Originally posted by RGlasel
So, I strongly suspect that the first new lens release (not already on the roadmap) will be an update of the 300mm prime to incorporate a DC AF motor, since the current optical design can fit a FF image circle and the new lens can be sold to existing APS-C users as well as new FF users. The necessary work to have DC drive entry level zooms has already been done, with the future wide angle DA zoom on the roadmap probably replacing the 12-24. For entry level to mid-level APS-C users, the only remaining lens that really needs an AF motor update is the 55-300, and with its short focus throw, that might not be a big priority. Since the super-zooms are rebadges, they probably are even lower on the priority list. The question in my mind is whether Pentax sees the need to update the DA* zooms and shorter DA* primes to DC AF from SDM (and from SMC to HD or Aerobright II coatings) or expects those potential customers to buy D FA lenses instead. The D FA lenses are going to be premium priced lenses, no matter what, and the only disadvantages of covering the FF image circle instead of only APS-C is size and weight. There is an expectation that more expensive lenses weigh more and not just among FF camera users.
Originally posted by Blue
You will find that the FA prime lenses are quite compact. The D FA 100 WR and D FA 50/2.8 aren't large lenses either. The A50/1.2 is not large even though it is the fastest lenses Pentax made granted its manual focus. Remember, this is Pentax we are talking about here and they have been making some remarkably small full frame lenses since the 1950s.
The weight issue shouldn't be under-estimated. The new 150-450mm and 70-200mm are about 2 kilograms each. Compare that with the DA* 300mm and DA* 60-250mm lenses, about 1 kilogram each. (I know
I can't successfully hand-hold a 3 kilogram long lens, and I've got rid of the Sigma 500mm f/4.5 in part-exchange for the two new lenses for that reason).
I suspect any D FA* wide angle zoom will weight about twice as much as the nearest current Pentax APS-C equivalent. Ricoh won't expect everyone to use or switch to FF, and I expect they will continue to have
high quality APS-C zooms that are smaller, lighter, and cheaper than the new D FA zooms. They won't assume that people who want smaller lighter lenses will all go for primes. I personally have little use for primes except specialist ones.
