02-28-2015, 11:10 AM   #331
QuoteOriginally posted by aleonx3 Quote
I am not sure if anyone agrees that it is useful or not, but after switching between spot metering and center-weigh metering in a recent gig, suddenly something occurs to me - why can they not make the spot metering to center-weigh metering in steps or something in between (or perhaps make the spot size adjustable). That would be a great feature to have in the pro/advanced camera model.
The most interesting thing they could do would be to reduce the spot surface which is too big on th K3. Pro models from other brand have a smaller spot so it's more precise to set a good exposure.
02-28-2015, 11:20 AM   #332
aleonx3's Avatar
QuoteOriginally posted by Black_Wizards Quote
smaller spot is not necessarily a good thing either... something adjustable would be most helpful.
02-28-2015, 11:48 AM   #333
thibs's Avatar
AFAIK the only problems with KatzEyes (and co.) screens with split screen are hen using spot metering fith f5.6 or lower (when it becomes dark so obviously throws the metering off).
As for the spot metering itself, I use a 1░ spotmeter when shooting 4x5. I really would like 1░ spot in a Pentax. I don't see the problem with a 1░ but if 3░ can get someone happy, lets get 1/3/5░ spot
02-28-2015, 12:37 PM   #334
aleonx3's Avatar
I ran into a situation where I have 2 kungfu masters doing their moves on stage, one is dress in all-black and the other one in all-white. I seem to be able to hit the one dressed in white more often than the one in black....and it is on-stage and lighting is on the stage only - otherwise, pretty much dark aside from the stage. I am using TAv mode, I later try using M mode after a few tries.
02-28-2015, 12:56 PM   #335
Otis Memorial Pentaxian
clackers's Avatar
In such a low light, low contrast situation you may be better off with manual focus, Aleonx.
02-28-2015, 01:18 PM   #336
aleonx3's Avatar
Thanks, you are correct about focusing and I am with you on that, but I am referring to metering (so I don't have blown highlights in many of the photos focusing on the one dressed in black and too dark for the one dressed in white).
02-28-2015, 01:30 PM   #337
clackers's Avatar
Oh, apologies, Aleonx - of course you're talking about exposure.
Are you not metering their faces, though?
02-28-2015, 01:37 PM   #338
aleonx3's Avatar
It is not possible as they moved very quickly.... I use MF m42 lens and snap focus-release (higher success rate than auto-focus). For the most part, I get the body in focus which is the reason why APS-C in this case works better with a more DOF than those guys using FF and longer lens.
02-28-2015, 01:38 PM   #339
M mode is the (only) way to go in such situations - if you can be sure the lighting does not change during the shooting.
02-28-2015, 02:49 PM   #340
aleonx3's Avatar
Thanks guys, for all the great input... nonetheless, a more refined 'spot' metering option would be very helpful; otherwise, a bit of trial-and-error will still work (this is where experience comes in very handy). Cheers!!
02-28-2015, 05:32 PM   #341
The MOST AWESOME spot metering system strategy that I ever encountered, regardless of being in-camera or a dedicated meter- was offered in the Olympus OM-4 as 'Automatic Multiple Spot Averaging'. It could handle up to 9 measurements- although I found that no more than 3 were typically really necessary. The display info in the viewfinder was laid-out as a linear bar along the bottom of the screen showing individual segments of 1/3 stops along with shutter speed or aperture (according to mode). Each reading placed a fixed diamond at its particular value along the bar graph, a flashing diamond then indicated the averaged result. At the time Olympus used the ring equivalent to the Pentax depth of field switch to clear the measurement memory. Incredibly fast, informative and easy to use! 1st spot on the darkest or lightest part of the subject, 2nd spot on the opposite- immediately can read the contrast range of the subject against the speed or aperture settings. The average between the two is already blinking and locked-in ready for automatic exposure. At this point you can instantly choose to accept the average and press the shutter release, or change to manual override (knowing what your contrast range is and its average camera setting), or you could instantly bias the automatic exposure system by including an additional spot reading(s). For example just placing a 3rd spot once again at either the darkest or lightest part of the scene will bias the exposure to 3/4 of the contrast range in favor of that end. This was incredibly useful in the days of 5 stop slide film and only 3 stop printing latitude! Being able to apply and simultaneously view more than 3 measurements enabled scene tone mapping. In cases where the contrast range of the image greatly exceeded the latitude of the medium- you could always elect to quickly clear the memory and substitute metering the extremes to metering the items you wanted near the distinguishable limits of the restricted latitude. Incredibly powerful in terms of information gathering, decision making, convenience and speed!
02-28-2015, 05:44 PM   #342
bobell69's Avatar
I find photographing birds in trees difficult with the size of the centre spot on my K5. A smaller centre spot would sure be helpful.
02-28-2015, 07:07 PM   #343
aleonx3's Avatar
QuoteOriginally posted by bobell69 Quote
I am not sure if spot metering and focussing spot are the same (or may be they are)... agree with you that smaller focusing point could be helpful especially in the situation you mentioned.
02-28-2015, 07:16 PM - 1 Like   #344
Yes they are. So spot metering is very dramatic on the K3. Very easy to meter on a small white spot. I often spot meter on the brightest part, hit ae-l to fix the exposure, recompose and shoot. That may work for you.
02-28-2015, 07:51 PM - 1 Like   #345
Class A's Avatar
If you had an FF camera, you would just stop down your lens accordingly to get the same DOF as you are getting with APS-C.
In other words, there is no "deeper DOF" advantage for APS-C (unless you go into f/22 territory).
Regarding metering, I'd really like a "highlight protection" mode that exposes in such a way that the brightest parts in the image do not get blown out. This would support the "ETTR" (expose to the right) approach that works well for me as I'm always post-processing anyhow.
It would be acceptable to me, if the camera adjusted the metering based on prior shots of the same scene, evaluating the actual sensor data, which is more accurate than just relying on the metering chip.
aps, aps-c, camera, card, conversation, cp, dof, ff, flash, focus, format, full frame, images, k-3, lens, lenses, magnification, mp, off-topic, pentax, pentax news, pentax rumors, plastic, pop-up, popup, ricoh, sd, unveiling
First image of the Full Frame Curved sensor!ůmade for the RX2? interested_observer Canon, Nikon, Sony, and Other Camera Brands 12 09-15-2014 10:04 PM
Economics of full frame mikemike Film SLRs and Compact Film Cameras 47 06-24-2014 03:47 PM
From Full-Frame Sony... to Pentax... to Full-Frame Canon Mr_Canuck Canon, Nikon, Sony, and Other Camera Brands 42 01-21-2014 12:50 AM
Full frame or no full frame.... Deedee Pentax K-3 & K-3 II 14 10-08-2013 05:39 AM
Is full frame the medium format of the digital era ? ghelary Photographic Technique 2 05-28-2009 08:50 AM
All times are GMT -7. The time now is 10:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
