up work. However, when all is good, the results are like "cinema like" and wonderful. My other DA lenses are nice, but don't produce the art in the same way. However, as you note, they also don't produce the artifacts either. ;-)
02-06-2015, 05:44 PM   #385
QuoteOriginally posted by jeffshaddix Quote
Zapatos means " shoes ", so I'm guessing it's related to a hot shoe mount.
Thanks for the clarification! Sounds close in Filipino (Tagalog) - Sapatos - shoe. If this is true then there is a hotshoe up there above the prism. A popup flash could go, but it wouldn't make sense for a costly full-frame not to have a hotshoe.
02-07-2015, 01:18 AM   #386
kenspo's Avatar
I think the reason for that, is that they wait until the last minute, to make shure they have the absolute latest of technology onboard when they release the camera. This is my thoughts and not info It will fit with the new thinking of Ricoh/Pentax.
02-07-2015, 02:11 AM   #387
I remember when they didn't even knew the buffer size, when they launched the K-5 The brochures were all wrong, overestimating camera's capabilities - and then were still wrong after the first firmware update which managed to fit many more frames into the buffer.
I guess it's a bit early to publish specs 6-7 months in advance.
02-07-2015, 09:01 AM   #388
D1N0's Avatar
QuoteOriginally posted by crewl1 Quote
Initial specs say KAF3 so unless that changes it would be NO.
And actually the mount designation on the body should be KAF2 to support screw drive lenses so the KAF3 spec is suspect.
There is a physical AF switch on the Dummy so there is a screw drive in the body.
02-07-2015, 09:20 AM   #389
It looks good, compact enough for an FF.
02-07-2015, 09:33 AM   #390
D1N0's Avatar
When Pentax would do the oly resolution trick with the FF and they used a 36mp sensor that would become 90mp. (or 60 for 24) W00t.
150-450mm, 70-200mm, apple, body, camera, canon, custom, dc, dfa, dpreview, dslr, f/2.8, f/4.5-5.6, fa, ff, firmware, hd, lens, lens purchase, lenses, market, pentax, pentax news, pentax rumors, people, post, product, site, strategy
Pentax Full Frame DSLR Officially Announced! PF Staff Homepage & Official Pentax News 61 02-09-2015 07:13 AM
D-FA* 70-200mm and D-FA 150-450mm Announced PF Staff Homepage & Official Pentax News 7 02-08-2015 03:10 PM
HD PENTAX-DFA 70-200 coming soon awaymars Pentax Full Frame 5 02-03-2015 09:30 PM
DFA 100 macro or DFA 100WR macro or Sigma 70 Shanti Pentax SLR Lens Discussion 7 03-03-2013 12:06 AM
Pentax 560mm, 18-270mm, and DFA 645 90mm Macro Officially Announced Adam Pentax SLR Lens Discussion 5 09-11-2012 05:58 AM
All times are GMT -7. The time now is 02:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
