Originally posted by Rondec
Probably will be of limited use in a lot of situations, but it is amazing all the little things you can do with software when you have in body image stabilization. Just try to do this with your in lens image stabilization...
I don't see a good reason why you couldn't do this with in-lens stabilization. You'd need to re-align the images so the process wouldn't be quite the same, but I don't see any other impediment? Maybe the camera can't control the in-lens stabilization?
There is software that combines multiple handheld images into one with higher resolution, or grabs multiple lower res frames from video and mashes it into one higher resolution frame. Some pretty neat processing is possible, I'm not sure of how the computational costs relate to in-camera processing power though.
