02-08-2015, 03:54 PM   #121
Class A's Avatar
They already did last year. Look for our review of the DA 1.4x converter.
I believe the question was targeted at a TC that supports AF even for MF lenses.
02-08-2015, 03:54 PM   #122
Class A's Avatar
Now for interview questions:
Will the lens naming be updated to allow easy identification which lenses can also be used on the FF?
02-08-2015, 03:55 PM   #123
Class A's Avatar
What is the source of the P-TTL flash delay on the K-3?
02-08-2015, 04:00 PM   #124
Class A's Avatar
Why not allow users downgrading to older firmware versions?
The camera could issue a warning when detecting an older firmware, but that should be overridable.
Sometimes new firmware versions appear promising, but then turn out to change aspects one would rather have seen unchanged. It would be very nice if one could downgrade in such cases. With the current scheme -- upgrades only -- I often do not upgrade due to not being able to undo the step.
I realise that there is a point in having everyone operate with the latest firmware -- it simplifies troubleshooting and service questions -- so any time this becomes relevant the latest firmware version could be required by Pentax/Ricoh. Furthermore, in practice, many users will not be on the latest firmware version anyhow.
02-08-2015, 04:01 PM   #125
Class A's Avatar
Have Ricoh considered using the SR mechanism to support macro shooting?
This would require the use of translation sensors for shake reduction and perhaps even calculating movement along the lens axis in order to automatically adjust focus.
02-08-2015, 04:03 PM - 1 Like   #126
Class A's Avatar
Have Ricoh considered to change the aperture during the exposure?
This would implement an apodisation simulator that could equip many lenses with the buttery smooth bokeh of the 135 f/2.8 T/4.5 STF lens.
02-08-2015, 04:04 PM   #127
Class A's Avatar
Why isn't the USB3 connection of the K-3 used for tethering?
It would support much quick transfer of images compared to the FLUcard.
02-08-2015, 04:07 PM   #128
Class A's Avatar
Have Ricoh considered using frame lines in the viewfinders instead of blacking out the non-APS-C parts when using APS-C crop mode on the FF model?
This would allow seeing objects move into the frame, before they actually entered the APS-C crop area.
Seeing a bit of context around the actual frame is a feature that makes rangefinder cameras very interesting to some and the FF model could offer it for the APS-C crop mode.
02-08-2015, 04:26 PM   #129
aurele's Avatar
QuoteOriginally posted by Asahiflex Quote
I have a question about the lenses. As we all know Pentax has made quite a few legendary lenses in the past. The Holy Limited Trinity, certain lenses in the A* and FA* series etc.
Is Ricoh/Pentax planning to develop more legendary lenses in the future? And with that I mean lenses which do not have perfect MTF graphs but a pleasing overall picture (not overcorrected: no harsh bokeh, no onion bokeh etc.)
Second
I'll second that too
And i will add : Pentax have a great lens legacy, but also shown new exciting lens recently (DFA*). Will Pentax exclusively developpe new lenses or do you consider using this legacy ?
02-08-2015, 10:21 PM   #130
Is it really, I mean really coming out? Are you sure?
02-09-2015, 12:35 AM   #131
A question I would like to submit:
With the K-S2 having a flip out screen, (a first for Pentax) as well as, a mic jack are we correct to assume that the K-S2 is intended to give a superior video experience compared to Pentax's previous cameras?
Last edited by SGOMMO7; 02-09-2015 at 12:54 AM. Reason: my post got merged into one so I was afraid I would be ignored for asking two questions
02-09-2015, 01:33 AM   #132
"Thank you Ricoh!"
02-09-2015, 02:17 AM - 1 Like   #133
Ricoh recently released a SDK (Software Development Kit) for the Theta. Are there any plans to release a SDK for DSLR's like the K-3?
Allowing 3rd party developers to build apps for Pentax cameras and expand camera functionality (eg to support tethering, or expand the range of video options) would be very useful for a wide range of users.
---------- Post added 2015-02-09 at 08:25 PM ----------
Cameras like the K-3 and 645Z already support exposure bracketing. It seems technically possible to also do focus bracketing (when AF lenses are mounted) with current cameras. Does Ricoh have any plans to add a focus bracketing option to the camera menu in any future Pentax DSLR's?
In-camera focus bracketing would be very useful for macro photography, as well as other shooting genres. It could work as an extension of the existing 'catch in focus' capability of all Pentax DSLR's.
02-09-2015, 02:33 AM - 1 Like   #134
donfenix's Avatar
Great idea, but also very much a niche. This could easily be accomplished via a photoshop action with crop mode disabled for DA lenses.
Adam, the main problem with what you are proposing is that the exposure will get somewhat random, especially that 4 corners plus two bands on either side of the image will be black (that's ~30% of your image). If you shoot in crop mode, choosing your crop type (regular APS-C, portrait APS-C, or Square as I proposed) before you release the shutter, it would give you many benefits including the following:
  • The camera will know exactly what part of the sensor to care about in terms of exposure, but also data processing (think time-saving, memory allocation and buffer fill optimization, battery saving, etc).
  • Your chances of taking better composed pictures increase because you will have to actually think about your composition properly and will be able to visualize it right off the bat (rather than making it an after-thought process).
  • In portrait APS-C crop mode you'll read the info in your viewfinder or on the screen easily since the text will be horizontal
  • In portrait APS-C crop mode your flash will illuminate your subject from the direction you want, and will be easier to bounce (especially if it doesn't have a swivel head like the 1st generation AF 360FGZ)
  • In square crop mode you'll effectively use 63% more sensor area (20.4^2 instead of 16^2)
  • In square crop mode your crop factor will be effectively 1.18 (24/20.4) instead of 1.5 (24/16). Your perspective control will be easier for scenes and subjects that have 1:1 aspect ratios. Your "35mm equivalent" focal length will be much closer to the lens' actual focal length because you'll multiply it by 1.18 instead of 1.5.
02-09-2015, 03:25 AM   #135
QuoteOriginally posted by RonHendriks1966 Quote
Maybe a good moment to ask if there are some new lenses coming in the FA Limiteds line?
I don't think they will ever relase another FA limited. They will get a rework and be labeled D-FA * WR or something similar.
camera, canon, composition, cp, cp pentax interview, ff, focus, home, interview, mode, nikon, option, pentax, pentax interview question, pentax news, pentax rumors, photo, pm, post, products, question, questions, ricoh, role, sensor, sr, suggestions, user
CP+ 2014 Interview Posted Adam Pentax News and Rumors 331 03-19-2014 02:30 PM
CP+ 2014 Pentax Interview: Question Suggestions Adam Photographic Industry and Professionals 137 02-24-2014 12:59 AM
CP+ 2013 Pentax Interview Posted Adam Pentax News and Rumors 49 02-20-2013 06:57 AM
CP+ Interview Question Suggestion Follow-Up Adam Pentax News and Rumors 67 02-11-2013 05:40 PM
PentaxForums at CP+ 2013, Interview Question Suggestions Adam Pentax News and Rumors 189 01-29-2013 08:36 PM
All times are GMT -7. The time now is 12:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
